ESP32 AsyncWebServer with temperature and PH
AsyncWebServer with sensors for temperature (DS18B20) and pH (PH-4502C).
The program must display the received data in an HTML server.
I need to do this program for my graduation.
Can someone help me with this project?
#indef ESP32
  #include <WiFi.h>
#else
  #include <Arduino.h>
  #include <Hash.h>
  #include <ESPAsyncTCP.h>
  #include <ESPAsyncWebServer.h>
#endif
#include <OneWire.h>
#include <DallasTemperature.h>
#define SensorPin A0
#define Offset 0.00
#define LED13
#define samplingInterval 20
#define printInterval 800
#define ArrayLenth 40
int pHArray[ArrayLenth];
int pHArrayIndex=0;
#define tempOffSet 0.00
#define ONE_WIRE_BUS 4  // Data wire is connected to GPIO 4
OneWire oneWire(ONE_WIRE_BUS); // Setup a oneWire instance to communicate with any OneWire devices
DallasTemperature sensors(&oneWire);
// Pass our oneWire reference to Dallas Temperature sensor
// Replace with your network credentials
const char* ssid = "xxxxxxxx";
const char* password = "xxxxxxxx";
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
  ///// Read pH Regularly //////
  static unsigned long samplingTime = millis();
  static unsigned long printTime = millis();
  static float pHValue,voltage;
  if(millis()-samplingTime > samplingInterval)
      pHArray[pHArrayIndex++]=analogRead(SensorPin);
      if(pHArrayIndex==ArrayLenth)pHArrayIndex=0;
      voltage = avergearray(pHArray, ArrayLenth)*5.0/1024;
      pHValue = 3.5*voltage+Offset;
      samplingTime=millis();
if(find(message,"getT")){
      float temp = 0;
      sensors.requestTemperatures();          // Send the command to get temperatures
      temp = sensors.getTempCByIndex(0);
      if(temp==85)
        sendData("\nTE1001");                 //Temperature ERROR CODE for INITIALIZE
      else if(temp==0 || temp==-127)
        sendData("\nTE1002");                  //Temperature ERROR CODE for NOT CONNECTED
      else{
        String temperature = "";
        temperature+=temp+tempOffSet;
        sendData("\n"+temperature);
    }else
    if(find(message,"getP")){
      //sending ph level:
      if(pHValue==0){
        sendData("\nPE1001");                 //pH ERROR CODE for NOT OPEN
      }else{
        String ph = "";
        ph+=pHValue;
        sendData("\n"+ph);
    }else if(find(message,"pHOff")){
      //sending ph level:
      digitalWrite(12,0);
    }else if(find(message,"pHOn")){
      //sending ph level:
      digitalWrite(12,1);
    else{
      sendData("\nErrRead");                 //Command ERROR CODE for UNABLE TO READ
  delay(responseTime);
double avergearray(int* arr, int number){
  int i;
  int max,min;
  double avg;
  long amount=0;
  if(number<=0){
    Serial.println("Error number for the array to avraging!/n");
    return 0;
  if(number<5){   //less than 5, calculated directly statistics
    for(i=0;i<number;i++){
      amount+=arr[i];
    avg = amount/number;
    return avg;
  }else{
    if(arr[0]<arr[1]){
      min = arr[0];max=arr[1];
    else{
      min=arr[1];max=arr[0];
    for(i=2;i<number;i++){
      if(arr[i]<min){
        amount+=min;        //arr<min
        min=arr[i];
      }else {
        if(arr[i]>max){
          amount+=max;    //arr>max
          max=arr[i];
        }else{
          amount+=arr[i]; //min<=arr<=max
      }//if
    }//for
    avg = (double)amount/(number-2);
  }//if
  return avg;
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
  <meta name="viewport" content="width=device-width, initial-scale=1">
  <link rel="stylesheet" href="https://use.fontawesome.com/releases/v5.7.2/css/all.css" integrity="sha384-fnmOCqbTlWIlj8LyTjo7mOUStjsKC4pOpQbqyi7RrhN7udi9RwhKkMHpvLbHG9Sr" crossorigin="anonymous">
  <style>
    html {
     font-family: Arial;
     display: inline-block;
     margin: 0px auto;
     text-align: center;
    h2 { font-size: 3.0rem; }
    p { font-size: 3.0rem; }
    .units { font-size: 1.2rem; }
    .ds-labels{
      font-size: 1.5rem;
      vertical-align:middle;
      padding-bottom: 15px;
  </style>
</head>
<body>
  <h2>ESP DS18B20 and PH Server</h2>
  <p>
    <i class="fas fa-thermometer-half" style="color:#059e8a;"></i>
    <span class="ds-labels">Temperature Celsius</span>
    <span id="temperaturec">%TEMPERATUREC%</span>
    <sup class="units">&deg;C</sup>
  </p>
  <p>
    <span class="ds-labels">pH</span>
    <span id="pH">%TpH%</span>
    <sup class="units">&deg;F</sup>
  </p>
</body>
<script>
setInterval(function ( ) {
  var xhttp = new XMLHttpRequest();
  xhttp.onreadystatechange = function() {
    if (this.readyState == 4 && this.status == 200) {
      document.getElementById("temperaturec").innerHTML = this.responseText;
  xhttp.open("GET", "/temperaturec", true);
  xhttp.send();
}, 10000) ;
      document.getElementById("pH").innerHTML = this.responseText;
  xhttp.open("GET", "/pH", true);
  xhttp.send();
}, 10000) ;
</script>
</html>)rawliteral";
// Replaces placeholder with DHT values
String processor(const String& var){
  //Serial.println(var);
  if(var == "TEMPERATUREC"){
    return readDSTemperatureC();
  else if(var == "pH"){
    return readpH();
  return String();
void setup(){
  // Serial port for debugging purposes
  // Start up the DS18B20 library
  sensors.begin();
  // Connect to Wi-Fi
  WiFi.begin(ssid, password);
  Serial.println("Connecting to WiFi");
    Serial.print(".");
  // Print ESP Local IP Address
  // Route for root / web page
  server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/html", index_html, processor);
  server.on("/temperaturec", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/plain", readDSTemperatureC().c_str());
  server.on("/temperaturef", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/plain", readpH().c_str());
  // Start server
  server.begin();
void loop(){
It seems that you did not Read this before posting a programming question so the code you posted has been partly turned into italics. Please read the topic linked to and add code tags to your posted code
What is the program supposed to do and what does it actually do ?
Where did you get the code ?
This code is from here:https://randomnerdtutorials.com/esp32-ds18b20-temperature-arduino-ide/?fbclid=IwAR3XwB4rfYxk9Vgnl2lal1ffXOjn2XYPhdzRjnK2WsOI7KyGB6-tJNKeXFw, but i also added a program for PH sensor.
"I need to do this program for my graduation."
You might start by getting the sensors to output the data you want, then incorporate it in a web page. What have you tried so far that doesn't work?
This program i used for my sensors. But i don’t know how to incorporate them in web page. That’s my problem.
Temperature program
// GPIO where the DS18B20 is connected to
const int oneWireBus = 4;
OneWire oneWire(oneWireBus);
  // Start the Serial Monitor
  // Start the DS18B20 sensor
  sensors.begin();
  float temperatureC = sensors.getTempCByIndex(0);
  float temperatureF = sensors.getTempFByIndex(0);
  Serial.print(temperatureC);
  Serial.println("ºC");
  Serial.print(temperatureF);
  Serial.println("ºF");
  delay(5000);
PH program
#define SensorPin A0 //pH meter Analog output to Arduino Analog Input 0
#define Offset 0.00 //deviation compensate
#define ArrayLenth 40 //times of collection
int pHArray[ArrayLenth]; //Store the average value of the sensor feedback
int pHArrayIndex=0;
void setup(void)
Serial.println("pH meter experiment!"); //Test the serial monitor
void loop(void)
if(millis() - printTime > printInterval) //Every 800 milliseconds, print a numerical, convert the state of the LED indicator
Serial.print("Voltage:");
Serial.print(voltage,2);
Serial.print(" pH value: ");
Serial.println(pHValue,2);
printTime=millis();
int i;
int max,min;
double avg;
long amount=0;
if(number<=0){
return 0;
amount+=arr[i];
return avg;
}else{
if(arr[0]<arr[1]){
"This program i used for my sensors. But i don't know how to incorporate them in web page. That's my problem."
Have you looked at all the web server examples that are available? I think I've seen some that collect data and send it back to the client in/to a web page.
