Hi, I am trying to upload the basic example of esp-sr on my esp32-s3 (esp32-s3 DevkitC 1 N16R8), the upload is done correctly but in the serial I see this
[ 517][V][esp32-hal-uart.c:510] uartBegin(): UART0 not installed. Starting installation
[ 526][V][esp32-hal-uart.c:575] uartBegin(): UART0 initialization done.
[ 533][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type GPIO (1) successfully set to 0x42061958
[ 544][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 40 successfully set to type GPIO (1) with bus 0x29
[ 554][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type GPIO (1) successfully set to 0x42061958
[ 565][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 41 successfully set to type GPIO (1) with bus 0x2a
[ 575][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type I2S_STD_BCLK (13) successfully set to 0x42002f3c
[ 587][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type I2S_STD_WS (14) successfully set to 0x42002f3c
[ 598][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type I2S_STD_DIN (16) successfully set to 0x42002f3c
[ 611][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 17 successfully set to type I2S_STD_BCLK (13) with bus 0x3fc9aaf8
[ 622][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 47 successfully set to type I2S_STD_WS (14) with bus 0x3fc9aaf8
[ 633][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 16 successfully set to type I2S_STD_DIN (16) with bus 0x3fc9aaf8
[ 645][D][esp32-hal-sr.c:338] sr_start(): init model
[ 650][D][esp32-hal-sr.c:346] sr_start(): load wakenet 'wn9_hiesp'
Guru Meditation Error: Core 1 panic'ed (StoreProhibited). Exception was unhandled.
(I have the Core Debug Level in Verbose)
I share with you the code although it is the same of the example without modification
#include "ESP_I2S.h"
#include "ESP_SR.h"
#define I2S_PIN_BCK 17
#define I2S_PIN_WS 47
#define I2S_PIN_DIN 16
#define LIGHT_PIN 40
#define FAN_PIN 41
I2SClass i2s;
// Generated using the following command:
// python3 tools/gen_sr_commands.py "Turn on the light,Switch on the light;Turn off the light,Switch off the light,Go dark;Start fan;Stop fan"
enum {
SR_CMD_TURN_ON_THE_LIGHT,
SR_CMD_TURN_OFF_THE_LIGHT,
SR_CMD_START_FAN,
SR_CMD_STOP_FAN,
static const sr_cmd_t sr_commands[] = {
{0, "Turn on the light", "TkN nN jc LiT"},
{0, "Switch on the light", "SWgp nN jc LiT"},
{1, "Turn off the light", "TkN eF jc LiT"},
{1, "Switch off the light", "SWgp eF jc LiT"},
{1, "Go dark", "Gb DnRK"},
{2, "Start fan", "STnRT FaN"},
{3, "Stop fan", "STnP FaN"},
void onSrEvent(sr_event_t event, int command_id, int phrase_id) {
switch (event) {
case SR_EVENT_WAKEWORD: Serial.println("WakeWord Detected!"); break;
case SR_EVENT_WAKEWORD_CHANNEL:
Serial.printf("WakeWord Channel %d Verified!\n", command_id);
ESP_SR.setMode(SR_MODE_COMMAND); // Switch to Command detection
case SR_EVENT_TIMEOUT:
Serial.println("Timeout Detected!");
ESP_SR.setMode(SR_MODE_WAKEWORD); // Switch back to WakeWord detection
case SR_EVENT_COMMAND:
Serial.printf("Command %d Detected! %s\n", command_id, sr_commands[phrase_id].str);
switch (command_id) {
case SR_CMD_TURN_ON_THE_LIGHT: digitalWrite(LIGHT_PIN, HIGH); break;
case SR_CMD_TURN_OFF_THE_LIGHT: digitalWrite(LIGHT_PIN, LOW); break;
case SR_CMD_START_FAN: digitalWrite(FAN_PIN, HIGH); break;
case SR_CMD_STOP_FAN: digitalWrite(FAN_PIN, LOW); break;
default: Serial.println("Unknown Command!"); break;
ESP_SR.setMode(SR_MODE_COMMAND); // Allow for more commands to be given, before timeout
// ESP_SR.setMode(SR_MODE_WAKEWORD); // Switch back to WakeWord detection
default: Serial.println("Unknown Event!"); break;
pinMode(LIGHT_PIN, OUTPUT);
pinMode(FAN_PIN, OUTPUT);
i2s.setPins(I2S_PIN_BCK, I2S_PIN_WS, -1, I2S_PIN_DIN);
i2s.setTimeout(1000);
i2s.begin(I2S_MODE_STD, 16000, I2S_DATA_BIT_WIDTH_16BIT, I2S_SLOT_MODE_STEREO);
ESP_SR.onEvent(onSrEvent);
ESP_SR.begin(i2s, sr_commands, sizeof(sr_commands) / sizeof(sr_cmd_t), SR_CHANNELS_STEREO, SR_MODE_WAKEWORD);
void loop() {}
I have downloaded the libraries from the github repository, latest version of the esp32 core.
