ESP13 Shield by Doit ... is there a schematic for this ?? Anywhere ??
I am using this shield as Generic ESP8266 Module and its working too(!)
However i want to use the on board Blue LED to signal a successful connection to a WiFi network. And for this i need to know to which pin of the ESP13 chip its connected.
Normally manufacturers make something called a schematic - you know the one that shows what is connected where :slight_smile: For some odd reason the Doctors Of Intelligence who made this board never thought its required...
Can anyone help to locate the schematic ? Or atleast let me know to which pin is the blue LED connected. ( Of course i can use a multimeter and check continuity but am afraid of screwing up the module by injecting voltage into its pins..
DoIt ESP
@juraj
Unfortunately that document which you linked does not have any schematic though its supposed to be a user manual.
I know. It is writen like if the doit firmware was the only option. If you want use it otherwise it's hacking and they don't want to help you with it.
Juraj:
Ok figured it out - the Blue LED on the shield is connected to GPIO16 and its active-low mode.
That's a revolutionary line of thinking - give a schematic and people will immediately start hacking it !! :slight_smile:
Anyway that Shield is now fully functional with a AT Firmware and sitting on a top of a UNO is connected to the Blynk App and tells me the power status and water tank level status at home. I really love that Shield - it provides access to all pins of the Arduino and Uno.
