While below program is uploaded to Arduino Atmel everything works well, have +/-2 measurements from accelerometer. When the same one is uploaded to Lolin wifi esp8266 nodemcu v3 (ESP12-E) the output is very different. Has no negative values and some of the axis jumps sudenly to 255. What is the difference here?
#include <Wire.h> // Wire library - used for I2C communication
int ADXL345 = 0x53; // The ADXL345 sensor I2C address
float X_out, Y_out, Z_out; // Outputs
Serial.begin(115200); // Initiate serial communication for printing the results on the Serial monitor
Wire.begin(); // Initiate the Wire library
// Set ADXL345 in measuring mode
Wire.beginTransmission(ADXL345); // Start communicating with the device
Wire.write(0x2D); // Access/ talk to POWER_CTL Register - 0x2D
// Enable measurement
Wire.write(8); // (8dec -> 0000 1000 binary) Bit D3 High for measuring enable
Wire.endTransmission();
delay(10);
// === Read acceleromter data === //
Wire.write(0x32); // Start with register 0x32 (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(ADXL345, 6, true); // Read 6 registers total, each axis value is stored in 2 registers
X_out = ( Wire.read()| Wire.read() << 8); // X-axis value
X_out = X_out/256; //For a range of +-2g, we need to divide the raw values by 256, according to the datasheet
Y_out = ( Wire.read()| Wire.read() << 8); // Y-axis value
Y_out = Y_out/256;
Z_out = ( Wire.read()| Wire.read() << 8); // Z-axis value
Z_out = Z_out/256;
Serial.print("Xa= ");
Serial.print(X_out);
Serial.print(" Ya= ");
Serial.print(Y_out);
Serial.print(" Za= ");
Serial.println(Z_out);
delay(10);
Multiplying the result by 255 is not going to give the scaled readings but multiplying the result by the scale factor will give a proper result.
void fReadAccelerometers()
int16_t temp = 0;
// read status register
fReadSPIdata16bits( hAG, STATUS_REG );
// is new accel data available
if ( GetHighBits() & AccelerometerDataReady )
fReadSPIdata16bits( hAG, LSM9DS1_REGISTER_OUT_X_L_XL ); // read x accel
temp = GetHighBits(); temp <<= 8; temp |= GetLowBits();
aX = (float)temp;
aX = (aX * _accel_mg_lsb) - aXbias;
temp = 0;
fReadSPIdata16bits( hAG, LSM9DS1_REGISTER_OUT_Y_L_XL ); // read Y accel
aY = (float)temp;
aY = (aY * _accel_mg_lsb) - aYbias;
temp = 0;
fReadSPIdata16bits( hAG, LSM9DS1_REGISTER_OUT_Z_L_XL ); // read z accel
aZ = (float)temp;
aZ = (aZ * _accel_mg_lsb) - aZbias;
That is the code of reading the accelerometer data, converting the 2 8 bits into one 16 bit, note how temp is declared as a int16_t and not a uint16_t. then multiplying the result by the scale factor, _accel_mg_lsb. Also, GetHighBits() is a int8_t and not a uint8_t
Well of course I have the same datasheet You are referring to. Your code seems to be for SPI connection (?), I'm using I2C but case with 2x8 bits data for single axis seems to be right I guess. I will investigate this as I'm pretty beginner
