Hi everyone, I want to connect and ESP32 WROOM 32 with a GC9A01. I am currently testing the HelloWorld example using the Arduino GFX library. The code does not give any errors, however once uploaded, nothing happens. I would really appreciate any help! Thanks in advance.
Blok-alıntı
- Start of Arduino_GFX setting
- Arduino_GFX try to find the settings depends on selected board in Arduino IDE
- Or you can define the display dev kit not in the board list
- Defalult pin list for non display dev kit:
- Arduino Nano, Micro and more: CS: 9, DC: 8, RST: 7, BL: 6
- ESP32 various dev board : CS: 5, DC: 27, RST: 33, BL: 22
- ESP32-C3 various dev board : CS: 7, DC: 2, RST: 1, BL: 3
- ESP32-S2 various dev board : CS: 34, DC: 35, RST: 33, BL: 21
- ESP32-S3 various dev board : CS: 40, DC: 41, RST: 42, BL: 48
- ESP8266 various dev board : CS: 15, DC: 4, RST: 2, BL: 5
- Raspberry Pi Pico dev board : CS: 17, DC: 27, RST: 26, BL: 28
- RTL8720 BW16 old patch core : CS: 18, DC: 17, RST: 2, BL: 23
- RTL8720_BW16 Official core : CS: 9, DC: 8, RST: 6, BL: 3
- RTL8722 dev board : CS: 18, DC: 17, RST: 22, BL: 23
- RTL8722_mini dev board : CS: 12, DC: 14, RST: 15, BL: 13
- Seeeduino XIAO dev board : CS: 3, DC: 2, RST: 1, BL: 0
- Teensy 4.1 dev board : CS: 39, DC: 41, RST: 40, BL: 22
#include <Arduino_GFX_Library.h>
#if defined(DISPLAY_DEV_KIT)
Arduino_GFX gfx = create_default_Arduino_GFX();
#else / !defined(DISPLAY_DEV_KIT) */
#if defined(ESP32)
#define CS 5
#define DC 27
#define RST 33
#define BL 22
#endif
/* More data bus class: Data Bus Class · moononournation/Arduino_GFX Wiki · GitHub */
//Arduino_DataBus *bus = create_default_Arduino_DataBus();
//Arduino_DataBus bus = new Arduino_ESP32SPI(12 / DC /, 15 / CS /, 14 / SCK /, 13 / MOSI /, -1 / MISO /, HSPI / spi_num */);
Arduino_DataBus bus = new Arduino_ESP32SPI(27 / DC /, 5 / CS /, 18 / SCK /, 23 / MOSI /, -1 / MISO /, VSPI / spi_num */);
/* More display class: Display Class · moononournation/Arduino_GFX Wiki · GitHub */
//Arduino_GFX gfx = new Arduino_ILI9341(bus, DF_GFX_RST, 0 / rotation /, false / IPS */);
//Arduino_GFX gfx = new Arduino_GC9A01(bus, 2 / RST /, 0 / rotation /, true / IPS */);
Arduino_GFX gfx = new Arduino_GC9A01(bus, 7 / RST /, 0 / rotation /, true / IPS */);
#endif /* !defined(DISPLAY_DEV_KIT) /
- End of Arduino_GFX setting
void setup(void)
gfx->begin();
gfx->fillScreen(BLACK);
#ifdef GFX_BL
pinMode(GFX_BL, OUTPUT);
digitalWrite(GFX_BL, HIGH);
#endif
gfx->setCursor(10, 10);
gfx->setTextColor(RED);
gfx->println("Hello World!");
delay(5000); // 5 seconds
gfx->setCursor(random(gfx->width()), random(gfx->height()));
gfx->setTextColor(random(0xffff), random(0xffff));
gfx->setTextSize(random(6) /* x scale /, random(6) / y scale /, random(2) / pixel_margin */);
delay(1000); // 1 second
