Hi guys, I've been attempting at reading from a POST request via an API using ESP32 Wrover.
But after each read, the chip reboots.
Here's the error message:
abort() was called at PC 0x4016512a on core 1
Backtrace: 0x400838bd:0x3ffb2080 0x4008efc9:0x3ffb20a0 0x40094341:0x3ffb20c0 0x4016512a:0x3ffb2140 0x400d2d62:0x3ffb21e0 0x400d2e2d:0x3ffb2250 0x400e8e59:0x3ffb2290
ELF file SHA256: b1c15bf399b45d38
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13964
load:0x40080400,len:3600
entry 0x400805f0
Here's the code:
#include <WiFiManager.h>
#include <string.h>
#include <WiFiClient.h>
//#include <time.h>
#include <stdlib.h>
#include <ArduinoJson.h>
#include <HTTPClient.h>
String response;
void init_WiFi() {
WiFi.mode(WIFI_STA); // explicitly set mode, esp defaults to STA+AP
// it is a good practice to make sure your code sets wifi mode how you want it.
//WiFiManager, Local intialization. Once its business is done, there is no need to keep it around
WiFiManager wm;
// reset settings - wipe stored credentials for testing
// these are stored by the esp library
//wm.resetSettings();
// Automatically connect using saved credentials,
// if connection fails, it starts an access point with the specified name ( "AutoConnectAP"),
// if empty will auto generate SSID, if password is blank it will be anonymous AP (wm.autoConnect())
// then goes into a blocking loop awaiting configuration and will return success result
bool res;
// res = wm.autoConnect(); // auto generated AP name from chipid
// res = wm.autoConnect("AutoConnectAP"); // anonymous ap
res = wm.autoConnect("Vortex", "123"); // password protected ap
if (!res) {
Serial.println("Failed to connect");
// ESP.restart();
//if you get here you have connected to the WiFi
Serial.print("Connected to: ");
Serial.println(WiFi.SSID());
Serial.println("connected...yeey :)");
HTTPClient http;
// Define the JSON body
String jsonBody =
"\"Inputs\": {"
"\"WebServiceInput0\": ["
"\"symboling\": 3,"
"\"normalized-losses\": 1.0,"
"\"make\": \"alfa-romero\","
"\"fuel-type\": \"gas\","
"\"aspiration\": \"std\","
"\"num-of-doors\": \"two\","
"\"body-style\": \"convertible\","
"\"drive-wheels\": \"rwd\","
"\"engine-location\": \"front\","
"\"wheel-base\": 88.6,"
"\"length\": 168.8,"
"\"width\": 64.1,"
"\"height\": 48.8,"
"\"curb-weight\": 2548,"
"\"engine-type\": \"dohc\","
"\"num-of-cylinders\": \"four\","
"\"engine-size\": 130,"
"\"fuel-system\": \"mpfi\","
"\"bore\": 3.47,"
"\"stroke\": 2.68,"
"\"compression-ratio\": 9,"
"\"horsepower\": 111,"
"\"peak-rpm\": 5000,"
"\"city-mpg\": 21,"
"\"highway-mpg\": 27"
"\"GlobalParameters\": {}"
String API_Read() {
Serial.println("Log: API reading..");
String serverPath = "(redacted)/score";
http.begin(serverPath);
// Set the header
String Auth = "(redacted)";
http.addHeader("Authorization", "Bearer " + Auth);
http.addHeader("Content-Type", "application/json");
// Send the HTTP POST request
int httpResponseCode = http.POST(jsonBody);
if (httpResponseCode > 0) {
Serial.print("HTTP Response code: ");
Serial.println(httpResponseCode);
String payload = http.getString();
Serial.println("Log: Response: " + payload);
Serial.println("Log: Data successfully retrieved.");
//delay(5000);
yield();
Serial.print("Error code: ");
// Free resources
http.end();
Serial.println("Log: Http request end.");
//delay(5000);
yield();
Here's the main code:
#include "WiFiManager.h"
#define Indicator 2
init_WiFi();
Serial.println(API_Read());
delay(5000);
Can anyone point out any mistakes in my handling?
Thanks.
Vizier87
