Hi everybody,
I write here because I'm quite desperate and i don't know what to do, I'm looking for the solution but I cannot, let me comment:
I've built a pcb to control an intercom ( read buzzer and open door ), to do that I've used a esp12f with a relay, a transistor and optocoupler with all their resistors to work correctly.
I've connected ESP12F to arduino ide and download my code without problems, outputs work fine and everything looks work fine but the most important thing doesn't work WIFI.
I've checked it out several sketches like wificlient, or scannetwork and when I look it by serial monitor is looking for a network but it does't find anyone, I tried to create wifi hotspot in my mobile but I think it is not wifi signal problem, I think it is something in esp12f, In my code I've used WIFI.mode(WIFI_STA), or changed arduino parameters to higher bandwidth but nothing work.
Could you help me to find where I'm wrong? I have no idea what to check now.
I attach a hardware connections to esp12f, maybe there is something wrong?
this is the library sketch to look for wifi networks
#include "WiFiEsp.h"
// Emulate Serial1 on pins 6/7 if not present
#ifndef HAVE_HWSERIAL1
#include "SoftwareSerial.h"
//SoftwareSerial Serial1(6, 7); // RX, TX
#endif
// initialize serial for debugging
// initialize serial for ESP module
Serial1.begin(9600);
// initialize ESP module
WiFi.init(&Serial1);
// check for the presence of the shield
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue
while (true);
// Print WiFi MAC address
printMacAddress();
// scan for existing networks
Serial.println("Scanning available networks...");
listNetworks();
delay(10000);
void printMacAddress()
// get your MAC address
byte mac[6];
WiFi.macAddress(mac);
// print MAC address
char buf[20];
sprintf(buf, "%02X:%02X:%02X:%02X:%02X:%02X", mac[5], mac[4], mac[3], mac[2], mac[1], mac[0]);
Serial.print("MAC address: ");
Serial.println(buf);
void listNetworks()
// scan for nearby networks
int numSsid = WiFi.scanNetworks();
if (numSsid == -1) {
Serial.println("Couldn't get a wifi connection");
while (true);
// print the list of networks seen
Serial.print("Number of available networks:");
Serial.println(numSsid);
// print the network number and name for each network found
for (int thisNet = 0; thisNet < numSsid; thisNet++) {
Serial.print(thisNet);
Serial.print(") ");
Serial.print(WiFi.SSID(thisNet));
Serial.print("\tSignal: ");
Serial.print(WiFi.RSSI(thisNet));
Serial.print(" dBm");
Serial.print("\tEncryption: ");
printEncryptionType(WiFi.encryptionType(thisNet));
void printEncryptionType(int thisType) {
// read the encryption type and print out the name
switch (thisType) {
case ENC_TYPE_WEP:
Serial.print("WEP");
case ENC_TYPE_WPA_PSK:
Serial.print("WPA_PSK");
case ENC_TYPE_WPA2_PSK:
Serial.print("WPA2_PSK");
case ENC_TYPE_WPA_WPA2_PSK:
Serial.print("WPA_WPA2_PSK");
case ENC_TYPE_NONE:
Serial.print("None");
