ESP32 and CAN (VD230)
As a note, it works for me.
#include <CAN_config.h>
#include <ESP32CAN.h>
CAN_device_t CAN_cfg;
setup()
CAN_cfg.speed = CAN_SPEED_1000KBPS;
  CAN_cfg.tx_pin_id = GPIO_NUM_12; // green wire
  CAN_cfg.rx_pin_id =  GPIO_NUM_13; // white wire
  CAN_cfg.rx_queue = xQueueCreate(3, sizeof(CAN_frame_t));
  //start CAN Module
  ESP32Can.CANInit();
 xTaskCreatePinnedToCore ( fSendCAN_Buss, "fSendCAN_Buss", TaskStack15K, NULL, Priority4, NULL, TaskCore0 );
  sema__Send_CAN_Bus = xSemaphoreCreateMutex();
  xSemaphoreGive ( sema__Send_CAN_Bus );
void fSendCAN_Buss( void *pvParameters )
  stuSERVO_Message pxServo_Message;
  for ( ;; )
    xEventGroupWaitBits (eg, evtSendCAN_Buss, pdTRUE, pdTRUE, portMAX_DELAY);
    if ( xSemaphoreTake( sema__Send_CAN_Bus, xTicksToWait0 ) == pdTRUE ) // grab semaphore no wait
      CAN_frame_t rx_frame;
      // Serial.println ( " fSendCAN_Buss 2 "  );
      if ( (CAN_cfg.rx_queue != NULL) && (uxQueueMessagesWaiting(CAN_cfg.rx_queue)) ) // if queue not null and something is waiting in queue
        // Serial.println ( uxQueueMessagesWaiting(CAN_cfg.rx_queue) );
        if (xQueueReceive( CAN_cfg.rx_queue, &rx_frame , xTicksToWait0) == pdTRUE )
          if ( rx_frame.MsgID == 2 )
            // Serial.println ( rx_frame.data.u8[0] );
            if ( rx_frame.data.u8[0] == '6' )
              EOT = false;
              // Serial.print ( " frame ID " );
              // Serial.print ( rx_frame.MsgID );
              // Serial.println ( "ACK" );
              //              rx_frame.FIR.B.FF = CAN_frame_std;
              //              rx_frame.MsgID = xServo_EOT.MsgID;
              //              rx_frame.FIR.B.DLC = xServo_EOT.DLC;
              //              rx_frame.data.u8[0] = xServo_EOT.Servo_EOT;
              //              rx_frame.data.u8[1] = xServo_EOT.p4; // send all '0'
              //              rx_frame.data.u8[2] = xServo_EOT.p4;
              //              rx_frame.data.u8[3] = xServo_EOT.p4;
              //              rx_frame.data.u8[4] = xServo_EOT.p4;
              //              rx_frame.data.u8[5] = xServo_EOT.p4;
              //              rx_frame.data.u8[6] = xServo_EOT.p4;
              //              rx_frame.data.u8[7] = xServo_EOT.p4;
              //              ESP32Can.CANWriteFrame(&rx_frame);
              // Serial.println ( " sent Servo controller ack " );
              //              vTaskDelay( pdMS_TO_TICKS( 6 ) );
            //            if (rx_frame.data.u8[0] = '3')
            //                EOT = false;
            if ( rx_frame.data.u8[0] == '4' )
              //                          rx_frame.data.u8[0] = '4';
              // Serial.println ( "InitComplete ack " );
              EOT = false;
              xSemaphoreGive ( sema_HexaPodAdjustment ); // begin walking forward task
          } // if ( rx_frame.MsgID == 2 )
        } // if (xQueueReceive( CAN_cfg.rx_queue, &rx_frame , xTicksToWait5) == pdTRUE )
      } // if ( (CAN_cfg.rx_queue != NULL) && (uxQueueMessagesWaiting(CAN_cfg.rx_queue)) )
      //      // ack the initialization
      if ( xQueueReceive ( xQ_SERVO_Message, &pxServo_Message, QueueReceiveDelayTime ) == pdTRUE )
        rx_frame.MsgID = pxServo_Message.MsgID;
        rx_frame.FIR.B.DLC = pxServo_Message.DLC;
        rx_frame.data.u8[0] = pxServo_Message.Instruction;
        rx_frame.data.u8[1] = pxServo_Message.p1;
        rx_frame.data.u8[2] = pxServo_Message.p2;
        rx_frame.data.u8[3] = pxServo_Message.p3;
        rx_frame.data.u8[4] = pxServo_Message.p4; // end of torque to position
        rx_frame.data.u8[5] = pxServo_Message.p5;
        rx_frame.data.u8[6] = pxServo_Message.p6;
        rx_frame.data.u8[7] = pxServo_Message.p7;
        //                Serial.print ( " message in sendCanBus " );
        //                Serial.print ( ", " );
        //                Serial.print ( rx_frame.data.u8[0] );
        //                Serial.print ( rx_frame.data.u8[1] );
        //                Serial.print (rx_frame.data.u8[2] );
        //                Serial.print ( rx_frame.data.u8[3] );
        //                Serial.print ( rx_frame.data.u8[4] );
        //                Serial.println ( " message end." );
      // Serial.print( "fSendCAN_Buss " );
      // Serial.print(uxTaskGetStackHighWaterMark( NULL ));
      // Serial.println();
      // Serial.flush();
    }  // if ( xSemaphoreTake( sema__Send_CAN_Bus, xTicksToWait0 ) == pdTRUE ) // grab semaphore no wait
  } // the for loop
  vTaskDelete( NULL );
} // void fSendCAN_Buss( void *pvParameters )
