I'm using Arduino IDE 2.3.2 on a W11 PC. The board is ESP32 Dev Module. Here is a simplified program that doesn't compile:
#include <WiFi.h>
}type or paste code here
This the error I get:
In file included from C:\Users\nesto\Arduino\hardware\espressif\esp32\libraries\WiFi\src\ETH.cpp:21:
C:\Users\nesto\Arduino\hardware\espressif\esp32\libraries\WiFi\src\ETH.h:54:9: error: 'eth_config_t' does not name a type; did you mean 'gpio_config_t'?
I'm running 1.8.10 and once I deleted the instructions from the outside of the loop() curly braces, it compiled fine for me on Arduino Uno
As @hallowed31 say, the error is
that you should have deleted.
Here is the new simplified same code:
#include<WiFi.h>
here is the pertinent part of the error message:
The error has nothing to do with the text outside the braces. That was my copy/paste error. I think the problem is in the esp32 WiFi.h library
Hi @neetgeek .
It looks like it. There is no libraries/WiFi/src/ETH.h file in the official "esp32" boards platform so it seems that you have made unknown modifications to the platform you have installed on your computer.
Unless you intentionally modified your installation, my recommendation is to remove the bad installation and then make a fresh good installation. I also recommend using the Arduino IDE Boards Manager to install the platform instead of the more complicated and error prone manual installation you chose to perform for unknown reasons.
I'll provide instructions you can follow to do that:
If Arduino IDE is running, select File > Quit from the IDE's menus.
All Arduino IDE windows will close.
Delete the folder at the following path:C:\Users\nesto\Arduino\hardware\espressif\esp32\
Please be careful when deleting things from your computer. When in doubt, back up!
Open the web page containing Espressif's official installation instructions for the ESP32 boards platform:
https://docs.espressif.com/projects/arduino-esp32/en/latest/installing.html#installing-using-arduino-ide
Copy the URL shown under the "Stable release link " section of that page.
Start Arduino IDE.
Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
The "Preferences " dialog will open.
Add the URL you copied from the ESP32 boards platform installation instructions to the "Additional Boards Manager URLs " field.
ⓘ If there are other URLs in the field, separate them with commas (,).
Click the "OK " button on the "Preferences " dialog.
The "Preferences " dialog will close.
You will now see a "Downloading index: ... " notification at the bottom right corner of the IDE window. Wait for that notification to close.
Select Tools > Board > Boards Manager... from the Arduino IDE menus to open the "Boards Manager " view in the left side panel.
Scroll down through the list of boards platforms until you see the "esp32 by Espressif Systems " entry.
Click the "INSTALL " button at the bottom of the entry.
Wait for the update process to finish, as indicated by a notification at the bottom right corner of the Arduino IDE window:
Successfully installed platform ...
Select Tools > Board > esp32 > ESP32 Dev Module from the Arduino IDE menus.
Now compile your sketch again. Hopefully this time it will compile without any errors.
I reiterate, I have no compilation errors so I can't imagine what the problem is.
Thank you. It worked. I suspect the offending file was included when I restored from a backup. It was included in an earlier release from Espressif, but was on my backup medium from an earlier backup.
You are welcome. I'm glad it is working now.
Regards,
Per
ptillisch: I am having a similar problem with another example program:
#include <WiFi.h>
#include <WiFiClient.h>
#include <WebServer.h>
#include <ESPmDNS.h>
void setup(void) {}
void loop(void) {}
There are a lot of lines of output from the compiler, but the pertinent lines are:
Detecting libraries used...
"C:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.7-dirty\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/log/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/console" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mul/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/add/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/addc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mulc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/sub/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mul/test/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\nesto\\AppData\\Local\\Temp\\arduino_build_32088/build_opt.h" "@C:\\Users\\nesto\\AppData\\Local\\Temp\\arduino_build_32088/file_opts" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15\\cores\\esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15\\variants\\esp32" "C:\\Users\\nesto\\AppData\\Local\\Temp\\arduino_build_32088\\sketch\\AdvancedWebServer-1.ino.cpp" -o nul
Alternatives for WiFi.h: [WiFi@1.2.7 WiFi@2.0.0]
ResolveLibrary(WiFi.h)
-> candidates: [WiFi@1.2.7 WiFi@2.0.0]
"C:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.7-dirty\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/log/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/console" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mul/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/add/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/addc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mulc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/sub/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mul/test/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\nesto\\AppData\\Local\\Temp\\arduino_build_32088/build_opt.h" "@C:\\Users\\nesto\\AppData\\Local\\Temp\\arduino_build_32088/file_opts" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15\\cores\\esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15\\variants\\esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15\\libraries\\WiFi\\src" "C:\\Users\\nesto\\AppData\\Local\\Temp\\arduino_build_32088\\sketch\\AdvancedWebServer-1.ino.cpp" -o nul
Alternatives for WebServer.h: [WebServer@2.0.0 WebServer-esp32@1.0]
ResolveLibrary(WebServer.h)
-> candidates: [WebServer@2.0.0 WebServer-esp32@1.0]
"C:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.7-dirty\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/log/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/console" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mul/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/add/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/addc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mulc/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/sub/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mul/test/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\nesto\\AppData\\Local\\Temp\\arduino_build_32088/build_opt.h" "@C:\\Users\\nesto\\AppData\\Local\\Temp\\arduino_build_32088/file_opts" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15\\cores\\esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15\\variants\\esp32" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15\\libraries\\WiFi\\src" "-IC:\\Users\\nesto\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.15\\libraries\\WebServer\\src" "C:\\Users\\nesto\\AppData\\Local\\Temp\\arduino_build_32088\\sketch\\AdvancedWebServer-1.ino.cpp" -o nul
Alternatives for ESPmDNS.h: [ESPmDNS@2.0.0 ESPmDNS@1.0]
ResolveLibrary(ESPmDNS.h)
-> candidates: [ESPmDNS@2.0.0 ESPmDNS@1.0]
Alternatives for FS.h: [FS@2.0.0]
ResolveLibrary(FS.h)
-> candidates: [FS@2.0.0]
In file included from C:\Users\nesto\Arduino\AdvancedWebServer-1\AdvancedWebServer-1.ino:4:
C:\Users\nesto\Arduino\libraries\ESPmDNS\src/ESPmDNS.h:87:53: error: could not convert 'ESP_IF_WIFI_STA' from 'esp_interface_t' to 'wifi_interface_t'
void enableWorkstation(wifi_interface_t interface=ESP_IF_WIFI_STA);
I deleted the folder you told me to. It is now empty.
Delete the folder at the following path:
C:\Users\nesto\Arduino\hardware\espressif\esp32\
Is there something else I need to delete?
I see you have installed a standalone copy of the "ESPmDNS" library. The installation of the "esp32 " boards platform includes a bundled copy of this library. The version of the library that is bundled with the platform is designed to be used with that version of the platform. The standalone installation you made is not compatible with the version of the platform (it seems to be an older version of the library). This is the cause of the error.
The solution will be to delete the incompatible installation of the library. Delete the folder at the following path:
After that, try compiling your sketch again. Hopefully it will work this time.
Thank you. It worked. I guess the problem is that I installed a library in ~/Arduino/libraries from a web site instead of using espressif's version.
You have been very helpful.
Larry N
system
Closed
October 12, 2024, 4:04pm
12
