ESP01 connections client <-> server
Hello,
I have 2 ESP01 trying to communicate :
ESP1 is access point and must send info to the station
ESP2 is a station which connect to the access point
I managed to have ESP1 as server receiving from ESP2 but now I’m trying the other way.
I have simplified the code but this is not working :
Code ESP1
#include <ESP8266WiFi.h>
// Wifi Configuration
const char* ssidAP = "ESPsoftAP_01";
const char* passwordAP = "password2020";
const char* station = "192.168.1.5";
// AP Configuration
IPAddress ip(192,168,1,10);
IPAddress gateway(192,168,1,254);
IPAddress subnet(255,255,255,0);
// Set web server port number to 80
WiFiServer server(80);
  WiFi.config(ip, gateway, subnet);
  WiFi.mode(WIFI_AP_STA);
  Serial.print("Starting AP ... ");
  boolean result = WiFi.softAP(ssidAP, passwordAP);
  if(result == true)
    Serial.println("Ready !");
    server.begin();
    Serial.println("Failed!");
  //client = server.available();   // Listen for incoming clients
  WiFiClient client;
  if (client.connect(station, 80))
         Serial.println("[CONNECTED TO STATION]");
         Serial.println("[FAILED CONNECT TO STATION]");
Result :
17:40:40.326 → Starting AP … Ready !
17:40:40.326 → 192.168.1.10
17:40:40.326 → [FAILED CONNECT TO STATION]
Code ESP2 :
const char* ssid = "ESPsoftAP_01";
const char* password = "password2020";
const char* host = "192.168.1.10";
IPAddress ip(192, 168, 1, 5); //ESP static ip
IPAddress gateway(192, 168, 1, 254); //IP Address of your WiFi Router (Gateway)
IPAddress subnet(255, 255, 255, 0);  //Subnet mask
// Serial is Arduino
// Connect to AP
  WiFi.config(ip, subnet, gateway);
  WiFi.begin(ssid, password);
  WiFi.mode(WIFI_STA);
  Serial.println("[ESP CONNECTING TO AP]");
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  server.begin();
  Serial.println("[ESP CONNECTED TO AP & SERVER STARTED]");
  //WiFiClient client;
  WiFiClient client = server.available();
// Listening to connection from Server
  if (client.connected())
  {                             // If a new client connects,
    Serial.println("[NEW CLIENT ON ESP]");
Result :
…[ESP CONNECTED TO AP & SERVER STARTED]
What do I do wrong ?
