Esp32 always resetting while receive data from uno
hi there....
in this project i make comunication arduino uno wit esp32 while arduino sending any data sensor to esp32,while esp32 ask the data to arduino uno.but if esp32 doesnt ask the data from arduino uno,arduino uno couldnt send the data sensor. but when ive upload ech program on arduino uno and esp32 (as receiver) and appear the data into serial monitor in esp32,the proble happen.:
  1. the data couldnt appear on esp32 serial monitor.
  2. when i press the esp32 reset button with 115200 baudrate,it always resetting or i change 9600 baudrate it so always resetting
    (ive put 10k resistor in uart betwen rx and tx).but when i checked outpur arduino uno voltage rx & tx it just 0.98 v and about 0.45v,when i chek voltage rx and tx in esp32,it shows rx=1.23 while it always changed about max 3.24 ,and tx alwas constant no more 1.xx.but when i changed baud rate 9600 it doesnt appear on serial monitor.
esp32 always resetting.
this is project serial comunication fritzing schematic.
arduino uno program (as sender sensor data program. here i change dht11 with dht22.
#include<DHT.h>
//konfigurasi untuk sesor DHT22
#define DHT_PIN 8
#define DHTTYPE DHT22
//buat variabel untuk sesnsor DHT22
DHT dht (DHT_PIN, DHTTYPE);
//variabel untuk menampung nilai sensor
int ldr;
float humidity,temperature;
  //aktifkan sensor DHT
  dht.begin();
//   ldr = analogRead(0);
//  //baca temperature dan kelembapan
//  temperature = dht.readTemperature();
//  humidity    = dht.readHumidity();
//  Serial.println(ldr);
//  Serial.println(temperature);
//  Serial.println(humidity);
  //perintah berikut di buat sebagai ilustrasi jika node mcu meminta data ke arduino uno
  String minta = "";
  //baca permintaan nodeMCU
  while(Serial.available()>0)
    minta += char(Serial.read());
  //buang spasi data yang diterima
  minta.trim();
  //uji variable minta
  if (minta == "Ya")
    //jika iya maka kirim data
    kirimdata();
  //kosongkan variabel minta
  minta = "";
  delay(500); //arduino akan melakukan pengecekan setiap satu detik ada permintaan atau tidak.
  /*hal penting dalam melakukan pengiriman data adalah pastikan data tidak
  dikirim secara terus menerus oleh arduino uno ke node mcu karena ia mengirim
  data terlalu cepat.ketika dia mengirim data terlalu ceapt,akan ada masalah di node mcu nya
  nah masalahnya adalah gampang reset sendiri,ini juga adalah kelemahan node mcu
  jika menerima data terus menerus dengan cepat dapat reset sendiri.atau ketika kita memprogram
  node mcu terjadi delay yg sangat lama,juga dapat menyebabkan reset,
  solusinya:
  data dikirim oleh arduino uno apabila ada permintaan dari node mcu.
  kita buat node mcu meminta data pada arduino uno.jika tidak ada permintaan
  makan arduino uno tidak akan mengirim data.
//arduino akan mengirim data jika ada permintaan dari nodemcu
void kirimdata()
 //baca nilai sensor LDR
  //sediakan variabel penampung data yang akan dikirim
  //data kirim = "10#29.05#84.50"
  String datakirim = String(ldr) + "#" + String(temperature) + "#" + String(humidity);
  //kirim data
  Serial.println(datakirim); //proses mengirim data
esp32 program as receiver data sensor,but it doesnt appear on esp32 serial monitor.
#include<SoftwareSerial.h>
//buat variable untuk sofware serial (Rx,Tx)
SoftwareSerial DataSerial(12, 13);
//millis sebagai pengganti delay
unsigned long previousMillis =0; //mendeteksi waktu akhir pengecekan
/*perbedaan millis dan delay: delay jika dijalankan maka program lain akan terhenti sebaliknya millis tidak*/
const long interval = 3000;
String arrData[3];//karena nilai sensor 3(jumlah sensor)
  // berikut program dimana node mcu meminta data pada arduino uno kemudian node mcu akan membacanya.
  //node mcu akan memina data setiap 3 detik sekali.
  DataSerial.begin(9600);
  // konfigurasi millis
  unsigned long currentMillis = millis(); //baca waktu millis (mili second saat ini)
  if (currentMillis - previousMillis >= interval)//jika program belum mencapai 3sekon maka program dilewati
    //update previouMillis(dia harus tahu dia harus refreh itu kapan)
    // prioritas pembacaan data dari arduino uno (hasil kiriman data)
    //baca data serial
    String data = "";
    while(DataSerial.available()>0)
      data += char(DataSerial.read());
    //buang spasi datanya
    data.trim();
    //uji data jika arduino kirim data kosong,maka diabaikan,jika tdk kosong maka format data "10#29.34#9845"
    //kemudian kita parsing data(pecah data)
    //kemudian setelah memecah data butuh array.
    int index = 0;
    //cara parsing dengan for
      for (int i=0; i<= data.length(); i++)
        char delimiter = '#';//karena menggunakan charr maka tanda petik satu
        if (data[i] != delimiter)
          arrData[index]  += data[i];
          index++;  //variable index bertambah 1
      //pastikan data yang dikirim lengkap(LDR,temp,hum)
      //urutanya 0=LDR, 1=Temp, 2=hum
      if (index == 2) //index dimulai dari 0,1,2
        //kita tampilkan nilai  sensor ke serial monitor
        Serial.println(arrData[0]);//LDR
        Serial.println(arrData[1]); //Temp
        Serial.println(arrData[2]); //hum
        Serial.println();//perintah spasi
      arrData[0] = "";//INI dikosongkan karena jika tidak data nambah terus.
      arrData[1] = "";
      arrData[2] = "";
  //minta data ke arduino uno
  DataSerial.println("Ya");
, please give me a solution
.thanks a lot. have a nice day.!! :slightly_smiling_face:
azhar
Make sure ESP8266 has a good power supply driving it, separate to the Uno's supply.
Take a look at this project Arduino to Arduino via Serial
you need to allow for the NodeMcu being 3v3 versus the Uno being 5v
You can alternatively use this circuit
Here I am using SoftwareSerial on the Uno so the USB can be used for debugging. Hardware serial is better but difficult to debug so start with software serial until things are running.
Here some example sketches using the SerialComs class from my SafeString library
UnoSoftSerialCSVToESP8266.ino (2.2 KB)
ESP8266CSV_fromUno.ino (2.5 KB)
Here is a simple echo test sketch to run on each board and open two IDEs and connect each board to one and open the two monitors,
UnoSoftSerialEchoTest.ino (825 Bytes)
You need to change the SoftwareSerial settings for the ESP8266
