ESP201 stops working after some time and falls into a reboot routine
The ESP201 can run for a few minutes to several hours and then no longer connects to Wi-Fi if I trust the serial monitor. To finally fall into a reboot routine. Sometimes it is not possible to contact the USB input port. What is strange is that I have a few that work very well and have done so for a long time. But they do not come from the same lot, from the same order. Is it possible that it is a bad batch of ESP201.
Here is my code:
      Template for static IP,MQTT &DeepSleep
        Read out a DHT11
https://arduinodiy.wordpress.com/2020/01/23/very-deep-sleep-part-3-mqtt/
long SLEEPTIME = 60e6; //1min
const char* WLAN_SSID = "xxx";
const char* WLAN_PASSWD = "xxx";
#include <ESP8266WiFi.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <PubSubClient.h>
#include <Wire.h>
#include "DFRobot_SHT20.h"
// We make a structure to store connection information
// The ESP8266 RTC memory is arranged into blocks of 4 bytes. The access methods read and write 4 bytes at a time,
// so the RTC data structure should be padded to a 4-byte multiple.
struct {
  uint32_t crc32;   // 4 bytes
  uint8_t channel;  // 1 byte,   5 in total
  uint8_t ap_mac[6];// 6 bytes, 11 in total
  uint8_t padding;  // 1 byte,  12 in total
} rtcData;
IPAddress ip(192, 168, 0, 202); // pick your own IP outside the DHCP range of your router
IPAddress gateway(192, 168, 0, 1); //watch out, these are comma's not dots
IPAddress subnet(255, 255, 255, 0);
IPAddress dns(207, 164, 234, 129);
//---------voor pubsub
WiFiClient espClient;
PubSubClient client(espClient);
//---------Other------
String naam = (__FILE__);     // filenaam
//unsigned int batt;
ADC_MODE(ADC_VCC); // vcc uitlezen.
//--------DHT11------
//float  humid_hok;
//float temp_hok;
/*#include <DHT.h>
#define DHTTYPE  DHT11
#define DHTPIN 2 // D4
DHT dht(DHTPIN, DHTTYPE, 11);*/ //
  DFRobot_SHT20    sht20;
  int pinOut = 10;
  float humd;
  float temp;
  float batt;
  pinMode(pinOut, OUTPUT);
  // we disable WiFi, coming from DeepSleep, as we do not need it right away
  WiFi.mode( WIFI_OFF );
  WiFi.forceSleepBegin();
  delay( 1 );
  Serial.println("wifi uit");
  // Try to read WiFi settings from RTC memory
  bool rtcValid = false;
  if ( ESP.rtcUserMemoryRead( 0, (uint32_t*)&rtcData, sizeof( rtcData ) ) ) {
    // Calculate the CRC of what we just read from RTC memory, but skip the first 4 bytes as that's the checksum itself.
    uint32_t crc = calculateCRC32( ((uint8_t*)&rtcData) + 4, sizeof( rtcData ) - 4 );
    if ( crc == rtcData.crc32 ) {
      rtcValid = true;
  //now do stuff
  Serial.println("do stuff");
  //strip naam
  //strip path van filenaam
  byte p1 = naam.lastIndexOf('\\');
  byte p2 = naam.lastIndexOf('.');
  naam = naam.substring(p1 + 1, p2);
  batt = ESP.getVcc();
  Serial.println(batt/1023.0F);
  batt = batt/1023.0F;
  Serial.print("Sketch name ");
  Serial.println(naam);
  Serial.print("Battery Voltage ");
   Serial.println(batt);
  digitalWrite(pinOut, HIGH);
    delay(50);
    sht20.initSHT20();                                  // Init SHT20 Sensor
    delay(100);
    sht20.checkSHT20();                                // Check SHT20 Sensor
    humd = sht20.readHumidity();                  // Read Humidity
    temp = sht20.readTemperature();
    digitalWrite(pinOut, LOW);
  // Read Temperature
  Serial.print("Time:");
  Serial.print(millis());
  Serial.print(" Temperature:");
  Serial.print(temp, 1);
  Serial.print("C");
  Serial.print(" Humidity:");
  Serial.print(humd, 1);
  Serial.print("%");
  // Start connection WiFi
  //Switch Radio back On
  WiFi.forceSleepWake();
  delay( 1 );
  // Disable the WiFi persistence.  The ESP8266 will not load and save WiFi settings unnecessarily in the flash memory.
  WiFi.persistent( false );
 Serial.println("Start WiFi");
  // Bring up the WiFi connection
  WiFi.mode( WIFI_STA );
  WiFi.config( ip, dns, gateway, subnet );
  //-----------Now we replace the normally used "WiFi.begin();" with a precedure using connection data stored by us
  if ( rtcValid ) {
    // The RTC data was good, make a quick connection
    WiFi.begin( WLAN_SSID, WLAN_PASSWD, rtcData.channel, rtcData.ap_mac, true );
  else {
    // The RTC data was not valid, so make a regular connection
    WiFi.begin( WLAN_SSID, WLAN_PASSWD );
  //WiFi.begin( WLAN_SSID, WLAN_PASSWD );
  //------now wait for connection
  int retries = 0;
  int wifiStatus = WiFi.status();
  while ( wifiStatus != WL_CONNECTED ) {
    retries++;
    if ( retries == 100 ) {
      // Quick connect is not working, reset WiFi and try regular connection
      WiFi.disconnect();
      delay( 10 );
      delay( 10 );
      delay( 10 );
    if ( retries == 600 ) {
      // Giving up after 30 seconds and going back to sleep
      WiFi.disconnect( true );
      delay( 1 );
      ESP.deepSleep( SLEEPTIME, WAKE_RF_DISABLED );
      return; // Not expecting this to be called, the previous call will never return.
    delay( 50 );
  Serial.println(" WiFi connected");
  Serial.println("IP address: ");
  // Write current connection info back to RTC
  rtcData.channel = WiFi.channel();
  memcpy( rtcData.ap_mac, WiFi.BSSID(), 6 ); // Copy 6 bytes of BSSID (AP's MAC address)
  rtcData.crc32 = calculateCRC32( ((uint8_t*)&rtcData) + 4, sizeof( rtcData ) - 4 );
  ESP.rtcUserMemoryWrite( 0, (uint32_t*)&rtcData, sizeof( rtcData ) );
  //---------As we are connected to WiFi, begin MQTT connection
  client.setServer("192.168.0.101", 1883); //your MQTT server's IP.Mind you, these are separated by dots again
  //client.setCallback(callback);
//-------Here is where you send data
Serial.println("Start Sending data");
  sendMQTTmessage();
  /* Close WiFi connection */
  //client.stop();
  //----and go to back to sleep
Serial.println("Go back to sleep");
  delay( 1 );
  // WAKE_RF_DISABLED to keep the WiFi radio disabled when we wake up
void sendMQTTmessage()
  if (!client.connected()) {
    reconnect();
  static char hygroBatt[7];
     dtostrf(batt, 6, 2, hygroBatt);
     static char hygroTemp[7];
     dtostrf(temp, 6, 2, hygroTemp);
    static char hygroHumi[7];
    dtostrf(humd, 6, 2, hygroHumi);
//client.publish("home/sleep/tele/naam", naam.c_str(), false);
  //client.publish("home/sleep/batt3", String(batt / 1023.0F).c_str(), false);
 // client.publish("home/main/esp3/temp3",String(sht20.readTemperature()).c_str(),false);//alternatively: read the sensor when wifi off
 // client.publish("home/main/esp3/humidity3",String(sht20.readHumidity()).c_str(),false);
  client.publish("home/main/esp2/temp2", hygroTemp);
  client.publish("home/main/esp2/humidity2", hygroHumi);
  client.publish("home/sleep/batt2",hygroBatt);
  /* Close MQTT client cleanly */
  client.disconnect();
void reconnect() {
  while (!client.connected())
    String ClientId = "ESP8266";
    ClientId += String(random(0xffff), HEX);
    if (client.connect(ClientId.c_str()))
      //if your MQTT server is protected with a password, use the next line instead of the revious
      //if (client.connect(ClientId.c_str()),mqtt_user,mqtt_password))
      Serial.print("Connected");
      client.publish("home/hok/stat/connection", "OK");
      Serial.print("failed, rc= ");
      Serial.print(client.state());
// the CRC routine
uint32_t calculateCRC32( const uint8_t *data, size_t length ) {
  uint32_t crc = 0xffffffff;
  while ( length-- ) {
    uint8_t c = *data++;
    for ( uint32_t i = 0x80; i > 0; i >>= 1 ) {
      bool bit = crc & 0x80000000;
      if ( c & i ) {
        bit = !bit;
      crc <<= 1;
      if ( bit ) {
        crc ^= 0x04c11db7;
  return crc;
Anyone have any idea what the problem is or have experienced something similar? thank you.
Can you post a schematic, not a frizzy think with links showing technical data for the external hardware. Be sure to show all connections, power and ground.
Interesting. I never heard of esp201 before.
What USB port? The esp201 I posted above doesn't have one. Is that the correct board?
I made the connection via FTDI232 to read the sérial monitor and programming the ESP201.
The standard DeepSleep connections. I test them without other load.esp-201 Wire up - Everything ESP8266
I have problems with this statement: "standard DeepSleep connections."
Other than discussions on REM sleep I found this, is this correct?
