Hi friends,
I have tried to write a project where I'm using an ESP32, a DHT11 and a 4 wire PWM caged fan.
I'm trying to log the data from the DHT11 on my blynk-app and send PWM signals to my caged fan at the same time.
the first code I have is the basic Blynk example:
#define BLYNK_PRINT Serial
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <DHT.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "YyxSI-rgdqf_ozwx3BmIZkkMFU3cuppC";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "nabofarm";
char pass[] = "regnbuer";
#define DHTPIN 4 // What digital pin we're connected to
// Uncomment whatever type you're using!
#define DHTTYPE DHT11 // DHT 11
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
BlynkTimer timer;
// This function sends Arduino's up time every second to Virtual Pin (5).
// In the app, Widget's reading frequency should be set to PUSH. This means
// that you define how often to send data to Blynk App.
void sendSensor()
float h = dht.readHumidity();
float t = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from DHT sensor!");
return;
// You can send any value at any time.
// Please don't send more that 10 values per second.
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
// Debug console
Blynk.begin(auth, ssid, pass);
// You can also specify server:
//Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 80);
//Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8080);
dht.begin();
// Setup a function to be called every second
timer.setInterval(1000L, sendSensor);
Blynk.run();
timer.run();
the new one is one I did with a mix of the example and another one where I should be able to send out PWM signal to pin 16.
The example is running fine but when I upload the new one it's only online on the blink app for a short period. Does anyone know what's wrong?
/* App project setup:
Value Display widget attached to V5
Value Display widget attached to V6
/* Comment this out to disable prints and save space */
#include <WiFi.h>
#include <DHT.h>
BlynkTimer timer;
void sendSensor()
return;
const int ledpin = 16;
const int freq= 20000;
const int channel= 0;
const int resolution= 8;
ledcSetup (0, 20000, 8);
ledcAttachPin (16 , 0);
// Debug console
dht.begin();
if (dht.readHumidity() < 60)
// increase the LED brightness
{for(int dutyCycle = 0; dutyCycle = 0; ){
// changing the LED brightness with PWM
ledcWrite(0, dutyCycle);}
for(int dutyCycle = 0; dutyCycle = 255; ){
delay (1000);
Blynk.run();
timer.run();
