Esp32 bluetooh error
Good day.
I have the following error when trying to connect to bluetooth from a cell phone.
Guru Meditation Error: Core 0 panic'ed (IntegerDivideByZero). Exception was unhandled.
Core 0 register dump:
PC : 0x4002f7c2 PS : 0x00060b30 A0 : 0x800268aa A1 : 0x3ffcbaf0
A2 : 0x00000000 A3 : 0x00000000 A4 : 0x3ffc8cb8 A5 : 0x3ffc8cbc
A6 : 0x3ffc8cc0 A7 : 0x3ffc8cc4 A8 : 0x8002f7ad A9 : 0x3ffcbad0
A10 : 0x3cdb3940 A11 : 0x00000007 A12 : 0x00060b20 A13 : 0x00000021
A14 : 0x00000074 A15 : 0x00000000 SAR : 0x0000001d EXCCAUSE: 0x00000006
EXCVADDR: 0x00000000 LBEG : 0x4000c46c LEND : 0x4000c477 LCOUNT : 0x00000000
ELF file SHA256: 0000000000000000
The following is the code that I am using.
//This example code is in the Public Domain (or CC0 licensed, at your option.)
//By Evandro Copercini - 2018
//This example creates a bridge between Serial and Classical Bluetooth (SPP)
//and also demonstrate that SerialBT have the same functionalities of a normal Serial
`#include "BluetoothSerial.h"
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run make menuconfig to and enable it
#endif
BluetoothSerial SerialBT;
SerialBT.begin("ESP32test"); //Bluetooth device name
Serial.println("The device started, now you can pair it with bluetooth!");
delay(20);
if (Serial.available()) {
SerialBT.write(Serial.read());
if (SerialBT.available()) {
Serial.write(SerialBT.read());
Could someone please tell me how to solve it, thanks.
Please explain more about what you are doing?
At what point do you see the error?
Your code compiles fine for my ESP32, my Android phone can see and pair with the ESP32. The app I use is Kai Morich's Serial Bluetooth Terminal and it can connect and communicate with the esp32.
Hello cattle dog. Thank you so much for taking the time to respond. Indeed it compiles correctly and is visible to my android cell phone, the problem persists when I try to pair from the android mobile it is impossible, when I look in real time on the serial monitor I see the error that I published in the first post.
There is nothing in your code to print
"Pairing Success" which is seen after "The device started, now you can pair it with bluetooth!"
Are you indeed posting the complete code you are running.
When I pair with my phone at that point in the code, I see no message about success.
What version of the esp core are you using? What is the version of BluetoothSerial.h being used?
I recommend that you up date the esp core to the latest in the board manager.
If that doesn't fix the issue, enable verbose output during compile and upload and post the complete messages. Do not post a picture, put just post the text.
hello cattledog. Thank you very much for the help you give me.
I have followed your recommendations.
I enable the build alerts and in them I see the version of the BluetoothSerial library
"Usando librería BluetoothSerial con versión 1.0 en la carpeta:"
Regarding the kernel version, I don't know where I can identify it or how I can update it, I have searched the internet for how to update it, but I don't understand if there is any procedure or guide.
The following are the messages at compile time:
Using board 'esp32doit-devkit-v1' from platform in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
Using core 'esp32' from platform in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
cmd /c if exist "C:\Users\User\OneDrive\Documentos\Arduino\SerialToSerialBT\partitions.csv" copy /y "C:\Users\User\OneDrive\Documentos\Arduino\SerialToSerialBT\partitions.csv" "C:\Users\User\AppData\Local\Temp\arduino\sketches\B6A69C3D4FD817381735B09C16F21D2F\partitions.csv"
cmd /c if not exist "C:\Users\User\AppData\Local\Temp\arduino\sketches\B6A69C3D4FD817381735B09C16F21D2F\partitions.csv" copy "C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\tools\partitions\default.csv" "C:\Users\User\AppData\Local\Temp\arduino\sketches\B6A69C3D4FD817381735B09C16F21D2F\partitions.csv"
Detectando las librerías usadas...
"C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="doitESP32devkitV1"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\doitESP32devkitV1" "C:\Users\User\AppData\Local\Temp\arduino\sketches\B6A69C3D4FD817381735B09C16F21D2F\sketch\SerialToSerialBT.ino.cpp" -o nul
Alternativas para BluetoothSerial.h: [BluetoothSerial@1.0]
ResolveLibrary(BluetoothSerial.h)
-> Candidatos: [BluetoothSerial@1.0]
"C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="doitESP32devkitV1"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\doitESP32devkitV1" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\BluetoothSerial\src" "C:\Users\User\AppData\Local\Temp\arduino\sketches\B6A69C3D4FD817381735B09C16F21D2F\sketch\SerialToSerialBT.ino.cpp" -o nul
Using cached library dependencies for file: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\BluetoothSerial\src\BluetoothSerial.cpp
Generating function prototypes...
"C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="doitESP32devkitV1"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\doitESP32devkitV1" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\BluetoothSerial\src" "C:\Users\User\AppData\Local\Temp\arduino\sketches\B6A69C3D4FD817381735B09C16F21D2F\sketch\SerialToSerialBT.ino.cpp" -o "C:\Users\User\AppData\Local\Temp\arduino\sketches\B6A69C3D4FD817381735B09C16F21D2F\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Users\User\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\User\AppData\Local\Temp\arduino\sketches\B6A69C3D4FD817381735B09C16F21D2F\preproc\ctags_target_for_gcc_minus_e.cpp"
Compilando el sketch...
"C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="doitESP32devkitV1"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\doitESP32devkitV1" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\BluetoothSerial\src" "C:\Users\User\AppData\Local\Temp\arduino\sketches\B6A69C3D4FD817381735B09C16F21D2F\sketch\SerialToSerialBT.ino.cpp" -o "C:\Users\User\AppData\Local\Temp\arduino\sketches\B6A69C3D4FD817381735B09C16F21D2F\sketch\SerialToSerialBT.ino.cpp.o"
Compilando librerías...
Compilando librería "BluetoothSerial"
Utilizando archivo previamente compilado: C:\Users\User\AppData\Local\Temp\arduino\sketches\B6A69C3D4FD817381735B09C16F21D2F\libraries\BluetoothSerial\BluetoothSerial.cpp.o
Compilando el núcleo...
Using precompiled core: C:\Users\User\AppData\Local\Temp\arduino\cores\5430c5c07ff6fa810d40a56793e033d4\core.a
Linking everything together...
"C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-gcc" -nostdlib "-LC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/lib" "-LC:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/ld" -T esp32_out.ld -T esp32.project.ld -T esp32.rom.ld -T esp32.peripherals.ld -T esp32.rom.libgcc.ld -T esp32.rom.spiram_incompatible_fns.ld -u esp_app_desc -u ld_include_panic_highint_hdl -u call_user_start_cpu0 -Wl,--gc-sections -Wl,-static -Wl,--undefined=uxTopUsedPriority -u __cxa_guard_dummy -u __cxx_fatal_exception -Wl,--start-group "C:\Users\User\AppData\Local\Temp\arduino\sketches\B6A69C3D4FD817381735B09C16F21D2F\sketch\SerialToSerialBT.ino.cpp.o" "C:\Users\User\AppData\Local\Temp\arduino\sketches\B6A69C3D4FD817381735B09C16F21D2F\libraries\BluetoothSerial\BluetoothSerial.cpp.o" "C:\Users\User\AppData\Local\Temp\arduino\cores\5430c5c07ff6fa810d40a56793e033d4\core.a" -lgcc -lesp_websocket_client -lwpa2 -ldetection -lesp_https_server -lwps -lhal -lconsole -lpe -lsoc -lsdmmc -lpthread -llog -lesp_http_client -ljson -lmesh -lesp32-camera -lnet80211 -lwpa_supplicant -lc -lmqtt -lcxx -lesp_https_ota -lulp -lefuse -lpp -lmdns -lbt -lwpa -lspiffs -lheap -limage_util -lunity -lrtc -lmbedtls -lface_recognition -lnghttp -ljsmn -lopenssl -lcore -lfatfs -lm -lprotocomm -lsmartconfig -lxtensa-debug-module -ldl -lesp_event -lesp-tls -lfd -lespcoredump -lesp_http_server -lfr -lsmartconfig_ack -lwear_levelling -ltcp_transport -llwip -lphy -lvfs -lcoap -lesp32 -llibsodium -lbootloader_support -ldriver -lcoexist -lasio -lod -lmicro-ecc -lesp_ringbuf -ldetection_cat_face -lapp_update -lespnow -lface_detection -lapp_trace -lnewlib -lbtdm_app -lwifi_provisioning -lfreertos -lfreemodbus -lethernet -lnvs_flash -lspi_flash -lc_nano -lexpat -lfb_gfx -lprotobuf-c -lesp_adc_cal -ltcpip_adapter -lstdc++ -Wl,--end-group -Wl,-EL -o "C:\Users\User\AppData\Local\Temp\arduino\sketches\B6A69C3D4FD817381735B09C16F21D2F/SerialToSerialBT.ino.elf"
"C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\Users\User\AppData\Local\Temp\arduino\sketches\B6A69C3D4FD817381735B09C16F21D2F/SerialToSerialBT.ino.bin" "C:\Users\User\AppData\Local\Temp\arduino\sketches\B6A69C3D4FD817381735B09C16F21D2F/SerialToSerialBT.ino.elf"
esptool.py v3.0-dev
"C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/gen_esp32part.exe" -q "C:\Users\User\AppData\Local\Temp\arduino\sketches\B6A69C3D4FD817381735B09C16F21D2F/partitions.csv" "C:\Users\User\AppData\Local\Temp\arduino\sketches\B6A69C3D4FD817381735B09C16F21D2F/SerialToSerialBT.ino.partitions.bin"
Usando librería BluetoothSerial con versión 1.0 en la carpeta: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\BluetoothSerial
"C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-size" -A "C:\Users\User\AppData\Local\Temp\arduino\sketches\B6A69C3D4FD817381735B09C16F21D2F/SerialToSerialBT.ino.elf"
El Sketch usa 932166 bytes (71%) del espacio de almacenamiento de programa. El máximo es 1310720 bytes.
Las variables Globales usan 31036 bytes (9%) de la memoria dinámica, dejando 296644 bytes para las variables locales. El máximo es 327680 bytes.
"C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0/esptool.exe" --chip esp32 --port "COM4" --baud 115200 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0xe000 "C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/partitions/boot_app0.bin" 0x1000 "C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/bin/bootloader_dio_80m.bin" 0x10000 "C:\Users\User\AppData\Local\Temp\arduino\sketches\B6A69C3D4FD817381735B09C16F21D2F/SerialToSerialBT.ino.bin" 0x8000 "C:\Users\User\AppData\Local\Temp\arduino\sketches\B6A69C3D4FD817381735B09C16F21D2F/SerialToSerialBT.ino.partitions.bin"
esptool.py v3.0-dev
Serial port COM4
Connecting........_
Chip is ESP32-D0WD-V3 (revision 3)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: e0:5a:1b:75:f0:04
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Compressed 8192 bytes to 47...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 1191.6 kbit/s)...
Hash of data verified.
Compressed 17120 bytes to 11164...
Writing at 0x00001000... (100 %)
Wrote 17120 bytes (11164 compressed) at 0x00001000 in 1.0 seconds (effective 131.6 kbit/s)...
Compressed 932288 bytes to 544027...
Writing at 0x00010000... (2 %)
Writing at 0x00014000... (5 %)
Writing at 0x00018000... (8 %)
Writing at 0x0001c000... (11 %)
Writing at 0x00020000... (14 %)
Writing at 0x00024000... (17 %)
Writing at 0x00028000... (20 %)
Writing at 0x0002c000... (23 %)
Writing at 0x00030000... (26 %)
Writing at 0x00034000... (29 %)
Writing at 0x00038000... (32 %)
Writing at 0x0003c000... (35 %)
Writing at 0x00040000... (38 %)
Writing at 0x00044000... (41 %)
Writing at 0x00048000... (44 %)
Writing at 0x0004c000... (47 %)
Writing at 0x00050000... (50 %)
Writing at 0x00054000... (52 %)
Writing at 0x00058000... (55 %)
Writing at 0x0005c000... (58 %)
Writing at 0x00060000... (61 %)
Writing at 0x00064000... (64 %)
Writing at 0x00068000... (67 %)
Writing at 0x0006c000... (70 %)
Writing at 0x00070000... (73 %)
Writing at 0x00074000... (76 %)
Writing at 0x00078000... (79 %)
Writing at 0x0007c000... (82 %)
Writing at 0x00080000... (85 %)
Writing at 0x00084000... (88 %)
Writing at 0x00088000... (91 %)
Writing at 0x0008c000... (94 %)
Writing at 0x00090000... (97 %)
Writing at 0x00094000... (100 %)
Wrote 932288 bytes (544027 compressed) at 0x00010000 in 49.8 seconds (effective 149.8 kbit/s)...
Compressed 3072 bytes to 128...
Writing at 0x00008000... (100 %)
Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.1 seconds (effective 396.4 kbit/s)...
Leaving...
Hard resetting via RTS pin...
In the serial monitor I have the following:
When I try to pair from the "bluetooth serial" app, the serial monitor automatically shows me the following:
ets Jul 29 2019 12:21:46
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:10124
load:0x40080400,len:5856
entry 0x400806a8
PC : 0x4002f7c2 PS : 0x00060130 A0 : 0x800268aa A1 : 0x3ffcbaf0
A10 : 0x3cdb3940 A11 : 0x00000007 A12 : 0x00060120 A13 : 0x00000021
A14 : 0x00000060 A15 : 0x00000000 SAR : 0x0000001d EXCCAUSE: 0x00000006
Backtrace: 0x4002f7c2:0x3ffcbaf0 0x400268a7:0x3ffcbb10 0x4015de1a:0x3ffcbb50 0x4008776e:0x3ffcbb70 0x40019d11:0x3ffcbba0 0x40055b4d:0x3ffcbbc0 0x401597e7:0x3ffcbbe0 0x40159df5:0x3ffcbc00 0x4008ff7e:0x3ffcbc30
Rebooting...
And in the SerialBluetooth app it shows me the following:
"Connection failed: read failed, socket might closed or timeout, read ret: -1"
Just to confirm, the code used is the one provided by the arduino IDE in its serialToSerialBT example:
#endif
delay(20);
If you look through the report carefully you see at the very beginning.
Then if you look carefully through the report foe versions od BluetoothSerial.h you find
The current version of the ESP32 arduino core is 2.07 and it includes BluetoothSerial.h version 2.0.
Use the boards manager of the IDE to upgrade to the latest core version.
Thank you very much in advance for your help.
I have followed your recommendations and I have already successfully updated the core.
Using board 'esp32doit-devkit-v1' from platform in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.7
Using core 'esp32' from platform in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.7
Usando librería BluetoothSerial con versión 2.0.0 en la carpeta: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.7\libraries\BluetoothSerial
I used one of the examples that the IDE gives me again.
//#define USE_PIN // Uncomment this to use PIN during pairing. The pin is specified on the line below
const char *pin = "1234"; // Change this to more secure PIN.
String device_name = "ESP32-BT-Slave";
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
#if !defined(CONFIG_BT_SPP_ENABLED)
#error Serial Bluetooth not available or not enabled. It is only available for the ESP32 chip.
#endif
  SerialBT.begin(device_name); //Bluetooth device name
  Serial.printf("The device with name \"%s\" is started.\nNow you can pair it with Bluetooth!\n", device_name.c_str());
  //Serial.printf("The device with name \"%s\" and MAC address %s is started.\nNow you can pair it with Bluetooth!\n", device_name.c_str(), SerialBT.getMacString()); // Use this after the MAC method is implemented
  #ifdef USE_PIN
    SerialBT.setPin(pin);
    Serial.println("Using PIN");
  #endif
  delay(20);
I keep getting the same error when I try to connect to the "Serial Bluetooth" app, resulting in the following error on the output monitor.
The device with name "ESP32-BT-Slave" is started.
PC      : 0x4002f7c2  PS      : 0x00060c30  A0      : 0x800268aa  A1      : 0x3ffcf030
A2      : 0x00000000  A3      : 0x00000000  A4      : 0x3ffcc808  A5      : 0x3ffcc80c
A6      : 0x3ffcc810  A7      : 0x3ffcc814  A8      : 0x8002f7ad  A9      : 0x3ffcf010
A10     : 0x3cdb3940  A11     : 0x00000007  A12     : 0x00060c20  A13     : 0x00000021
Backtrace: 0x4002f7bf:0x3ffcf030 0x400268a7:0x3ffcf050 0x4015c54e:0x3ffcf090 0x4008664c:0x3ffcf0b0 0x40019d11:0x3ffcf0e0 0x40055b4d:0x3ffcf100 0x401578bb:0x3ffcf120 0x40157f21:0x3ffcf140
ELF file SHA256: 31d1f1781cf674a9
Rebooting...
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
load:0x3fff0030,len:1184
load:0x40078000,len:13220
ho 0 tail 12 room 4
load:0x40080400,len:3028
entry 0x400805e4
Is it possible that the mobile phone is related to the error?
Good job on the update.
Possibly. It's certainly not the issue with the sketch.
What phone and Android Version are you using? Do you or a friend have another phone to try?
What board selection have you made for this chip.
Greetings.
The android version is 11.
I'm going to try to do a test on another mobile device.
Within the arduino ID at the top, select the option "DOIT ESP32 DEVKIT V1", in addition to this, on the back of the esp32 it has "ESP 23 DEVKIT V1" printed.
Thank you in advance for the time you invest in supporting me.
