ESP32 Async Webserver, Updating Variables with Buttons and Radio Buttons
Hello everyone,
i use this tutorial as basis for my program. It works pretty well.
My problem is i want to use "Refresh" Buttons to update some variables from the main-code to the html code and also use Radio Buttons (or similar input) to change some variables in the main-code
I read about AJAX/jQuery but i am really new into this so this is what i tried.
Since my HTML code is pretty long im going to post the necessary bits and if wanted i can post everything
<!DOCTYPE HTML>
<html>
<head>
  <title>ESP Input Form</title>
  <meta name="viewport" content="width=device-width, initial-scale=1">
  <style>
  </style>
  </head>
  <body>
  <h2>Musik f&uuml;r Geh&ouml;rlose</h2>
  <h3><u>Generelle Einstellungen:</u></h3>
  <form action="/get" class="radio">
    <h4>DC-Offset (current value %dcOffset%)</h4>
    <input type="button" value="Measure" onclick="measure()">
    <input type="button" value="Kalibieren" onclick="kalibieren()">
  </form>
  <h4>Zeige Peaks:</h4>
    <input type="radio" id="on" name="show_peaks" value="on">
    <label for="on">An</label>
    <input type="radio" id="off" name="show_peaks" value="off">
    <label for="off">Aus</label>
    <input type="submit" value="Speichern" onclick="return RadioValidator()>
  </form>
  <script>
    function RadioValidator() {
      if(document.getElementById('on').checked) {
        show_peaks = true;
      else if(document.getElementById('off').checked) {
        show_peaks = false;
  </script>
</body>
</html>
With the script function RadioValidator i want to change the variable in the code but its not really working.
The %DC_Offset% variable should be changed via a the Measure Button which maybe could work similar to the script function.
I also tried to change the %DC_Offset% variable like this which should search for the variable and replace it (but it didnt work):
String processor(const String& var){
  //Serial.println(var);
  if(var == "dcOffset"){
    return "changed_dcOffset";
  return String();
If there are any questions, feel free to ask.
Thanks for your help
Greetings,
Xenoshell
