ESP to ESP continuously communication
Hi guys,
Quick help on my project please. I am using 2 Node MCUs (ESP8266).
I would like to have a two way communication between those two, while continuously being connected.
I wrote these 2 project codes but it seems that the client and server disconnects after first message sent between those two.
The clients only sends every 3 seconds a message.
The server tries to connect and then displays the message from the client (if any).
I want the connection to be one time, not in loop, so i’ve done it in setup()
THIS IS THE CLIENT code:
// esp client 2
#include <ESP8266WiFi.h>
byte ledPin = LED_BUILTIN;
char ssid[] = "Lepy_IoT";           // SSID of your AP
char pass[] = "lepy1234";         // password of your AP
IPAddress serverIP(192, 168, 4, 1);  // IP address of the AP
WiFiClient client;
  WiFi.mode(WIFI_STA); // configure as STATION not as ACCES POINT
  WiFi.begin(ssid, pass);           // connects to the WiFi AP (Server)
  Serial.println("Connection to the AP");
    Serial.print(".");
  Serial.println("Connected"); // prints IP, Gateway and SERVER MAC to Serial
  Serial.print("LocalIP:"); Serial.println(WiFi.localIP());
  Serial.println("MAC:" + WiFi.macAddress());
  Serial.print("Gateway:"); Serial.println(WiFi.gatewayIP());
  Serial.print("AP MAC:"); Serial.println(WiFi.BSSIDstr());
  pinMode(ledPin, OUTPUT);
  client.connect(serverIP, 80); // connects one time to server Ip and port
 // client.connect(serverIP, 80);
void loop() { // this sends every 3 seconds a message
sendSomething();
//client.connect(serverIP, 80);
  //client.flush();
  digitalWrite(ledPin, HIGH);
 // client.flush();
  delay(3000);
void sendSomething()
  String s = "Hello, 3 s passed!";
  Serial.println("Sending string: " + s);
  client.print(s + "\r");
  // client.flush(); // flush or not the client ?
THIS IS THE SERVER CODE:
// This is the ACCES POINT (SERVER):
WiFiServer server(80); // port of the server
IPAddress IP(192, 168, 4, 1); // set the IP of the server
IPAddress mask = (255, 255, 255, 0); // set the mask of the server (OPTIONAL)
byte ledPin = LED_BUILTIN; // select LED pin
WiFiClient client;
  WiFi.mode(WIFI_AP); // set the mode to ACCES POINT not STATION!
  WiFi.softAP("Lepy_IoT", "lepy1234"); // set the SSID and PASSWORD
  WiFi.softAPConfig(IP, IP, mask); // WiFi.softAP(ssid, password, channel, hidden, max_connection) -> https://arduino-esp8266.readthedocs.io/en/latest/esp8266wifi/soft-access-point-class.html
  // de incercat cu un IP numai!
  server.begin(); // start the server
  Serial.println("Server started.");
  Serial.print("IP: "); Serial.println(WiFi.softAPIP()); // print IP and MAC address
  Serial.print("MAC:"); Serial.println(WiFi.softAPmacAddress());
int conn = 0; // 0 if not connected, 1 else
void conect() // try to connect with client
  client = server.available();
  if (!client)
    Serial.println("Try to connect with client... ");
    conect();
    return;
    conn = 1;
    Serial.println("Connected with Client");
  if (!(client = server.available())) // check if still connected
    conn = 0;
  while (conn == 0) // while not connected to client...
    conect(); // try to connect
  String request = client.readStringUntil('\r'); // get string from CLIENT
  if (request == "") // if no string is sent
    Serial.println("No msg recieved");
  else // string is recieved
    Serial.println("Msg recieved: ");
    Serial.println("From the client: " + request);
  // client.flush(); // flush the client ?
And…
should i use client.flush() after every message send and received ? or never if continuously connected?
What is wrong with this ? why it keeps disconnecting after the first message received.
  1. Clients connects with server
  2. Clients sends server msg
  3. Server receives msg and disconnects
“and disconnects” is the problem => it should still receive a message every 3 seconds.
Thank you in advance
