ESP32 ble mouse fails to compile
Hello,
I wanted to try the bluetooth mouse from this example: https://github.com/T-vK/ESP32-BLE-Mouse
But it does not compile. I get following errors:
c:\Users\roger\Documents\Arduino\libraries\ESP32-BLE-Mouse-0.3.1\BleMouse.cpp: In static member function 'static void BleMouse::taskServer(void*)':
c:\Users\roger\Documents\Arduino\libraries\ESP32-BLE-Mouse-0.3.1\BleMouse.cpp:143:37: error: cannot convert 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'String'
  143 |   BLEDevice::init(bleMouseInstance->deviceName);
      |                                     std::string {aka std::__cxx11::basic_string<char>}
In file included from c:\Users\roger\Documents\Arduino\libraries\ESP32-BLE-Mouse-0.3.1\BleMouse.cpp:1:
C:\Users\roger\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\BLE\src/BLEDevice.h:41:27: note:   initializing argument 1 of 'static void BLEDevice::init(String)'
   41 |   static void init(String deviceName);                                                            // Initialize the local BLE environment.
c:\Users\roger\Documents\Arduino\libraries\ESP32-BLE-Mouse-0.3.1\BleMouse.cpp:151:50: error: no matching function for call to 'BLECharacteristic::setValue(std::string&)'
  151 |   bleMouseInstance->hid->manufacturer()->setValue(bleMouseInstance->deviceManufacturer);
In file included from C:\Users\roger\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\BLE\src/BLEServer.h:23,
                 from C:\Users\roger\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\BLE\src/BLEDevice.h:21:
C:\Users\roger\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\BLE\src/BLECharacteristic.h:83:8: note: candidate: 'void BLECharacteristic::setValue(double&)'
   83 |   void setValue(double &data64);
C:\Users\roger\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\BLE\src/BLECharacteristic.h:83:25: note:   no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'double&'
C:\Users\roger\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\BLE\src/BLECharacteristic.h:82:8: note: candidate: 'void BLECharacteristic::setValue(float&)'
   82 |   void setValue(float &data32);
C:\Users\roger\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\BLE\src/BLECharacteristic.h:82:24: note:   no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'float&'
C:\Users\roger\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\BLE\src/BLECharacteristic.h:81:8: note: candidate: 'void BLECharacteristic::setValue(int&)'
   81 |   void setValue(int &data32);
C:\Users\roger\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\BLE\src/BLECharacteristic.h:81:22: note:   no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'int&'
C:\Users\roger\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\BLE\src/BLECharacteristic.h:80:8: note: candidate: 'void BLECharacteristic::setValue(uint32_t&)'
   80 |   void setValue(uint32_t &data32);
C:\Users\roger\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\BLE\src/BLECharacteristic.h:80:27: note:   no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'uint32_t&' {aka 'long unsigned int&'}
C:\Users\roger\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\BLE\src/BLECharacteristic.h:79:8: note: candidate: 'void BLECharacteristic::setValue(uint16_t&)'
   79 |   void setValue(uint16_t &data16);
C:\Users\roger\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\BLE\src/BLECharacteristic.h:79:27: note:   no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'uint16_t&' {aka 'short unsigned int&'}
C:\Users\roger\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\BLE\src/BLECharacteristic.h:77:8: note: candidate: 'void BLECharacteristic::setValue(uint8_t*, size_t)'
   77 |   void setValue(uint8_t *data, size_t size);
C:\Users\roger\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\BLE\src/BLECharacteristic.h:77:8: note:   candidate expects 2 arguments, 1 provided
C:\Users\roger\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\BLE\src/BLECharacteristic.h:78:8: note: candidate: 'void BLECharacteristic::setValue(String)'
   78 |   void setValue(String value);
C:\Users\roger\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\BLE\src/BLECharacteristic.h:78:24: note:   no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'String'
Multiple libraries were found for "BleMouse.h"
  Used: C:\Users\roger\Documents\Arduino\libraries\ESP32-BLE-Mouse-0.3.1
  Not used: C:\Users\roger\Documents\Arduino\libraries\ESP32-BLE-Mouse-master
exit status 1
Compilation error: exit status 1
I do not know what to make of it. I simply added the zipped library and opened the example. Any tips on what is going on here?
This thread solved it. Saw just after posting. :upside_down_face:
https://forum.arduino.cc/t/ble-mouse-example-compilation-error/1265845/2
