I'm trying to implement buttons to control avrc commands (play, pause, etc) using the bluetooth library below (220 ohm pull up resistor and button on pin 22 of the esp32s).
#include "BluetoothA2DPSink.h"
#include "LiquidCrystal.h"
LiquidCrystal lcd(19, 23, 18, 17, 16, 15);
BluetoothA2DPSink a2dp_sink;
bool is_active = true;
const int PlayButton = 22;
int Play_button_state = 0;
void avrc_metadata_callback(uint8_t id, const uint8_t *text) {
char lcd_buf[33]; // Check the size you need
char lcd_buf1[33]; // Check the size you need
if (id == 0x1)
snprintf(lcd_buf, 32, "%s ", text);
if (id == 0x2)
snprintf(lcd_buf1, 32, "%s ", text);
lcd.setCursor(0, 0);
lcd.print(lcd_buf);
lcd.setCursor(0, 1);
lcd.print(lcd_buf1);
Serial.printf("==> AVRC metadata rsp: attribute id 0x%x, %s\n", id, text);
a2dp_sink.set_avrc_metadata_callback(avrc_metadata_callback);
a2dp_sink.start("MyMusic");
lcd.begin(16, 2);
pinMode(PlayButton, INPUT);
{ for (int positionCounter = 0; positionCounter < 16; positionCounter++) {
// scroll one position left:
lcd.scrollDisplayLeft();
// wait a bit:
delay(350);
// digitalRead function stores the Push button state
// in variable push_button_state
int Play_button_state = digitalRead(PlayButton);
// if condition checks if push button is pressed
// if pressed LED will turn on otherwise remain off
if ( Play_button_state == HIGH ){
Serial.println("play");
a2dp_sink.play();
But I get the following error.
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\marky\OneDrive\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\marky\OneDrive\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\marky\OneDrive\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none -ide-version=10819 -build-path C:\Users\marky\AppData\Local\Temp\arduino_build_839765 -warnings=none -build-cache C:\Users\marky\AppData\Local\Temp\arduino_cache_151077 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esptool_py.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.0.0 -verbose C:\Users\marky\OneDrive\Documents\Arduino\sketch_oct07anearlythere2\sketch_oct07anearlythere2.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\marky\OneDrive\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\marky\OneDrive\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\marky\OneDrive\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none -ide-version=10819 -build-path C:\Users\marky\AppData\Local\Temp\arduino_build_839765 -warnings=none -build-cache C:\Users\marky\AppData\Local\Temp\arduino_cache_151077 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esptool_py.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.0.0 -verbose C:\Users\marky\OneDrive\Documents\Arduino\sketch_oct07anearlythere2\sketch_oct07anearlythere2.ino
Using board 'esp32' from platform in folder: C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6
Using core 'esp32' from platform in folder: C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6
cmd /c if exist "C:\\Users\\marky\\OneDrive\\Documents\\Arduino\\sketch_oct07anearlythere2\\partitions.csv" copy /y "C:\\Users\\marky\\OneDrive\\Documents\\Arduino\\sketch_oct07anearlythere2\\partitions.csv" "C:\\Users\\marky\\AppData\\Local\\Temp\\arduino_build_839765\\partitions.csv"
cmd /c if not exist "C:\\Users\\marky\\AppData\\Local\\Temp\\arduino_build_839765\\partitions.csv" copy "C:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\tools\\partitions\\default.csv" "C:\\Users\\marky\\AppData\\Local\\Temp\\arduino_build_839765\\partitions.csv"
Detecting libraries used...
"C:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "C:\\Users\\marky\\AppData\\Local\\Temp\\arduino_build_839765\\sketch\\sketch_oct07anearlythere2.ino.cpp" -o nul
Alternatives for BluetoothA2DPSink.h: [ESP32-A2DP-main@1.0]
ResolveLibrary(BluetoothA2DPSink.h)
-> candidates: [ESP32-A2DP-main@1.0]
"C:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\Arduino\\libraries\\ESP32-A2DP-main\\src" "C:\\Users\\marky\\AppData\\Local\\Temp\\arduino_build_839765\\sketch\\sketch_oct07anearlythere2.ino.cpp" -o nul
Alternatives for LiquidCrystal.h: [LiquidCrystal@1.0.7]
ResolveLibrary(LiquidCrystal.h)
-> candidates: [LiquidCrystal@1.0.7]
"C:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\Arduino\\libraries\\ESP32-A2DP-main\\src" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\libraries\\LiquidCrystal\\src" "C:\\Users\\marky\\AppData\\Local\\Temp\\arduino_build_839765\\sketch\\sketch_oct07anearlythere2.ino.cpp" -o nul
Using cached library dependencies for file: C:\Users\marky\OneDrive\Documents\Arduino\libraries\ESP32-A2DP-main\src\BluetoothA2DPSink.cpp
Using cached library dependencies for file: C:\Users\marky\OneDrive\Documents\Arduino\libraries\ESP32-A2DP-main\src\BluetoothA2DPSource.cpp
Using cached library dependencies for file: C:\Users\marky\OneDrive\Documents\Arduino\libraries\ESP32-A2DP-main\src\SoundData.cpp
Using cached library dependencies for file: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries\LiquidCrystal\src\LiquidCrystal.cpp
Generating function prototypes...
"C:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\Arduino\\libraries\\ESP32-A2DP-main\\src" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\libraries\\LiquidCrystal\\src" "C:\\Users\\marky\\AppData\\Local\\Temp\\arduino_build_839765\\sketch\\sketch_oct07anearlythere2.ino.cpp" -o "C:\\Users\\marky\\AppData\\Local\\Temp\\arduino_build_839765\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\marky\\AppData\\Local\\Temp\\arduino_build_839765\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\Arduino\\libraries\\ESP32-A2DP-main\\src" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\libraries\\LiquidCrystal\\src" "C:\\Users\\marky\\AppData\\Local\\Temp\\arduino_build_839765\\sketch\\sketch_oct07anearlythere2.ino.cpp" -o "C:\\Users\\marky\\AppData\\Local\\Temp\\arduino_build_839765\\sketch\\sketch_oct07anearlythere2.ino.cpp.o"
sketch_oct07anearlythere2:52:1: error: expected unqualified-id before '{' token
Using library ESP32-A2DP-main at version 1.0 in folder: C:\Users\marky\OneDrive\Documents\Arduino\libraries\ESP32-A2DP-main
Using library LiquidCrystal at version 1.0.7 in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries\LiquidCrystal
exit status 1
Something dumb I'm sure, but any help would be greatly appreciated.
Cheers.
