ESP28226 LED Ping
Here is code from my latest project using a NodeMcu ESP28226 and a WS28112 LED strip to indicate the Ping speed from a website. The LED strip is connected to the D4 pin on the NodeMcu board. The LEds powered from a 5V supply and the NodeMcu has a Step-Down Power Supply Buck Module to feed it 3.7V.
#include <ESP8266WiFi.h>
#include <ESP8266Ping.h>
#define PIN 2
#define NUM_PIXELS 23
// Put the WIF information on the next lines
const char* ssid     = "Nhat Binh";
const char* password = "binh12345";
Adafruit_NeoPixel strip = Adafruit_NeoPixel(23, PIN, NEO_GRB + NEO_KHZ800);
//The next line is the ip address to ping..note that the numbers are seperated by commas and
// not a dot!
const IPAddress remote_ip(149,210,160,107);
// 149,210,160,107
// 72,52,4,122 slow 171ms slow
// 8,8,8,8 fast
//   212,58,244,23 no 8,8,8,1 route
  strip.begin();
  strip.show(); // Initialize all pixels to 'off
  delay(10);
  // We start by connecting to a WiFi network
  Serial.println("Connecting to WiFi");
  WiFi.begin(ssid, password);
    delay(100);
    Serial.print(".");
  Serial.print("WiFi connected with ip ");
  Serial.print("Pinging ip ");
  Serial.println(remote_ip);
  bool ret = Ping.ping(remote_ip);
  int avg_time_ms = Ping.averageTime();
  Serial.println(avg_time_ms);
  Serial.println(" ms  ");
  if (avg_time_ms >=1 && avg_time_ms <= 50){
    knightRider(1, 32, 4, 0x00FF00); // Cycles, Speed, Width, RGB Color (green)
  else if ( avg_time_ms  >=50 && avg_time_ms <= 350){
    knightRider(1, 64, 8, 0xFFFF00); // Cycles, Speed, Width, RGB Color (yellow)
  else if ( avg_time_ms = 0){
    knightRider(1, 150, 16, 0xFF0000); // Cycles, Speed, Width, RGB Color (red)
  clearStrip();
  delay(10);
// Cycles - one cycle is scanning through all pixels left then right (or right then left)
// Speed - how fast one cycle is (32 with 16 pixels is default KnightRider speed)
// Width - how wide the trail effect is on the fading out LEDs.  The original display used
//         light bulbs, so they have a persistance when turning off.  This creates a trail.
//         Effective range is 2 - 8, 4 is default for 16 pixels.  Play with this.
// Color - 32-bit packed RGB color value.  All pixels will be this color.
// knightRider(cycles, speed, width, color);
void knightRider(uint16_t cycles, uint16_t speed, uint8_t width, uint32_t color) {
  uint32_t old_val[NUM_PIXELS]; // up to 256 lights!
  // Larson time baby!
  for(int i = 0; i < cycles; i++){
    for (int count = 1; count<NUM_PIXELS; count++) {
      strip.setPixelColor(count, color);
      old_val[count] = color;
      for(int x = count; x>0; x--) {
        old_val[x-1] = dimColor(old_val[x-1], width);
        strip.setPixelColor(x-1, old_val[x-1]);
      strip.show();
      delay(speed);
    for (int count = NUM_PIXELS-1; count>=0; count--) {
      for(int x = count; x<=NUM_PIXELS ;x++) {
        strip.setPixelColor(x+1, old_val[x+1]);
      strip.show();
      delay(speed);
void clearStrip() {
  for( int i = 0; i<NUM_PIXELS; i++){
    strip.setPixelColor(i, 0x000000); strip.show();
uint32_t dimColor(uint32_t color, uint8_t width) {
   return (((color&0xFF0000)/width)&0xFF0000) + (((color&0x00FF00)/width)&0x00FF00) + (((color&0x0000FF)/width)&0x0000FF);
