Esp32 arduino getstring()
Hello ım working on a project rfid mysql and php project, my arduino (esp32) .It connects to a site ( getUID.php) with http.begin and transmits rfid tag information, then php mysql platforms perform operations in the background and show the tag information on a separate php page (readtag2.php). I want to connect with http.begin again for this site and then save the tag information on that page to the payload variable with get.string(), but I see the source string of that site, so actually I can transfer the html codes to my variable. How can I transfer the information from that site to my variable?.
My arduino codes :
#include <WebServer.h>
#include <HTTPClient.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 5 //--> SDA
#define RST_PIN 27 //--> RST
MFRC522 mfrc522(SS_PIN, RST_PIN);
#define ON_Board_LED 2 //--> On Board LED
//-----------------------------------------SSID and Password of your WiFi router-------------------------------------------------------------------------------------------------------------//
const char* ssid = "";
const char* password = "";
WebServer server(80); //--> Server on port 80
int readsuccess;
byte readcard[4];
char str[32] = "";
String StrUID;
String httpGETRequest(const char* serverName) {
HTTPClient http;
// Your IP address with path or Domain name with URL path
http.begin(serverName);
http.addHeader("Content-Type", "application/x-www-form-urlencoded");
// Send HTTP POST request
int httpResponseCode = http.GET();
String payload = "{}";
if (httpResponseCode>0) {
Serial.print("HTTP Response code: ");
Serial.println(httpResponseCode);
payload = http.getString();
Serial.println(payload);
else {
Serial.print("Error code: ");
http.end();
return payload;
//-----------------------------------------------------------------------------------------------SETUP--------------------------------------------------------------------------------------//
Serial.begin(115200); //--> Initialize serial communications with the PC
SPI.begin(); //--> Init SPI bus
mfrc522.PCD_Init(); //--> Init MFRC522 card
WiFi.begin(ssid, password); //--> Connect to your WiFi router
Serial.println("");
pinMode(ON_Board_LED,OUTPUT);
digitalWrite(ON_Board_LED, HIGH); //--> Turn off Led On Board
//----------------------------------------Wait for connection
Serial.print("Connecting");
Serial.print(".");
//----------------------------------------Make the On Board Flashing LED on the process of connecting to the wifi router.
digitalWrite(ON_Board_LED, LOW);
delay(250);
delay(250);
digitalWrite(ON_Board_LED, HIGH); //--> Turn off the On Board LED when it is connected to the wifi router.
//----------------------------------------If successfully connected to the wifi router, the IP Address that will be visited is displayed in the serial monitor
Serial.println("");
Serial.print("Successfully connected to : ");
Serial.println(ssid);
Serial.print("IP address: ");
Serial.println("Please tag a card or keychain to see the UID !");
Serial.println("");
// put your main code here, to run repeatedly
readsuccess = getid();
if(readsuccess) {
HTTPClient http; //Declare object of class HTTPClient
String UIDresultSend, postData;
UIDresultSend = StrUID;
//Post Data
postData = "UIDresult=" + UIDresultSend;
http.begin("http://192.168......./......../getUID.php");  //Specify request destination
http.addHeader("Content-Type", "application/x-www-form-urlencoded"); //Specify content-type header
int httpCode = http.POST(postData);   //Send the request
String payload = http.getString();    //Get the response payload
Serial.println(UIDresultSend);
Serial.println(httpCode);   //Print HTTP return code
Serial.println(payload);    //Print request response payload
http.end();  //Close connection
httpGETRequest("http://192.168....../......../readtag2.php");
//----------------------------------------Procedure for reading and obtaining a UID from a card or keychain---------------------------------------------------------------------------------//
int getid() {
if(!mfrc522.PICC_IsNewCardPresent()) {
return 0;
if(!mfrc522.PICC_ReadCardSerial()) {
return 0;
Serial.print("THE UID OF THE SCANNED CARD IS : ");
for(int i=0;i<4;i++){
readcard[i]=mfrc522.uid.uidByte[i]; //storing the UID of the tag in readcard
array_to_string(readcard, 4, str);
StrUID = str;
mfrc522.PICC_HaltA();
return 1;
//----------------------------------------Procedure to change the result of reading an array UID into a string------------------------------------------------------------------------------//
void array_to_string(byte array[], unsigned int len, char buffer[]) {
for (unsigned int i = 0; i < len; i++)
byte nib1 = (array[i] >> 4) & 0x0F;
byte nib2 = (array[i] >> 0) & 0x0F;
buffer[i*2+0] = nib1 < 0xA ? '0' + nib1 : 'A' + nib1 - 0xA;
buffer[i*2+1] = nib2 < 0xA ? '0' + nib2 : 'A' + nib2 - 0xA;
buffer[len*2] = '\0';
My Serial Monitor
23:18:48.137 ->
23:18:59.428 -> THE UID OF THE SCANNED CARD IS : 421F0DD4
23:19:00.340 -> 200
23:19:00.340 ->
23:19:01.355 -> HTTP Response code: 200
23:19:01.355 -> alinan deger
23:19:01.355 -> <?php 23:19:01.355 -> $Write="<?php $" . "UIDresult=''; " . "echo $" . "UIDresult;" . " ?>";
23:19:01.355 -> file_put_contents('UIDContainer.php',$Write);
23:19:01.355 -> ?>
23:19:01.355 ->
23:19:01.355 ->
23:19:01.355 ->
23:19:01.355 ->
23:19:01.355 ->
23:19:01.355 ->
23:19:01.355 ->
23:19:01.355 ->
23:19:01.355 ->
23:19:01.395 ->
23:19:01.395 ->
23:19:01.395 ->
23:19:01.395 ->
23:19:01.395 ->
23:19:01.395 ->
23:19:01.395 ->
23:19:01.395 ->
23:19:01.395 ->
23:19:01.395 ->
23:19:01.395 ->
23:19:01.395 ->
23:19:01.395 ->
23:19:01.395 ->
23:19:01.395 ->
23:19:01.395 -> ID
23:19:01.395 -> :
23:19:01.436 -> --------
23:19:01.436 ->
23:19:01.436 -> <tr
23:19:01.436 -> Name
23:19:01.436 -> :
23:19:01.436 ->
Use [color = red]code tags[/color] (the </> icon above the compose window) to make it easier to read and copy for examination
