Hello guys ,
I am a student , currently working on a personal project , i want to establish a can bus communication between an esp-wroom-32 and a teensy 3.2. For that i used 2 mcp2551 can transceivers i have connected pins 21 on the esp for TX and pin 22 for RX. So far its a simple project , i want the teensy to send some messages and the esp to read them. However , it seems there is a problem and it fails to read them. I have done a can bus communication with the teensy and an arduino uno board (i used an mcp2515 can module for that and removed 1 transceiver as the module has one ) . I am kinda stuck on that project for the past week and i cant understand what i am doing wrong. I have also connected a 5V power supply to the transceivers , and have set the baud rate to 115200.
Here is the code for the teensy
#include <FlexCAN.h>
static CAN_message_t msg;
static CAN_message_t msg2;
pinMode(4,OUTPUT);
digitalWrite(4,HIGH);
pinMode(3,INPUT);
Can0.begin(500000);
msg.ext = 0;
msg.id = 0x010;
msg.len = 8;
msg2.ext = 0;
msg2.id = 0x080;
msg2.len = 8;
void CAN_send()
noInterrupts();
msg.buf[0] = 1;
msg.buf[1] = 54;
msg.buf[2] = 64;
msg.buf[3] = 87;
msg.buf[4] = 12;
msg.buf[5] = 35;
msg.buf[6] = 23;
msg.buf[7] = 0;
Can0.write(msg);
msg2.buf[0] = 'a';
msg2.buf[1] = 'b';
msg2.buf[2] = 'c';
msg2.buf[3] = 'd';
msg2.buf[4] = 0;
msg2.buf[5] = 1;
msg2.buf[6] = 2;
msg2.buf[7] = 3;
Can0.write(msg2);
delay(2000);
interrupts();
CAN_send();
Serial.println("Message sent ... ");
and the code for the esp to read the can messages
#include "driver/gpio.h"
#include "driver/can.h"
app_main();
// Initialize configuration structures using macro initializers
can_general_config_t g_config = CAN_GENERAL_CONFIG_DEFAULT(GPIO_NUM_21, GPIO_NUM_22, CAN_MODE_NORMAL); // 21 Tx 22 Rx
can_timing_config_t t_config = CAN_TIMING_CONFIG_1MBITS();
can_filter_config_t f_config = CAN_FILTER_CONFIG_ACCEPT_ALL();
delay(2000);
// Install CAN driver
if (can_driver_install(&g_config, &t_config, &f_config) == ESP_OK)
Serial.println("Driver installed\n");
Serial.println("Failed to install driver\n");
return;
// Start CAN driver
if (can_start() == ESP_OK)
Serial.println("Driver started\n");
Serial.println("Failed to start driver\n");
return;
can_message_t message;
if (can_receive(&message, pdMS_TO_TICKS(5000)) == ESP_OK)
Serial.println("Message received\n");
Serial.println("Failed to receive message in the last 5 seconds\n");
return;
Serial.println((String) "ID is " + message.identifier);
for (int i = 0; i < message.data_length_code; i++)
// Serial.println("Data byte %d = %d\n", i, message.data[i]);
Serial.print((String)message.data[i] + " ");
and the usefull links :
https://www.pjrc.com/store/teensy32.html
as well as the link for the library i used for teensy is the collin80' one , sorry but as a new user i cant post more than 2 links ...
