Hello! Greetings! and hope you are having good time!
Few days back with the help of @horace I wrote a code that worked perfectly fine on ESP32 board. Now I'm trying to get that same code working on ESP01 but ESP01 fails to do most of the tasks in the code.
The code basically does following things:
- Configures the ESP32 as soft AP
- Hosts a web server
- Controls a device connected to its GPIO (LED for now)
- has elegantOTA
- Resets SSID from the web page that is hosted on it
- But most important is it derives its password from MAC ID
now, after running it on ESP01 couple of times and trying to make some random but meaningful changes I found that I needed to correct the Pin numbers obviously so I changed it. Next thing I noticed that the SSID can't be longer than 5 characters and Password can't be longer than 9 characters. So, I made changes accordingly.
The password generation from MAC ID is something really important for me, which worked perfectly fine on ESP32 but doesn't seem to work as expected on ESP01.
Here's the code that I run on ESP32
//<script src="https://kit.fontawesome.com/6392e33924.js" crossorigin="anonymous"></script>
#ifdef ESP32
#include <WiFi.h>
#include <AsyncTCP.h>
#else
#include <ESP8266WiFi.h>
#include <ESPAsyncTCP.h>
#endif
#include <ESPAsyncWebServer.h>
#include <AsyncElegantOTA.h>
AsyncWebServer server(80);
const char* Old_ssid = "ESP32-Data-On-Tag";// This is the SSID that ESP32 will broadcast
const char* password;
char ssid[64]={0};
void Reset_SSID(char* ssid);
const char* PARAM_INPUT1 = "input1";
const char* PARAM_INPUT_1 = "output";
const char* PARAM_INPUT_2 = "state";
const char* LED_ON = "ON";
const char* LED_OFF = "OFF";
String DeviceState = "off";
byte mac[6];
String one, Two, Pass;
// HTML web page to handle 3 input fields (input1, input2, input3)
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
<title>ESP Web Server</title>
<meta name="viewport" content="width=device-width, initial-scale=1">
<link rel="icon" href="data:,">
<link rel="icon" href="https://kit.fontawesome.com/6392e33924.js" crossorigin="anonymous">
<style>
html {
font-family: Arial;
display: inline-block;
margin: 0px auto;
text-align: center;
h2 { font-size: 3.0rem; }
p { font-size: 1.0rem; }
.units { font-size: 0.8rem; }
.labels{
font-size: 1.0rem;
//vertical-align:middle;
padding-bottom: 15px;
</style>
</head>
<body>
<h2>Data On Tag</h2>
<p>
<i class="fa-solid fa-plug-circle-bolt"style="color:#059e8a;"></i>
<span class="labels">Power Consumed</span>
<span id="power">%POWER%</span>
<span class="units">Watts</span>
</p>
<script>
function toggleCheckbox(element)
var xhr = new XMLHttpRequest();
if(element.checked){ xhr.open("GET", "/update?output="+element.id+"&state=1", true); }
else { xhr.open("GET", "/update?output="+element.id+"&state=0", true); }
xhr.send();
setInterval(function ( )
var xhttp = new XMLHttpRequest();
xhttp.onreadystatechange = function()
if (this.readyState == 4 && this.status == 200)
document.getElementById("power").innerHTML = this.responseText;
xhttp.open("GET", "/power", true);
xhttp.send();
}, 3000 ) ;
</script>
<form action="/get">
New SSID: <input type="text" name="input1">
<input type="submit" value="Submit">
</form><br>
<p> %BUTTONPLACEHOLDER%</p>
<p><a href="/Device/on"><button>Turn ON</button></a></p>
<p><a href="/Device/off"><button>Turn OFF</button></a></p>
</body>
</html>
)rawliteral";
String outputState(int output){
if(digitalRead(output)){
return "checked";
else {
return "";
String PowerConsumed()
float Pow = analogRead(0);
Serial.print("Power");
Serial.println(Pow);
return String(Pow);
// Replaces placeholder with button section in your web page
String processor(const String& var)
//Serial.println(var);
if(var == "BUTTONPLACEHOLDER")
String buttons = "";
buttons += "<h4>Device Status</h4><label class=\"switch\"><input type=\"checkbox\" onchange=\"toggleCheckbox(this)\" id=\"2\" " + outputState(2) + "><span class=\"slider\"></span></label>";
return buttons;
else if(var == "POWER")
return PowerConsumed();
}return String();
void notFound(AsyncWebServerRequest *request) {
request->send(404, "text/plain", "Not found");
void setupServer(void)
// Send web page with input fields to client
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request)
Serial.print("AsyncWebServerRequest from client with IP: ");
Serial.println(request->client()->remoteIP());
request->send_P(200, "text/html", index_html, processor);
server.on("/power", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", PowerConsumed().c_str());
// Send a GET request to <ESP_IP>/get?input1=<inputMessage>
server.on("/get", HTTP_GET, [] (AsyncWebServerRequest *request)
String inputMessage;
String inputParam;
// GET input1 value on <ESP_IP>/get?input1=<inputMessage>
if (request->hasParam(PARAM_INPUT1))
inputMessage = request->getParam(PARAM_INPUT1)->value();
inputParam = PARAM_INPUT1;
Serial.println(inputMessage);
//ssid = char(inputMessage);
inputMessage.toCharArray(ssid,64);
Serial.print("New SSID is:");
Serial.println(ssid);
// Reset_SSID(ssid); // <<<<<<<<<<<<<<<<<<<<< moved into loop()
// Send a GET request to <ESP_IP>/update?output=<inputMessage1>&state=<inputMessage2>
server.on("/update", HTTP_GET, [] (AsyncWebServerRequest *request)
String inputMessage1;
String inputMessage2;
// GET input1 value on <ESP_IP>/update?output=<inputMessage1>&state=<inputMessage2>
if (request->hasParam(PARAM_INPUT_1) && request->hasParam(PARAM_INPUT_2))
inputMessage1 = request->getParam(PARAM_INPUT_1)->value();
inputMessage2 = request->getParam(PARAM_INPUT_2)->value();
digitalWrite(inputMessage1.toInt(), inputMessage2.toInt());
inputMessage1 = "No message sent";
inputMessage2 = "No message sent";
Serial.print("GPIO: ");
Serial.print(inputMessage1);
Serial.print(" - Set to: ");
Serial.println(inputMessage2);
request->send(200, "text/plain", "OK");
// Send a GET request to <ESP_IP>/Device/off
// Route to set GPIO to LOW
server.on("/Device/off", HTTP_GET, [](AsyncWebServerRequest *request)
digitalWrite(2, LOW);
// Send a GET request to <ESP_IP>/Device/on
// Route to set GPIO to HIGH
server.on("/Device/on", HTTP_GET, [](AsyncWebServerRequest *request)
digitalWrite(2, HIGH);
server.onNotFound(notFound);
// Start our ESP32 server
server.begin();
void Create_Password_SetupAP()
WiFi.begin();
Serial.println("WiFi began");
WiFi.macAddress(mac);
Serial.print("MAC: ");
Serial.print(mac[0],HEX);
Serial.print(":");
Serial.print(mac[1],HEX);
Serial.print(":");
Serial.print(mac[2],HEX);
Serial.print(":");
Serial.print(mac[3],HEX);
Serial.print(":");
Serial.print(mac[4],HEX);
Serial.print(":");
Serial.println(mac[5],HEX);
Serial.println("Creating Password from MAC ID");
int mac0 = mac[0];
int mac1 = mac[1];
one = mac0;
Two = one + mac1;
Pass = Two + "DOT";
Serial.println(Pass);
password = Pass.c_str();
Serial.print("Connecting to ");
WiFi.softAP(Old_ssid, password);
Serial.println( "" );
Serial.println( "WiFi AP is now running with Old SSID" );
Serial.println( "IP address: " );
Serial.println( WiFi.softAPIP() );
WiFi.begin();
Serial.println(Old_ssid);
// WiFi.softAP(Old_ssid, password);
WiFi.softAP(Old_ssid);
Serial.print( "WiFi AP is now running IP address: " );
Serial.println( WiFi.softAPIP() ); */
//server.end();
// delay(500);
WiFi.softAPdisconnect (true);
// WiFi.disconnect(); // **************** added
// delay(500);
Serial.print("Connecting to New SSID: ");
WiFi.softAP(ssid);//, password);
Serial.println( "WiFi AP is now running with New SSID" );
Serial.print( "IP address: " );
// server.begin();
ssid[0]=0;
pinMode(2, OUTPUT);
Serial.print("Program Start *******************************");
Create_Password_SetupAP();
setupServer();
AsyncElegantOTA.begin(&server); // Start ElegantOTA
server.begin();
Serial.println("Server started");
static long startTime = millis(), heap=0, freeHeap=0, stations=0, newStations=0;
freeHeap=ESP.getFreeHeap();
if((millis()-startTime>30000) && (heap != freeHeap)) {
startTime=millis();
Serial.print("Free heap ");
Serial.println(heap=freeHeap);
newStations= WiFi.softAPgetStationNum();
if(stations != newStations){
Serial.print("Connected stations ");
Serial.println(stations=newStations);
if(Serial.available()) {
Serial.readBytesUntil('\n', ssid, 64);
Reset_SSID(ssid);
stations=0;
if(ssid[0]!=0)
Reset_SSID(ssid);
and here's the code that's current;y running on ESP01. Which controls the LED and also shows the OTA webpage (I haven't tested it yet) but so far controlling the LED works fine. But not the password generation thing. Here's the code:
#define RELAYPIN 2
byte mac[6];
<head>
<style>
html {
font-family: Arial;
margin: 0px auto;
text-align: center;
.labels{
font-size: 1.0rem;
</style>
</head>
<body>
<p>
</p>
<script>
xhr.send();
xhttp.send();
}, 3000 ) ;
</script>
</form><br>
</body>
</html>
)rawliteral";
return "checked";
else {
return "";
return buttons;
String inputParam;
digitalWrite(RELAYPIN, LOW);
//detachInterrupt(CF_PIN);
digitalWrite(RELAYPIN, HIGH);
//attachInterrupt(CF_PIN, ISR, RISING);
server.begin();
WiFi.begin();
Serial.print(":");
Serial.print(":");
Serial.print(":");
Serial.print(":");
Serial.print(":");
int mac0 = (mac[1],HEX);
int mac1 = mac[2];
one = mac0;
Serial.print("First:");
Serial.println(one);
Two = one + mac1;
Serial.print("Second:");
Serial.println(Two);
Pass = one + "DOT";
Serial.print("Setting soft-AP ... ");
boolean result = WiFi.softAP("DOT01", "12345678T");
if(result == true)
Serial.println("Ready");
Serial.println("Failed!");
pinMode(RELAYPIN, OUTPUT);
setupServer();
server.begin();
Serial.printf("Stations connected = %d\n", WiFi.softAPgetStationNum());
startTime=millis();
//PowerCalc();
delay(3000);
what I'm missing here?
Thanks in advance
