Esp32 acs 712 5a
can anyone provide the code for acs712 5a esp 32
  analogReadResolution(10);
  int adc = analogRead(32);
  float voltage = adc * 3.3 / 0.805;
  float current = (voltage - 1.60) / 1096;
  if (current < 0.16) {
    current = 0;
  Serial.print("Current : ");
  Serial.println(current);
  delay(300);
this code gives incorrect value
  float current = float(abs(analogRead(32) - 512)) / 102.4; //Ampere. 5A max.
  //if (current < 0.16)current = 0;
  Serial.println(current,3);
  delay(300);
when no load is connected its showing
15:50:28.624 -> Current : 1.416
show schematic. i think you power module with 5v and try to read on 3v input.
acs712 siganl pin is connected to D35
acs 712 is connected to 3.3v
show
  delay(300);
their was an . in between 1024 line afte fixing no volt is showing 0.067 but when i connect load nothing hapens
ACS712.pdf (662.5 KB)
minimum 4,5V supply
now i changed to 5v and no volt changed to 0.161 but when i connect load nothing happens
  float current = float(abs(analogRead(34) - 512)) / 102.4; //Ampere. 5A max.
  delay(300);
// Include the required libraries
#include <ACS712.h>
// Define the pin number for the ACS712 sensor
#define ACS712_PIN 35
// Define the sensitivity of the ACS712 sensor
#define ACS712_SENSITIVITY 185 // 185mV/A for ACS712-05A module
// Declare the ACS712 object
ACS712 acs712(ACS712_PIN, ACS712_SENSITIVITY);
  // Initialize the serial communication
  // Read the current value from the ACS712 sensor
  float current = acs712.getCurrentDC();
  // Print the current value to the serial monitor
  Serial.print("Current: ");
  Serial.print(current);
  Serial.println("A");
  // Wait for a short period before taking another reading
  delay(100);
why ist showing Compilation error: 'class ACS712' has no member named 'getCurrentDC'
i have no responsibility of not my code.
brother i dont know what to do next i have tried everthing to get the acs712 working dtill no use
free module from wiring, connect 5v to 5V, GND to GND, take multimeter and watch voltage between signal and GND, you should see 2,5V.
yes bro its 2.5
well. reconnect module 5v to 3,3V and measure signal now
now its 1.59
take Li-Ion cell and resistor, or other constant current source. measure current with MM, it should be about 1A, then connect to load pins and measure signal output voltage
