Good day, I am currently using my ESP32 as a Bluetooth server device which is retreiving data from my phone via an app I designed. My question is, is it possible to gain the MAC address or any unique identifier of my phone over Bluetooth without having to send specific pin codes? Basically I would like my esp32 to ping the device for it's unique identified and use it to turn on a green or red light. The current code I have is only for retreiving pins sent from an app over BLE. Help would be greatly appreciated!
This is my current code:
Based on Neil Kolban example for IDF: https://github.com/nkolban/esp32-snippets/blob/master/cpp_utils/tests/BLE%20Tests/SampleNotify.cpp
Ported to Arduino ESP32 by Evandro Copercini
updated by chegewara and MoThunderz
#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
#include <WiFi.h>
#include <HTTPClient.h>
const char *ssid = "L"; // Your Wi-Fi SSID
const char *password = "Leoleoleo12345"; // Your Wi-Fi password
const char *url = "https://databasefyp.000webhostapp.com/insert.php";
BLEServer* pServer = NULL;
BLECharacteristic* pCharacteristic = NULL;
BLECharacteristic* pCharacteristic_2 = NULL;
BLECharacteristic* pCharacteristic_3 = NULL;
BLECharacteristic* pCharacteristic_4 = NULL;
BLECharacteristic* pCharacteristic_5 = NULL;
BLEDescriptor *pDescr;
BLE2902 *pBLE2902;
bool deviceConnected = false;
bool oldDeviceConnected = false;
uint32_t value = 0;
// See the following for generating UUIDs:
// https://www.uuidgenerator.net/
#define SERVICE_UUID "4fafc201-1fb5-459e-8fcc-c5c9c331914b"
#define CHAR1_UUID "beb5483e-36e1-4688-b7f5-ea07361b26a8"
#define CHAR2_UUID "e3223119-9445-4e96-a4a1-85358c4046a2"
#define CHAR3_UUID "e3223119-9445-4e96-a4a1-85358c4046a3"
#define CHAR4_UUID "e3223119-9445-4e96-a4a1-85358c4046a4"
#define CHAR5_UUID "e3223119-9445-4e96-a4a1-85358c4046a5"
class MyServerCallbacks: public BLEServerCallbacks {
void onConnect(BLEServer* pServer) {
deviceConnected = true;
void onDisconnect(BLEServer* pServer) {
class CharacteristicCallBack_1: public BLECharacteristicCallbacks {
void onWrite(BLECharacteristic *pChar) override {
std::string pChar2_value_stdstr = pChar->getValue();
String pChar2_value_string = String(pChar2_value_stdstr.c_str());
int pChar2_value_int = pChar2_value_string.toInt();
Serial.println("pChar2: " + String(pChar2_value_int));
class CharacteristicCallBack_2: public BLECharacteristicCallbacks {
std::string pChar3_value_stdstr = pChar->getValue();
String pChar3_value_string = String(pChar3_value_stdstr.c_str());
int pChar3_value_int = pChar3_value_string.toInt();
Serial.println("pChar3: " + String(pChar3_value_int));
class CharacteristicCallBack_3: public BLECharacteristicCallbacks {
std::string pChar4_value_stdstr = pChar->getValue();
String pChar4_value_string = String(pChar4_value_stdstr.c_str());
int pChar4_value_int = pChar4_value_string.toInt();
Serial.println("pChar4: " + String(pChar4_value_int));
class CharacteristicCallBack_4: public BLECharacteristicCallbacks {
std::string pChar5_value_stdstr = pChar->getValue();
String pChar5_value_string = String(pChar5_value_stdstr.c_str());
int pChar5_value_int = pChar5_value_string.toInt();
Serial.println("pChar5: " + String(pChar5_value_int));
void makeHttpRequest(const char *url) {
HTTPClient http;
// Send an HTTP GET request to the specified URL
http.begin(url);
int httpResponseCode = http.GET();
if (httpResponseCode > 0) {
String response = http.getString();
Serial.print("HTTP Response Code: ");
Serial.println(httpResponseCode);
Serial.println("Response: " + response);
Serial.print("Error on HTTP request. Error code: ");
http.end();
// Create the BLE Device
BLEDevice::init("ESP32");
// Create the BLE Server
pServer = BLEDevice::createServer();
pServer->setCallbacks(new MyServerCallbacks());
// Create the BLE Service
BLEService *pService = pServer->createService(SERVICE_UUID);
// Create a BLE Characteristic
pCharacteristic = pService->createCharacteristic(
CHAR1_UUID,
BLECharacteristic::PROPERTY_NOTIFY
pCharacteristic_2 = pService->createCharacteristic(
CHAR2_UUID,
BLECharacteristic::PROPERTY_READ |
BLECharacteristic::PROPERTY_WRITE
pCharacteristic_3 = pService->createCharacteristic(
CHAR3_UUID,
pCharacteristic_4 = pService->createCharacteristic(
CHAR4_UUID,
pCharacteristic_5 = pService->createCharacteristic(
CHAR5_UUID,
// Create a BLE Descriptor
pDescr = new BLEDescriptor((uint16_t)0x2901);
pDescr->setValue("A very interesting variable");
pCharacteristic->addDescriptor(pDescr);
pBLE2902 = new BLE2902();
pBLE2902->setNotifications(true);
pCharacteristic->addDescriptor(pBLE2902);
// Add all Descriptors here
pCharacteristic_2->addDescriptor(new BLE2902());
pCharacteristic_2->setCallbacks(new CharacteristicCallBack_1());
pCharacteristic_3->addDescriptor(new BLE2902());
pCharacteristic_3->setCallbacks(new CharacteristicCallBack_2());
// After defining the desriptors, set the callback functions
pCharacteristic_4->addDescriptor(new BLE2902());
pCharacteristic_4->setCallbacks(new CharacteristicCallBack_3());
pCharacteristic_5->addDescriptor(new BLE2902());
pCharacteristic_5->setCallbacks(new CharacteristicCallBack_4());
// Start the service
pService->start();
// Start advertising
BLEAdvertising *pAdvertising = BLEDevice::getAdvertising();
pAdvertising->addServiceUUID(SERVICE_UUID);
pAdvertising->setScanResponse(false);
pAdvertising->setMinPreferred(0x0); // set value to 0x00 to not advertise this parameter
BLEDevice::startAdvertising();
Serial.println("Waiting a client connection to notify...");
// notify changed value
if (deviceConnected) {
pCharacteristic->setValue(value);
pCharacteristic->notify();
value++;
// disconnecting
if (!deviceConnected && oldDeviceConnected) {
delay(500); // give the bluetooth stack the chance to get things ready
pServer->startAdvertising(); // restart advertising
Serial.println("start advertising");
oldDeviceConnected = deviceConnected;
// connecting
if (deviceConnected && !oldDeviceConnected) {
// do stuff here on connecting
