Hello all,
I am trying to connect Esp32 to the MQTT broker(Raspberrry Pi) but I am having issues in it. I am trying to send a simple "Hello" message to the MQTT broker via Wi-Fi but it does not work. Upon checking the IP Address of Esp32 it is "192.168.0.105" and the raspberry pi IP is "192.168.0.106" and the Wi-Fi IP is "192.168.0.1". I am confused that maybe this is the error because of IP adressed or is it something else. Esp32 does connects to the Wi-Fi and so does the Raspberry Pi with MQTT broker but on different IPs. MQTT broker is also running fine on RPi, but I don't know where the issue is. Can anyone help me with this?
I am posting the Esp32 code below:
#include <HardwareSerial.h>
#include <PubSubClient.h> //Connect and publish data to the MQTT broker
#include <WiFi.h> //Enables Esp32 to connect to the local network(via WiFi)
#define RXD2 16
#define TXD2 17
//char myRcvChar;
//WiFi
const char* ssid = "xxxxxxxxxxx";
const char* wifi_password = "xxxxxx";
//MQTT
const char* mqtt_server = "192.168.0.106";
const char* message_topic = "test/esp32/message";
//const char* bending_topic = "exoskeleton/walking/bending";
//const char* streching_topic = "exoskeleton/walking/streching";
const char* mqtt_username = "pi"; //MQTT username
const char* mqtt_password = "raspberry"; //MQTT password
const char* clientID = "first message";
//Initialise the Wifi and MQTT Client objects
WiFiClient wifiClient;
//1883 is the listener port for the broker
PubSubClient client(mqtt_server,1883,wifiClient);
//Custom function to connect to the MQTT broker via WiFi
void connect_MQTT(){
Serial.print("Connecting to ");
Serial.println(ssid);
//Connect to the WiFi
WiFi.begin(ssid, wifi_password);
//wait until the connection has been confirmed before continuing
while(WiFi.status()!= WL_CONNECTED){
Serial.print(".");
//Debugging-Output the IP Address of the ESP32
Serial.println("WiFi connected");
Serial.println("IP Address");
//Connect to MQTT Broker
//client.connect returns a boolean value to let us know if the connection was successful
//if the connection is failing, make sure you are using the correct MQTT Username and Password
if(client.connect(clientID,mqtt_username,mqtt_password)){
Serial.println("Connected to MQTT Broker");
else{
Serial.println("Connection to MQTT Broker failed...");
Serial2.begin(115200, SERIAL_8N1, RXD2, TXD2);
//char myRcvchar;
connect_MQTT();
Serial.setTimeout(2000);
Serial.println("Data Received: ");
Serial.println(Serial2.readStringUntil('\n'));
const char* message = "Hello";
Serial.print("Message Received: ");
Serial.print(message);
//MQTT can only transmit strings
String ms = "Mess: "+String((char*)message);
//Publish to MQTT broker
if(client.publish(message_topic, String(message).c_str())){
Serial.println("Message sent");
//Again client.publish will return boolean value depending on whether it succeded or not.
//if the message failed to send, try again, as the connection might have broken
else{
Serial.println("Message failed to send. Reconnecting to MQTT Broker and trying again");
client.connect(clientID,mqtt_username,mqtt_password);
delay(10); //This delay ensures that client.publish does not clash with client.connect call
client.publish(message_topic,String(message).c_str());
client.disconnect(); //disconnect from the MQTT broker
delay(1000*60); //print new values every 2 minutes
