Hello all together,
I`m triying to get the Impuls of a reed contact out of my ESP (over Seriell Monitoring )
It is possible with this code on the Ardoino Uno, but it doesn´t work with the ESP.
What is my mistake ???
I tried already to change the unsigned Long to unsigned int… But that wasn´t the reason.
Here is the Code:
// Impulszähler
// Gibt die Impulse pro Sekunde
// des Spannungsignals an Pin 7 aus
int pin = 1;
unsigned long N; //Anzahl der Impulse
unsigned long T; //Zeitintervall in us
unsigned long time; //Startzeit
const byte pinLedgruen = 2;
const byte pinLedblau = 3;
const byte pinLedrot = 4;
int Variabel = 5;
void setup(){
pinMode(pin, INPUT);
pinMode(pinLedgruen, OUTPUT);
pinMode(pinLedblau, OUTPUT);
pinMode(pinLedrot, OUTPUT);
pinMode (Variabel, OUTPUT);
T = 1e6;
void loop(){
N = 0;
time = micros();
do{
if (pulseIn(pin, HIGH)>0) N++;
while( micros() < (time+T) );
Serial.println(N);
void zeige_Drehzahl (unsigned long N, unsigned int intervall);
static unsigned long last_ms = 0;
unsigned long ms = millis();
if ( N <= 3 ){
digitalWrite (pinLedgruen, HIGH );
else {
digitalWrite (pinLedgruen, LOW );
if ((N >3)&&(N <=17)) {
digitalWrite (pinLedblau, HIGH );
else {
digitalWrite (pinLedblau, LOW );
if ((N >17)&&(N <=200)){
digitalWrite (pinLedrot, HIGH );
else {
digitalWrite (pinLedrot, LOW );
