Hi!
I am working on a project where I need the precise orientation of an MPU6050. I started off using the Adafruit mpu6050 library and everything was working fine. However, I needed to use the DMP for accurate results. I am trying to use the MPU6050 library by Jeff Rowberg: MPU6050 by Jeff Rowberg .
When trying to use the MPU6050_DMP6 example in the Arduino IDE, it uploads, but when I reset the ESP32 and look for data in the Serial Monitor, It stops at "Initializing I2C devices".
