I find that with the ESP32, to het the best results from the A:D is to use the ESP32 A:D API
Page not Found - ESP32 - — ESP-IDF Programming Guide latest documentation instead of the Arduino way.
#include "sdkconfig.h"
#include "esp_system.h" //This inclusion configures the peripherals in the ESP system.
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/timers.h"
#include "freertos/event_groups.h"
#include <SimpleKalmanFilter.h>
#include <driver/adc.h>
#include "driver/mcpwm.h"
2000 mocrosecond
const int TaskCore1 = 1;
const int TaskCore0 = 0;
const int TaskStack20K = 20000;
const int Priority3 = 3;
const int Priority4 = 4;
const int SerialDataBits = 115200;
const int servo_EW_Park = 900; //using writeMicroseconds
const int servo_NS_Pin = GPIO_NUM_12; //
const int servo_NS_Park = 900; //using writeMicroseconds
// https://dl.espressif.com/doc/esp-idf/latest/api-reference/peripherals/adc.html
// set up A:D channels
adc_power_on( );
vTaskDelay( 1 );
adc1_config_width(ADC_WIDTH_12Bit);
// ADC1 channel 0 is GPIO36 (ESP32), GPIO1 (ESP32-S2)
adc1_config_channel_atten(ADC1_CHANNEL_0 , ADC_ATTEN_DB_11);
// ADC1_CHANNEL_3 ADC1 channel 3 is GPIO39 (ESP32)
adc1_config_channel_atten(ADC1_CHANNEL_3, ADC_ATTEN_DB_11);
// ADC1 channel 5 is GPIO33
adc1_config_channel_atten(ADC1_CHANNEL_5, ADC_ATTEN_DB_11);
// ADC1 channel 6 is GPIO34
adc1_config_channel_atten(ADC1_CHANNEL_6, ADC_ATTEN_DB_11);
// adc for light dark detection, ADC1 channel 7 is GPIO35 (ESP32)
adc1_config_channel_atten(ADC1_CHANNEL_7, ADC_ATTEN_DB_11);
mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM1A, GPIO_NUM_4 ); // Azimuth
mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM0A, GPIO_NUM_12 ); // Altitude servo
mcpwm_config_t pwm_config = {};
pwm_config.frequency = 50; //frequency = 50Hz, i.e. for every servo motor time period should be 20ms
pwm_config.cmpr_a = 0; //duty cycle of PWMxA = 0
pwm_config.cmpr_b = 0; //duty cycle of PWMxb = 0
pwm_config.counter_mode = MCPWM_UP_COUNTER;
pwm_config.duty_mode = MCPWM_DUTY_MODE_0;
mcpwm_init(MCPWM_UNIT_0, MCPWM_TIMER_0, &pwm_config); //Configure PWM0A timer 0 with above settings
mcpwm_init(MCPWM_UNIT_0, MCPWM_TIMER_1, &pwm_config); //Configure PWM0A timer 1 with above settings
fMoveAltitude( 1500 );
vTaskDelay( 10 );
fMoveAzimuth( 1500 );
vTaskDelay(10);
xTaskCreatePinnedToCore( fDaylight, "fDaylight", TaskStack20K, NULL, Priority3, NULL, TaskCore0 ); // assigned to core
void mcpwm_gpio_initialize(void)
void TrackSun( void * pvParameters )
int Altitude = 1500;
int Azimuth = 1500;
int maxAltitudeRange = 2144;
int minAltitudeRange = 900;
int maxAzimuthRange = 2144;
int minAzimuthRange = 900;
SimpleKalmanFilter kfAltitude0( 5.0, 10.0, .01 ); // kalman filter Altitude 0
SimpleKalmanFilter kfAltitude1( 5.0, 10.0, .01 ); // kalman filter Altitude 1
SimpleKalmanFilter kfAzimuth0( 5.0, 5.0, .01 ); // kalman filter Azimuth 0
SimpleKalmanFilter kfAzimuth1( 5.0, 5.0, .01 ); // kalman filter Azimuth 1
float filteredAltitude_0 = 0.0f;
float filteredAltitude_1 = 0.0f;
float filteredAzimuth_0 = 0.0f;
float filteredAzimuth_1 = 0.0f;
int64_t AzimuthEndTime = esp_timer_get_time();
int64_t AzimuthStartTime = esp_timer_get_time(); //gets time in uSeconds like Arduino Micros,
int64_t AltitudeEndTime = esp_timer_get_time();
int64_t AltitudeStartTime = esp_timer_get_time(); //gets time in uSeconds like Arduino Micros,
float AltitudeThreashold = 80.0f;
float AzimuthThreashold = 60.0f;
while (1)
//Altitude
AltitudeEndTime = esp_timer_get_time() - AltitudeStartTime; // produce elasped time for the simpleKalmanFilter
kfAltitude0.setProcessNoise( (float)AltitudeEndTime / 1000000.0f ); //convert time of process to uS, update SimpleKalmanFilter q
kfAltitude1.setProcessNoise( (float)AltitudeEndTime / 1000000.0f ); //convert time of process to uS, update SimpleKalmanFilter q
filteredAltitude_0 = kfAltitude0.updateEstimate( (float)adc1_get_raw(ADC1_CHANNEL_3) );
filteredAltitude_1 = kfAltitude1.updateEstimate( (float)adc1_get_raw(ADC1_CHANNEL_0) );
if ( (filteredAltitude_0 > filteredAltitude_1) && (abs(filteredAltitude_0 - filteredAltitude_1) > AltitudeThreashold))
Altitude -= 1;
if ( Altitude < minAltitudeRange )
Altitude = 1500;
fMoveAltitude( Altitude );
vTaskDelay( 12 );
if ( (filteredAltitude_0 < filteredAltitude_1) && (abs(filteredAltitude_0 - filteredAltitude_1) > AltitudeThreashold) )
Altitude += 1;
if ( Altitude >= maxAltitudeRange )
Altitude = 1500;
vTaskDelay( 12 );
// Serial.println();
//// AZIMUTH
AzimuthEndTime = esp_timer_get_time() - AzimuthStartTime; // produce elasped time for the simpleKalmanFilter
kfAzimuth0.setProcessNoise( (float)AzimuthEndTime / 1000000.0f ); //convert time of process to uS, update SimpleKalmanFilter q
kfAzimuth1.setProcessNoise( (float)AzimuthEndTime / 1000000.0f ); //convert time of process to uS, update SimpleKalmanFilter q
filteredAzimuth_0 = kfAzimuth0.updateEstimate( (float)adc1_get_raw(ADC1_CHANNEL_5) );
filteredAzimuth_1 = kfAzimuth1.updateEstimate( (float)adc1_get_raw(ADC1_CHANNEL_6) );
if ( (filteredAzimuth_0 > filteredAzimuth_1) && (abs(filteredAzimuth_0 - filteredAzimuth_1)) > AzimuthThreashold )
Azimuth += 2;
if ( Azimuth >= maxAzimuthRange )
Azimuth = 900;
fMoveAzimuth( Azimuth );
vTaskDelay( 12 );
if ( (filteredAzimuth_0 < filteredAzimuth_1) && (abs(filteredAzimuth_1 - filteredAzimuth_0)) > AzimuthThreashold )
Azimuth -= 2;
if ( (Azimuth >= maxAzimuthRange) || (Azimuth <= minAzimuthRange) )
Azimuth = 900;
vTaskDelay( 12 );
vTaskDelay( 30 );
} // while(1)
} //void TrackSun()
