Hello all.
I have an problem with the code of mine ESP12F
Ihave an code that is working (without an button)
tis is my working code:
Wifi for screens
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
MDNSResponder mdns;
// Replace with your network credentials
const char* ssid = "XXXXXXX";
const char* password = "XXXXXXX";
// Update these with values suitable for your network.
IPAddress ip(192,168,192,128); //Node static IP
IPAddress gateway(192,168,192,1);
IPAddress subnet(255,255,255,0);
ESP8266WebServer server(80);
String webPage = "";
int gpio4_pin = 4; // screen 1 OPEN
int gpio5_pin = 5; // screen 1 close
int gpio12_pin = 12; // screen 2 OPEN
int gpio13_pin = 13; // screen 2 close
void setup(void){
webPage += "<p>Socket #1 <a href=\"socket1On\"><button>ON</button></a> <a href=\"socket1Stop\"><button>STOP</button></a> <a href=\"socket1Off\"><button>OFF</button></a></p>";
webPage += "<p>Socket #2 <a href=\"socket2On\"><button>ON</button></a> <a href=\"socket2Stop\"><button>STOP</button></a> <a href=\"socket2Off\"><button>OFF</button></a></p>";
// preparing GPIOs
pinMode(gpio4_pin, OUTPUT);
digitalWrite(gpio4_pin, LOW);
pinMode(gpio5_pin, OUTPUT);
digitalWrite(gpio5_pin, LOW);
pinMode(gpio12_pin, OUTPUT);
digitalWrite(gpio12_pin, LOW);
pinMode(gpio13_pin, OUTPUT);
digitalWrite(gpio13_pin, LOW);
WiFi.begin(ssid, password);
WiFi.config(ip, gateway, subnet);
// Wait for connection
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
if (mdns.begin("esp8266", WiFi.localIP())) {
Serial.println("MDNS responder started");
server.on("/", [](){
server.send(200, "text/html", webPage);
//screen control 1//
//screen OPEN
server.on("/socket1On", [](){
digitalWrite(gpio4_pin, HIGH);
//screen closed
server.on("/socket1Off", [](){
digitalWrite(gpio5_pin, HIGH);
//screen STOP
server.on("/socket1Stop", [](){
//screen controll 2//
//screen OPEN
server.on("/socket2On", [](){
digitalWrite(gpio12_pin, HIGH);
//screen closed
server.on("/socket2Off", [](){
digitalWrite(gpio13_pin, HIGH);
//screen STOP
server.on("/socket2Stop", [](){
server.begin();
Serial.println("HTTP server started");
void loop(void){
server.handleClient();
now i want to add buttons so that i can turn on and off my output from the webpage and also manual with buttons
this is the code i tried:
Wifi voor de rolluiken
MDNSResponder mdns;
const char* ssid = "xxxxxxxxx";
const char* password = "xxxxxxxx";
int gpio5_pin = 5; // screen 1 closed
int gpio13_pin = 13; // screen 2 closed
const int gpio9_pin = 9; // screen 1 manual open
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
void setup(void){
// preparing GPIOs
//screen manual
pinMode(gpio9_pin, INPUT);
Serial.print(".");
Serial.println("");
//screen OPEN
//screen closed
//screen STOP
//screen control 2//
//screen OPEN
//screen closed
//screen STOP
server.begin();
void loop(void){
// read the state of the pushbutton value:
buttonState = digitalRead(gpio9_pin);
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (buttonState == HIGH) {
// turn LED5 on AND4 OFF:
this is what i triet to add:
const int gpio9_pin = 9; // screen 1 manual(with button) open
//manual button
// turn pin5 on AND4 OFF:
what i want is:
this code is an wifi webserver that can control 4 outputs to open and close 2 screens.
each screen needs 2 outputs 1 high and 1 low for open.
1 open and 1 high for close.
and 2 low for stop.
now i want to first one butten if it worksi want to add 4 buttens to open and close the screens.
so the buttons needs to de the same as the button on de webserver (1 output low and 1 high)
i hope that someone can help me
thanx
