ESP32 and DS18B20 only works once after upload
Good day all,
I have a really odd issue and I would love some help on this odd one.
I have a ESP32 board, with a DS18B20 connected on pin D4, which I believe on the ESP references pin 7.
Once I Upload after setting the pin to 7, the DS18B20 works perfectly, until I either re-upload or plug the ESP32 in elsewhere where it is actually being used. Basically if it reboots once, it tickets. I then have to change the pin, to lets say 4, upload, then change it back to 7, upload and it works again until unplugged...
I am powering the ESP over USB C and only have 2 DS18B20's connected in serial. I have tested with only 1 DS18B20 and get the same behavior.
I am using a Gikfun DS18B20 : Gikfun DS18B20 Waterproof Digital Temperature Sensor with Adapter Module for Arduino (Pack of 3 Sets) EK1183 : Amazon.ca: Industrial & Scientific
My Code is as follows:
//Network Connectivity
#include <WiFi.h>
#include <HTTPClient.h>
#include "arduino_secrets.h"
//Temp Probe
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 7
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
//Temp Sensor DS18B20
//Black = GND
//Yellow = Data
//White = VCC
const char* password = "Password";
const char* ssid = "WIFINetwork";
int SensorID1 = 4;
float TempS1 = 0;
int SensorID2 = 5;
float TempS2 = 0;
int SensorID3 = 6;//NA
float TempS3 = 0;
// API endpoint
const char* serverName = "http://192.168.10.xxxx";
// Timing variables
unsigned long lastTime = 0;
const unsigned long interval = 30000; // 1 minute in milliseconds = 30000
  pinMode(motorPin1, OUTPUT);
  pinMode(motorPin2, OUTPUT);
  pinMode(buttonOpen, INPUT_PULLUP);
  pinMode(buttonClose, INPUT_PULLUP);
  // Connect to Wi-Fi
  Serial.print("Connecting to Wi-Fi");
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("\nConnected to Wi-Fi");
  sensors.begin();  // Start up the Temperature library
  TempS1 = sensors.getTempCByIndex(0);
  // Check if it's time to send the PUT request
  unsigned long currentTime = millis();
  if (currentTime - lastTime >= interval) {
    lastTime = currentTime;
    ReadTemps();
    if (WiFi.status() == WL_CONNECTED) {
      // Prepare JSON payload
      float value = TempS1;
      int sensorid = SensorID1;
      Serial.println("Temperature 1 : " + String(value));
      PostTemps(value, sensorid);
      value = TempS2;
      sensorid = SensorID2;
      Serial.println("Temperature 2 : " + String(value));
      value = TempS3;
      sensorid = SensorID3;
      Serial.println("Temperature 3 : " + String(value));
        Serial.println("WiFi Disconnected");
  delay(100);
void PostTemps(float value, int sensorid) {
      WiFiClient client;
      HTTPClient http;
      http.begin(client, serverName);
      // Add headers
      http.addHeader("Content-Type", "application/json; charset=utf-8");
      http.addHeader("accept", "*/*");
  if(value != -127)
        String jsonPayload = "{\"value\": " + String(value) + ", \"sensorid\": " + String(sensorid) + "}";
        // Send POST request
        int httpResponseCode = http.POST(jsonPayload);
        // Handle response
        if (httpResponseCode > 0) {
          String payload = http.getString(); // Get response payload
          Serial.println("HTTP Response code: " + String(httpResponseCode));
          Serial.println("Response: " + payload);
          Serial.println("Error on HTTP request");
          Serial.println("Server: " + String(serverName));
          Serial.println("Payload: " + jsonPayload);
        http.end(); // Free resources
void ReadTemps() {
  sensors.requestTemperatures();
  // You can have more than one IC on the same bus. 0 refers to the first IC on the wire
  TempS2 = sensors.getTempCByIndex(1);
  TempS3 = sensors.getTempCByIndex(2);
Apologies if I have missed anything.
Thank you
You need to pick another pin, Gpio7 is connected to Esp32 boards flash memory.
Choose any pin between 16-33 for example.
