ESP WROOM 32 - digitalWrite does not work when executed in interrupt
Hello
I'm trying to use two timers to get behaviour:
Turn on pump -> Wait 5 seconds -> Turn off pump -> wait 15 seconds -> Turn on pump -> ...
#include "Pump.h"
#include "globals.h"
#include <BluetoothSerial.h>
hw_timer_t *pumpTimer = NULL; // Timer dla pompy
hw_timer_t *waitTimer = NULL; // Timer oczekiwania
const unsigned long PUMP_DURATION = 5000000;
const unsigned long WAIT_DURATION = 15000000;
bool pumpActive = false;
void IRAM_ATTR onPumpTimer()
  digitalWrite(5, HIGH);
  Serial.println("Pompa OFF");
  pumpActive = false;
  timerAlarmEnable(waitTimer);
void IRAM_ATTR onWaitTimer()
  if (!pumpActive)
    digitalWrite(5, LOW);
    Serial.println("Pompa ON");
    pumpActive = true;
    timerAlarmWrite(pumpTimer, PUMP_DURATION, false);
    timerAlarmEnable(pumpTimer);
    timerAlarmDisable(waitTimer);
   InitializeSensors();
  Pump::Initialize();
  pinMode(5, OUTPUT);
  pumpTimer = timerBegin(0, 80, true);
  waitTimer = timerBegin(1, 80, true);
  timerAttachInterrupt(pumpTimer, &onPumpTimer, true);
  timerAttachInterrupt(waitTimer, &onWaitTimer, true);
  timerAlarmWrite(waitTimer, WAIT_DURATION, true);
// int ReadMoisture()
//   int dry = 2695, wet = 1100;
//   int data = analogRead(AOUT);
//   int moistValue = map(data, dry, wet, 0, 100);
//   return moistValue;
It goes to both interrupts setting high state on pin, but it's always high, event though there is digitalWrite(5,LOW) in second interrupt. I've checked this and it works:
  digitalWrite(5,HIGH);
  delay(1000); //works fine
  digitalWrite(5,LOW);
  delay(1000)
What am I missing?
It’s not the digitalWrite() that doesn’t work in interrupt, it’s the Serial.print()
And the main problem is probably that you did not defile the variables changed in the interrupt as volatile
Changed to this but still the same.
#include "Pump.h"
volatile const unsigned long PUMP_DURATION = 5000000;
volatile const unsigned long WAIT_DURATION = 15000000;
volatile bool pumpActive = false;
  pumpActive = false;
  if (!pumpActive)
    pumpActive = true;
   //InitializeSensors();
  //Pump::Initialize();
  //Serial.begin(115200);
  pinMode(5, OUTPUT);
Hi @viperoo1500100900 ,
Welcome to the forum..
You know this might be a good chance to play with the ESP Timer..
High Resolution Timer ESP32
did a test sketch, using the timer to blink onboard led..
ESP32 Timer
might be worth a peek..
good luck.. ~q
So, do you need to enable the pumpTimer as well, would you say?
You know you could do this in the loop without any timers..
Maybe there's another reason for the complexity??
~q
Well I also would like to add sending data via Bluetooth so I guess I can't use delay() to not block ESP. I would like to just have cyclic Turn on-> wait some time-> turn off etc. Don't know if my solution is right.
It is going to be a better option?
I wouldn't use delay either..
you're duration is quite large, can easily track this using a millis timer and state machine ..
won't slow the loop down at all and no complexity..
would you like an example??
~q
Yes, please if it's not the problem. The timers I used was something I first saw and tried to use them. And I tought interrupts will be good when also bluetooth transmission is present.
ok, give me a few..
on the phone..
~q
check this..
#define PUMP_PIN 5
#define MINS  1000 * 60
unsigned long lastPump;
unsigned long intervalPump = 5 * MINS;
bool pumpOn = false;
  Serial.println("Hello, ESP32!");
  pinMode(PUMP_PIN, OUTPUT);
  CheckPump();
void CheckPump() {
  unsigned long now = millis();
  if (now - lastPump >= intervalPump) {
    lastPump = now;
    if (!pumpOn) {
      //turning pump on
      Serial.println("Pump On");
      digitalWrite(PUMP_PIN, HIGH);
      //set new interval 15 minutes..
      intervalPump = 15 * MINS;
      pumpOn = true;
      //turning pump off
      Serial.println("Pump Off");
      digitalWrite(PUMP_PIN, LOW);
      //set new interval 5 mins..
     pumpOn = false;
no timers needed..
takes 5 minutes before pump starts..
could initially set the intervalPump to 0 and it would turn on at boot..
keep your loop fast, avoid delay..
good luck.. ~q
could move it into it's own thread..
#define PUMP_PIN 5 * 1000
#define MINS  1000
  xTaskCreate( CheckPump, "Pump Task", 1000, NULL, 1, NULL);
  delay(10);
void CheckPump(void *pvParameters) {
  while (1) {
      lastPump = now;
      if (!pumpOn) {
        //turning pump on
        //turning pump off
  delay(1000);// breath some..
~q
And when I want to add sending data via Bluetooth to phone I can just put code to do that in loop()?
Or also use xTaskCreate()?
Have you ever coded in a multi-tasking environment? There's something of a learning curve.
Yes..
The first example uses the loop..
The second example is just putting the routine into its own thread..
So far as everything sits now, I would use the loop, less complex..
good luck.. ~q
