Hello,
I was looking to use a Teensy 3.2 MCU to communicate between an E paper display and RFID module to provide an interactive scale payment system for my project. I have used I2C protocols to communicate with an ESP32 to retrieve and send different variables which are:
- Card ID from Teensy 3.2 to ESP32 (Not yet configured)
- Weight from ESP 32 to Teensy 3.2
I have set up the E paper display to only switch to my sale screen when the RFID module receives a card ID where then it would continuously update the weight on the sale screen as long as the calculated weight is greater than the previous weight as found here:
Slave code:
A simple sketch to test and demo the dispenser's current features
#include "DispenserData.h"
#include "DispenserUI.h"
#include "Dispenser.h"
#include <Wire.h>
// Const
const int dispensingTimout = 5000; //in milliseconds
int weight;
int prevWeight = 0;
Dispenser dp;
// Initialise dispenser
dp.begin();
// Show product screen at startup
dp.clearScreen();
dp.showProductScreen();
// Continuosly check for rfid cards
if (dp.isCardPresent()) {
Serial.print("CardID: ");
Serial.println(dp.getCardID());
// If one is detected, toggle LED
// and display sale screen
dp.ledOn();
dp.clearScreen();
dp.showSaleScreen(0);
// Keep filling container until timout is reached
unsigned long startTime = millis();
while (millis() - startTime < dispensingTimout) {
Wire.begin(8); // join i2c bus with address #8
Wire.onReceive(receiveEvent);
// Toggle motor depending on whether
// button is pressed
if (dp.isButtonPressed()) {
Serial.println("Dispensing.");
dp.addWeight(); // For Testing only
dp.motorOn(255);
dp.motorOff();
// After timout, "stop dispensing",
// and return to product screen
dp.motorOff();
//dp.showSaleScreen(weight);
dp.ledOff();
//dp.resetWeight(); //reset
delay(2500);
dp.clearScreen();
void receiveEvent(int howmany) {
while(1 < Wire.available()) // loop through all but the last
char c = Wire.read(); // receive byte as a character
Serial.print(c); // print the character
int weight = Wire.read(); // respond with message of 6 bytes // as expected by master
//Serial.println(weight);
if (weight > prevWeight) {
weight == prevWeight;
Master code:
#include <WiFi.h>
#include <HTTPClient.h>
#include <Wire.h>
// Const
int prevWeight = 0;
// Wifi constants
const char* wifiSsid = "Crunchy";
const char* wifiPassword = "muffin4me";
const int httpConnectionTimeout = 500;
const char* cartServiceURL = "http://10.0.0.88:8080/Cart";
const char* pulseServiceURL = "http://10.0.0.88:8080/Pulse";
Dispenser dp;
Wire.begin();
// Connect to WiFi
WiFi.begin(wifiSsid, wifiPassword);
Serial.println("Connecting to WiFi...");
Serial.println("Connected to WiFi...");
dp.begin();
if (WiFi.status() == WL_CONNECTED) {
HTTPClient pulseClient;
pulseClient.setConnectTimeout(httpConnectionTimeout);
pulseClient.begin(pulseServiceURL);
int pulseResponseCode = pulseClient.GET();
pulseClient.end();
//if (pulseResponseCode == 200) {
// getcardID();
int weight = dp.getWeight();
prevWeight == weight;
Wire.beginTransmission(8); // transmit to device #8
Wire.write("Weight is ");
Wire.write(weight);
Wire.endTransmission(); // stop transmitting
else{
// Network sent data
// String cardID = dp.getCardID();
// String machineID = WiFi.macAddress();
// unsigned int weightGrams = dp.getWeight();
// Debug echo
// Serial.println("Exiting dispensing mode.");
// Serial.print("CardID: ");
// Serial.println(cardID);
// Serial.print("machineID: ");
// Serial.println(machineID);
// Serial.print("weightGrams: ");
// Serial.println(weightGrams);
// Send data over network
// if (weightGrams > 0) {
Serial.println("Sending Data to web service.");
// String weightString = String(weightGrams);
//itoa(weightGrams, weightString, 10);
String xml1 = "<CartItem xmlns:i=\"http://www.w3.org/2001/XMLSchema-instance\" xmlns=\"http://schemas.datacontract.org/2004/07/Dispenser.WebService.Model\">\r\n";
String xml2a = " <CardId>";
String xml2b = "</CardId>\r\n";
String xml3a = " <MachineId>";
String xml3b = "</MachineId>\r\n";
String xml4a = " <Weight>";
String xml4b = "</Weight>\r\n";
String xml5 = "</CartItem>";
String payload = xml1 + xml2a + xml2b + xml3a + xml3b + xml4a + xml4b + xml5;
//String payload = xml1 + xml2a + cardID + xml2b + xml3a + machineID + xml3b + xml4a + weightString + xml4b + xml5;
Serial.println(payload);
HTTPClient webclient;
webclient.setConnectTimeout(httpConnectionTimeout);
webclient.begin(cartServiceURL);
webclient.addHeader("Content-Type", "application/xml");
webclient.addHeader("Accept", "application/xml");
int httpResponseCode = webclient.POST(payload);
if (httpResponseCode == 200) {
Serial.println("Sending data: success");
Serial.println("Sending data: failed");
webclient.end();
// dp.resetWeight();
//else {
//Serial.println("ERROR - Web service not available");
// TO DO
// Show on dispenser screen as that the dispense is offline
//delay(500);
//else {
//Serial.println("ERROR - WiFi not connected...");
// TO DO
// Show on dispenser screen as no WiFi available
// delay(500);
//void getcardID(){
// Wire.requestFrom(8,11); // request 11 bytes from slave device #8
// while (Wire.available()) { // slave may send less than requested
// char c = Wire.read(); // receive a byte as character
// Serial.print(c); // print the character
// Serial.println();
The variables are being sent by Master slave I2C between the ESP32 and Teensy 3.2, my issue is that my Epaper display continues displaying the weight values whether <,=, > the previous weight value and is stuck in this loop indefinitely without restarting from the beginning of my void loop()
My code does consist of classes so I went ahead and attached it at the bottom of the document. The class functions used to measure, send, display & receive the weight measurements can be found there
firmware_slave.zip (7.44 KB)
Firmware_master.zip (5.86 KB)
