Hello I have been trying to make an esp32 based bluetooth gamepad that has 4 momentary push buttons and 2 joysticks. But I can't to get it to work with my MacBook. The main problem that I am facing is that the esp32 pairs with the MacBook but nothing gets registered neither the button presses nor the joystick movements. The code that is supposed to work is below. Thank you for any kind of help in advance.
#include <Arduino.h>
#include <BleGamepad.h>
//ABXY BUTTONS
#define X_BUTTON 23 // A
#define CIRCLE_BUTTON 22 // B
#define TRIANGLE_BUTTON 21 // Y
#define SQUARE_BUTTON 19 // X
//TRIGGERS
#define R1_BUTTON 0
#define R2_BUTTON 0
#define L1_BUTTON 0
#define L2_BUTTON 0
//MENU BUTTONS
#define START_BUTTON 0
#define SELECT_BUTTON 0
#define PS_BUTTON 0
//JOYSTICKS BUTTONS
#define R3_BUTTON 0
#define L3_BUTTON 0
//JOYSTICKS
#define LEFT_VRX_JOYSTICK 15
#define LEFT_VRY_JOYSTICK 4
#define RIGHT_VRX_JOYSTICK 0
#define RIGHT_VRY_JOYSTICK 0
#define NUM_BUTTONS 13
//The order of these three arrays matters a lot, be carefully when changing them
int buttonsPins[NUM_BUTTONS] = {X_BUTTON, CIRCLE_BUTTON, TRIANGLE_BUTTON, SQUARE_BUTTON,
R1_BUTTON, R2_BUTTON, L1_BUTTON, L2_BUTTON,
START_BUTTON, SELECT_BUTTON, PS_BUTTON,
R3_BUTTON, L3_BUTTON};
//There is not buttons for Y and Z
int androidGamepadButtons[NUM_BUTTONS] = {1, 2, 3, 4, 8, 10, 7, 9, 12, 11, 13, 15, 14};
int PS1GamepadButtons[NUM_BUTTONS] = {2, 3, 4, 1, 6, 8, 5, 7, 10, 9, 13, 12, 11};
int PCGamepadButtons[NUM_BUTTONS] = {1, 2, 4, 3, 6, 8, 5, 7, 10, 9, 0, 12, 11};
uint16_t leftVrxJoystickLecture = 0;
uint16_t leftVryJoystickLecture = 0;
uint16_t rightVrxJoystickLecture = 0;
uint16_t rightVryJoystickLecture = 0;
uint16_t leftVrxJoystickValue = 0;
uint16_t leftVryJoystickValue = 0;
uint16_t rightVrxJoystickValue = 0;
uint16_t rightVryJoystickValue = 0;
typedef enum{ANDROID, PS1, PC} GamepadModes;
GamepadModes gamepadMode = ANDROID;
BleGamepad bleGamepad("Maker101 Gamepad", "Maker101 Home");
BleGamepadConfiguration bleGamepadConfig;
for(int i=0; i<NUM_BUTTONS; i++){
pinMode(buttonsPins[i], INPUT_PULLUP);
bleGamepadConfig.setAutoReport(false);
bleGamepadConfig.setControllerType(CONTROLLER_TYPE_GAMEPAD); // CONTROLLER_TYPE_JOYSTICK, CONTROLLER_TYPE_GAMEPAD (DEFAULT), CONTROLLER_TYPE_MULTI_AXIS
bleGamepadConfig.setVid(0xe502);
bleGamepadConfig.setPid(0xabcd);
bleGamepadConfig.setHatSwitchCount(4);
bleGamepad.begin(&bleGamepadConfig);
if(bleGamepad.isConnected()){
//Joysticks lecture
leftVrxJoystickLecture = analogRead(LEFT_VRX_JOYSTICK);
leftVryJoystickLecture = analogRead(LEFT_VRY_JOYSTICK);
rightVrxJoystickLecture = analogRead(RIGHT_VRX_JOYSTICK);
rightVryJoystickLecture = analogRead(RIGHT_VRY_JOYSTICK);
//Compute joysticks value
leftVrxJoystickValue = map(leftVrxJoystickLecture, 4095, 0, 0, 32737);
leftVryJoystickValue = map(leftVryJoystickLecture, 0, 4095, 0, 32737);
rightVrxJoystickValue = map(rightVrxJoystickLecture, 4095, 0, 0, 32737);
rightVryJoystickValue = map(rightVryJoystickLecture, 0, 4095, 0, 32737);
switch(gamepadMode){
case ANDROID:
if(!digitalRead(buttonsPins[i])){
bleGamepad.press(androidGamepadButtons[i]);
else{
bleGamepad.release(androidGamepadButtons[i]);
joysticksHandlerForMobile(leftVrxJoystickValue, leftVryJoystickValue, rightVrxJoystickValue, rightVryJoystickValue);
case PS1:
bleGamepad.press(PS1GamepadButtons[i]);
else{
bleGamepad.release(PS1GamepadButtons[i]);
case PC:
bleGamepad.press(PCGamepadButtons[i]);
else{
bleGamepad.release(PCGamepadButtons[i]);
joysticksHandlerForPC(leftVrxJoystickValue, leftVryJoystickValue, rightVrxJoystickValue, rightVryJoystickValue);
bleGamepad.sendReport();
void joysticksHandlerForMobile(uint16_t leftVrx, uint16_t leftVry, uint16_t rightVrx, uint16_t rightVry){
bleGamepad.setLeftThumb(leftVrx, leftVryJoystickValue);
bleGamepad.setRightThumb(rightVrxJoystickValue, rightVryJoystickValue);
void joysticksHandlerForPC(uint16_t leftVrx, uint16_t leftVry, uint16_t rightVrx, uint16_t rightVry){
bleGamepad.setX(leftVrxJoystickValue);
bleGamepad.setY(leftVryJoystickValue);
bleGamepad.setZ(rightVrxJoystickValue);
bleGamepad.setRX(rightVryJoystickValue);
