Hi. I am trying to use a ESP32 and this touch screen 3.5" TFT LCD Display with resistive touch. I am only able to get a white screen using these pin connections. From researching it, it seems the only thing I might be lacking (that I can tell) is using the x-, x+, y+, y- pins. Those seem like I obviously need to use them but I am using this pinout and getting messages in Serial Monitor that say: "working" and then "could not connect to display." So it is breaking on one of these lines. Any help would be very cool!
tft.begin();
tft.fillScreen(HX8357_BLACK); // Set the background to black
pinout:
TFT_CS: Connect to GPIO 5 (assuming CS next to D/C and RST)TFT_DC: Connect to GPIO 4TFT_RST: Connect to GPIO 2TS_CS: Connect to GPIO 15 (assuming Card CS)MOSI: Connect to GPIO 23MISO: Connect to GPIO 19CLK: Connect to GPIO 18
#include <Adafruit_HX8357.h>
#include <Adafruit_STMPE610.h>
#include <WiFi.h>
#define SerialMon Serial
#include <AppleMIDI_Debug.h>
#include <AppleMIDI.h> // Add the AppleMIDI library
char ssid[] = "ATT4K"; // your network SSID (name)
char pass[] = "passpasspass"; // your network password (use for WPA, or use as key for WEP)
// TFT display and touchscreen pins
#define TFT_CS 5
#define TFT_DC 4
#define TFT_RST 2
#define TS_CS 15
const int DEBOUNCE_DELAY = 70; // the debounce time; increase if the output flickers
// The display uses hardware SPI, plus TFT_RST and TFT_DC
Adafruit_HX8357 tft = Adafruit_HX8357(TFT_CS, TFT_DC, TFT_RST);
Adafruit_STMPE610 ts = Adafruit_STMPE610(TS_CS);
// global variables to keep track of the previous position
int previous_x = -1;
int previous_y = -1;
unsigned long lastDebounceTime = 0; // the last time the output pin was toggled
unsigned long t0 = millis();
int8_t isConnected = 0;
APPLEMIDI_CREATE_DEFAULTSESSION_INSTANCE();
Serial.print("working");
tft.begin();
if (!ts.begin()) {
Serial.println("Couldn't start touchscreen controller");
while (1);
DBG_SETUP(115200);
Serial.print("Booting");
WiFi.begin(ssid, pass);
Serial.print("Establishing connection to WiFi..");
Serial.print("Connected to network");
Serial.println(F("OK, now make sure you an rtpMIDI session that is Enabled"));
Serial.println(F("Add device named Arduino with Host"));
Serial.println(F("Port"));
Serial.println(AppleMIDI.getPort());
Serial.println(F("(Name"));
Serial.println(AppleMIDI.getName());
Serial.println(F(")"));
Serial.println(F("Select and then press the Connect button"));
Serial.println(F("Then open a MIDI listener and monitor incoming notes"));
Serial.println(F("Listen to incoming MIDI commands"));
MIDI.begin();
AppleMIDI.setHandleConnected([](const APPLEMIDI_NAMESPACE::ssrc_t & ssrc, const char* name) {
isConnected++;
DBG(F("Connected to session"), ssrc, name);
AppleMIDI.setHandleDisconnected([](const APPLEMIDI_NAMESPACE::ssrc_t & ssrc) {
isConnected--;
DBG(F("Disconnected"), ssrc);
MIDI.read();
if (ts.touched()) {
Serial.println("Screen is pressed");
TS_Point p = ts.getPoint();
int cc11 = map(p.x, 0, tft.width(), 0, 127);
int cc10 = map(p.y, 0, tft.height(), 0, 127);
// send MIDI messages
MIDI.sendControlChange(66, 127, 5);
MIDI.sendControlChange(67, cc11, 5);
MIDI.sendControlChange(68, cc10, 5);
// Draw blue circle at touch point
tft.fillCircle(p.x, p.y, 10, HX8357_BLUE);
// Draw a tail from the previous position to the current position
if (previous_x != -1 && previous_y != -1) {
tft.drawLine(previous_x, previous_y, p.x, p.y, HX8357_BLUE);
// update the previous position
previous_x = p.x;
previous_y = p.y;
MIDI.sendControlChange(66, 0, 5);
// reset previous position
previous_x = -1;
previous_y = -1;
