ESP32 - Access Point problem
Hello
I'm testing communication between an application and ESP32 through an access point. It's pretty basic, just for studying.
#include <WiFi.h> //Inclui a biblioteca
const char* ssid = "ESP32-AP";
const char* pass = "12345678";
WiFiServer sv(80);
int LED_Pin = 2;
  pinMode(LED_Pin, OUTPUT);
  WiFi.softAP(ssid, pass);
  Serial.print("Se conectando a: ");
  Serial.println(ssid);
  IPAddress ip = WiFi.softAPIP();
  Serial.print("Endereço de IP: ");
  Serial.println(ip);
  sv.begin();
  Serial.println("Servidor online");
  WiFiClient client = sv.available();
  if (client) {
    String line = "";
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        if (c == '\n') {
          if (line.length() == 0) {
            line = "";
        } else if (c != '\r') {
          line += c;
        if (line.indexOf("LEDON") > 0) {
          digitalWrite(LED_Pin, HIGH);
          client.println("Ligado");
        if (line.indexOf("LEDOFF") > 0) {
          digitalWrite(LED_Pin, LOW);
          client.println("Desligado");
    client.stop();
I manage to send data from the app to the ESP32 and it turns an LED on and off. But I am not able to send data to the application and I would like to know if the problem is in the Arduino code. As I understand it, just the command "client.println". Got it correctly? Is there a better way to send data from ESP32 to devices that have connected to it?
Thank you!
What does "the app" do with text it receives from the server?
have a look at ESP32 Web Server using Server-Sent Events
