I stared using ESP12 (both -E and -F) early in February 2017. After many weeks of pain needed to understand the specifics of this chip (power, capacitors, pins, brand of the USB-Serial adapter, etc.) I finally managed to upload some sketches made in Arduino IDE and I developed some applications for my personal use. I remember all those chips, out-of-the box presented the so-called AT firmware. In addition, after a while, I managed to successfully update the basic firmware from 1.5.0 to 2.0.0 and my Arduino-like sketches continue to work. To upload, I used both the Espressif GUI tool that the esptool.py on Windows or Linux. I think I also learned the meaning of NONOS/OS and OTA/no OTA and I can say I need NONOS and no OTA!
Those 4 chips of my first lots (2 ESP12E and 2 ESP12F), had a small, round, AI logo on top as well as the "Vendor: Ai-Thinker" statement:
Now I bought 4 ESP12-F. There is no AI logo or Vendor: Ai-Thinker statement on them, just: "WiFi ESP-12F / ESP8266MOD / FC / ISM 2.4Ghz / PA +25 dBm / 802.11 b/g/n":
At power on, on the serial port I see some messages at 74880 (normal):
oad 0x3ffe8000, len 776, room 8
tail 0
chksum 0x02
load 0x3ffe8310, len 552, room 8
tail 0
chksum 0x79
csum 0x79
2nd boot version : 1.5
SPI Speed : 40MHz
SPI Mode : DIO
SPI Flash Size & Map: 32Mbit(512KB+512KB)
jump to run user1 @ 1000
rf cal sector: 1017
rf[112] : 00
rf[113] : 00
rf[114] : 01
SDK ver: 1.5.4.1(39cb9a32) compiled @ Jul 1 2016 20:04:35
phy ver: 972, pp ver: 10.1
Followed by some lines at 115200 (normal too):
Ai-Thinker Technology Co. Ltd.
ready
At this point, I tried to enter "AT", not only at 115200 but also 9600, 56400, 74880 with no result. Ok, I assumed the AT firmware is not present, no problem. I uploaded a simple and working Arduino-like sketch and I started to get all sort of errors, some at 74880 and some at 115200: huge pages of dump and messages:
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
v3de0c112
~ld
system param error
--- dump follows ---
and:
Exception (0):
epc1=0x4022cc40 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: sys
sp: 3ffff7d0 end: 3fffffb0 offset: 01a0
>>>stack>>>
3ffff970: 4022cc40 00000138 00000177 4022cc29
Of course, my firts approach was to upload the 4 firmware files I used in the former chips: no success! Even if upload works fine and verify_flash reports OK, they look "incompatible" for these new chips.
Here starts my real confusion: I don't really know what the 4 (well ... 3) modules are. Save for blank.bin that, I assume, is used to clear some locations, eagle.flash.bin, eagle.irom0text.bin and esp_init_data_default.bin are totally mysterious to me!
After days, I concluded that:
blank.bin: used to clear locations.
esp_init_data_default.bin: reported as "optional", basic configuration?
eagle.flash.bin: the location to upload is 0x000, i.e. the same location where user sketches are loaded, so have I to assume this is the AT firmware?
And, at that point, can I replace it with MY sketch binary?
eagle.irom0text.bin: total mystery! Is that the basic ESP formware, i.e. what handles WiFi, IP, TCP, ect?
I also thoroughly read Pieter P's "A Beginner's Guide to the ESP8266" but I didn't find anything about ESP firmware.
Can someone clarify:
-What are the rules of the 4 modules?
-What is linked together with my sketch and uploaded to the chip?
In other words, in a NONOS/no OTA environment, is there anyway a sort of "resident" firmware or - in theory - is the product of the compile/link of my sketch enoght to handle a totally empty ESP?
My last attemt was to fill 4M with FF and then upload my sketch's .bin file. After each upload, I verify_flash and I see it is ok. But the messge on serial is:
tail 8
chksum 0xef
csum 0xef
csum err
ets_main.c
It is also confusing "chksum" and "csum" (I assume stored checksum and computed checksum) are the same but "csum err" is shown!
