Esp01 does not connect to wifi repeater
I've made a simple code for the esp8266 where i can control an LED wirelessly via wifi.
down below is the code i am using.
#include<ESP8266WiFi.h>
const byte ledPin = 2;
const char *ssid = "ZenWifi";
const char *pass = "-------";
WiFiServer server (80);
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, LOW);
  Serial.println("connecting to ");   Serial.println(ssid);
  WiFi.begin(ssid, pass);
    Serial.write('.');
  Serial.println("connected to the wireless network !");
  digitalWrite(ledPin, HIGH);
  server.begin();
  Serial.println("Use this to connect");
  Serial.print("http://");
  Serial.print(WiFi.localIP());
  Serial.println("/");
  WiFiClient client = server.available();
  if (!client) return;
  Serial.println("handling new client");
  String request = client.readStringUntil('\r');
  while (client.available()) client.read();
  if (request.indexOf("/ON") != -1) {
    Serial.println("led on");
  } else if (request.indexOf("/OFF") != -1) {
    Serial.println("led off");
  } else Serial.println(request);
  client.println("Connection: close");
  client.println();
  delay(1);
  // close the connection:
  client.stop();
  Serial.println("client disconnected");
in this project I am using an esp01 module which i want to connect to a wifi repeater.
the following link is the wifi repeater i am using.
Amazon.com: Xiaomi Mi Wifi Extender Pro, DVB4235GL
the code uploads fine to the esp01 module but the esp01 doesn't connect to the wifi repeater.
However, when i change the code to connect to the central router instead of the wifi repeater it works.
I have double checked the ssid of the repeater several times and even the password too.
i hope someone can help me find the solution to this problem.
thank you in advance.
try to add
WiFi.persitent(false);
WiFi.disconnect();
before WiFi.begin
just tried it and it didnt fix the problem.
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project :wink: See About the Installation & Troubleshooting category.
