Bonjour,
j'ai un WeMos D1 ESP-Wroom-02 ESP8266 - 18650 batterie.
https://fr.aliexpress.com/item/32813501130.html?spm=a2g0o.order_list.order_list_main.4.36105e5b2glnsH&gatewayAdapt=glo2fra
J'arrive à lire des données depuis le port série, mais je n'arrive pas à faire fonctionner le blink et le programme mis à la fin ( qui fonctionne avec un esp32)
C'est peut etre un probleme de board manager
Mais j'ai essayé le generic, tout les LOLIN, tout les nodeMcu et rien ne fonctionne complètement.
Dois je acheter une ESP32?
Open Sound Control (OSC) library for the ESP8266/ESP32
Example for receiving open sound control (OSC) messages on the ESP8266/ESP32
Send integers '0' or '1' to the address "/led" to turn on/off the built-in LED of the esp8266.
This example code is in the public domain.
#ifdef ESP8266
#include <ESP8266WiFi.h>
#else
#include <WiFi.h>
#endif
#include <WiFiUdp.h>
#include <OSCMessage.h>
#include <OSCBundle.h>
#include <OSCData.h>
//char ssid[] = "Iphone de ben"; // your network SSID (name)
//char pass[] = "cacaprout"; // your network password
//char ssid[] = "Bbox-E69F0626"; // your network SSID (name)
//char pass[] = "NKg5Ad1m3mXFgx142p"; // your network password
char ssid[] = "SFR-d078"; // your network SSID (name)
char pass[] = "DEDW3VPARYGZ"; // your network password
// A UDP instance to let us send and receive packets over UDP
WiFiUDP Udp;
//const IPAddress outIp(10,40,10,105); // remote IP (not needed for receive)
//const IPAddress outIp(192, 168, 1, 77); // heltec
//const IPAddress outIp(192,168,1,97); // node32s 97
//const IPAddress outIp(192,168,0,26); // node32s 26
const IPAddress outIp(192,168,0,31); // esp8288
const unsigned int outPort = 9999; // remote port (not needed for receive)
const unsigned int localPort = 8000; // local port to listen for UDP packets (here's where we send the packets)
OSCErrorCode error;
unsigned int ledState = LOW; // LOW means led is *on*
//------------ END ESP and OSC setting
#ifndef BUILTIN_LED
#ifdef LED_BUILTIN
#define BUILTIN_LED LED_BUILTIN
#else
#define BUILTIN_LED 13
#endif
#endif
#include <FastLED.h>
#define NUM_LEDS 64
#define PIN_CONTROLLING_STRIP 1// esp8266//21 // 21 node 97 // 1
CRGB leds[NUM_LEDS];
//----------- END FastLed setting
//----------- Receive with start- and end-markers combined with parsing
const byte numChars = 200;
char receivedChars[numChars];
char tempChars[numChars]; // temporary array for use when parsing
//----------- variables to hold the parsed data
char messageFromPC[numChars] = {0}; //or 5 doesn't change anything
// ABOVE not USED
#define numberOfDataPerLed 3
#define numberOfLed 64
int number_of_received_packets;// = 0;
int size;
//String ledR, ledB, ledG;
int valuesOfEachLed[numberOfDataPerLed] = { 0 };
int valueOfRed[NUM_LEDS];
int valueOfGreen[NUM_LEDS];
int valueOfBlue[NUM_LEDS];
float floatFromPC = 0.0; // not used for the moment
boolean newData = false;
Serial.println("local ip"); // with node32s ip is 10.0.1.778 // to get IP adress 192.168.0.26
pinMode(BUILTIN_LED, OUTPUT);
digitalWrite(BUILTIN_LED, ledState); // turn *on* led
// Connect to WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, pass);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println("Starting UDP");
Udp.begin(localPort);
Serial.print("Local port: ");
#ifdef ESP32
Serial.print("LocalportESP32: ");
Serial.println(localPort);
#else
Serial.println(Udp.localPort());
#endif
// control LED with FastLed
FastLED.addLeds<NEOPIXEL, PIN_CONTROLLING_STRIP>(leds, NUM_LEDS);
FastLED.setBrightness(250);
for (int i = 0; i <= NUM_LEDS; i++) {
// leds[i] = CRGB ( 2*i,255-(2*i), 255-(2*i));
leds[i] = CRGB(0, 0, 0); // turn off all
FastLED.show();
Serial.println (".");
OSCMessage msg;
size = Udp.parsePacket();
if (size > 0) {
while (size--) {
msg.fill(Udp.read());
if (!msg.hasError()) {
msg.dispatch("/matrixdata",assignDataParsed); // read only 1/8 datadata and write it 1/64 ( so it light only pixel 0 0)
else {
error = msg.getError();
Serial.print("error: ");
Serial.println(error);
for (int i = 0; i < NUM_LEDS; i++) {
// leds[i] = CRGB ( valueOfRed[j],valueOfGreen[k],valueOfBlue[l]);
// leds[i] = CRGB ( valueOfRed[i],valueOfGreen[i],valueOfBlue[i]);
// leds[i] = CRGB (msg.getInt(i*3), msg.getInt(i*3+1), msg.getInt(i*3+2));
//FastLED.show();
void assignDataParsed(OSCMessage &msg) {
for (uint8_t i = 0; i < NUM_LEDS; i++) {
// for (uint8_t i = NUM_LEDS-1; i >= NUM_LEDS/2; i--) {
Serial.print (" led number "); Serial.print (i); Serial.print ("");
Serial.print ( " h"); Serial.print (msg.getInt(i*3));
Serial.print ( " r"); Serial.print (msg.getInt(i*3+1));
Serial.print ( " g"); Serial.print (msg.getInt(i*3+2));
Serial.print ( " b"); Serial.println (msg.getInt(i*3+3));
leds[i] = CRGB (msg.getInt(i*3), msg.getInt(i*3+1), msg.getInt(i*3+2)); // , msg.getInt(i*3+3)
FastLED.show();
