ESP32 Bluetooth- LED's- Serial MP3
Hey guys I am very new to coding arduino. I am working on a little project using an ESP32 Bluetooth to trigger LED's and a sound via serial MP3.
My code is a mess of cobbled together code from around the internet. It is working a little and just trying to get some further guidance to make it work how I want it to fully.
The bluetooth is working. I am using an android serial bluetooth app to send signals to the ESP32 and it triggers it.
The issue I have is it's not doing what I expect/want with my code. I have 6 WS2811 LED's that I want to trigger a certain way.
For example "If BTData=1" I just want it to trigger the first 3 LED's.
"If BTData=2" I want the last 3 LED's triggered.
"If BTData=3" I want all 6 LED's triggered.
"If BTData=4" I want them to cascade from 1-6.
But when I send 1,2, or 3 it just triggers all 6 LED's. When I send 4 instead of cascading 1 through 6, it flashes 6 times.
The other issue is I am getting nothing from the MP3. I am trying to trigger a sound with the LED's. I only have one sound that I need triggered and I have just named it 001.mp3 and it's in the root folder of the SD Card. I have tried using different pins but I am not getting anything from that at this point.
Any help is greatly appreciated. Here is the code I am working with:
#include <BluetoothSerial.h>
#include "FastLED.h"
#include <SoftwareSerial.h>
#define ARDUINO_RX RX//should connect to TX of the Serial MP3 Player module
#define ARDUINO_TX TX//connect to RX of the module
SoftwareSerial mySerial(ARDUINO_RX, ARDUINO_TX);//init the serial protocol, tell to myserial wich pins are TX and RX
static int8_t Send_buf[8] = {0} ;//The MP3 player undestands orders in a 8 int string
                                 //0X7E FF 06 command 00 00 00 EF;(if command =01 next song order)
#define NEXT_SONG 0X01
#define PREV_SONG 0X02
#define CMD_PLAY_W_INDEX 0X03 //DATA IS REQUIRED (number of song)
#define VOLUME_UP_ONE 0X04
#define VOLUME_DOWN_ONE 0X05
#define CMD_SET_VOLUME 0X1E//DATA IS REQUIRED (number of volume from 0 up to 30(0x1E))
#define SET_DAC 0X17
#define CMD_PLAY_WITHVOLUME 0X22 //data is needed  0x7E 06 22 00 xx yy EF;(xx volume)(yy number of song)
#define CMD_SEL_DEV 0X09 //SELECT STORAGE DEVICE, DATA IS REQUIRED
                #define DEV_TF 0X02 //HELLO,IM THE DATA REQUIRED
#define SLEEP_MODE_START 0X0A
#define SLEEP_MODE_WAKEUP 0X0B
#define CMD_RESET 0X0C//CHIP RESET
#define CMD_PLAY 0X0D //RESUME PLAYBACK
#define CMD_PAUSE 0X0E //PLAYBACK IS PAUSED
#define CMD_PLAY_WITHFOLDER 0X0F//DATA IS NEEDED, 0x7E 06 0F 00 01 02 EF;(play the song with the directory \01\002xxxxxx.mp3
#define STOP_PLAY 0X16
#define PLAY_FOLDER 0X17// data is needed 0x7E 06 17 00 01 XX EF;(play the 01 folder)(value xx we dont care)
#define SET_CYCLEPLAY 0X19//data is needed 00 start; 01 close
#define SET_DAC 0X17//data is needed 00 start DAC OUTPUT;01 DAC no output
#define NUM_LEDS 7
// Which pin are we using on the arduino to send data to the strip?
#define BRIGHTNESS 255
// Create a variable that will hold the current state of each of our LEDs.
CRGB leds[NUM_LEDS];
#define ledPIN 21
#define ledPIN 22
#define ledPIN 23
#define ledPIN 25
#define ledPIN 26
#define ledPIN 27
BluetoothSerial SerialBT;
byte BTData;
/* Check if Bluetooth configurations are enabled in the SDK */
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
void sendCommand(int8_t command, int16_t dat)
 delay(20);
 Send_buf[0] = 0x7e; //starting byte
 Send_buf[1] = 0xff; //version
 Send_buf[2] = 0x06; //the number of bytes of the command without starting byte and ending byte
 Send_buf[3] = command; //
 Send_buf[4] = 0x00;//0x00 = no feedback, 0x01 = feedback
 Send_buf[5] = (int8_t)(dat >> 8);//datah
 Send_buf[6] = (int8_t)(dat); //datal
 Send_buf[7] = 0xef; //ending byte
 for(uint8_t i=0; i<8; i++)//
   mySerial.write(Send_buf[i]) ;//send bit to serial mp3
   Serial.print(Send_buf[i],HEX);//send bit to serial monitor in pc
  pinMode(ledPIN, OUTPUT);
  SerialBT.begin("BT-1");
  Serial.println("Bluetooth Started! Ready to pair...");
  delay(20);//Wait chip initialization is complete
   sendCommand(CMD_SEL_DEV, DEV_TF);//select the TF card
delay(200);//wait for 200ms
  if(SerialBT.available())
    BTData = SerialBT.read();
    Serial.write(BTData);
  /* If received Character is 1, then turn ON the LED */
  /* You can also compare the received data with decimal equivalent */
  /* 48 for 0 and 49 for 1 */
  /* if(BTData == 48) or if(BTData == 49) */
  if(BTData == '1')
    digitalWrite(21, HIGH);LEDS.addLeds<WS2811, GPIO_NUM_21, GRB>(leds,NUM_LEDS);
fill_solid(leds, NUM_LEDS, CRGB::Red);
  // Turn on all of the LEDs
  FastLED.show();
  // wait for a bit so we can see them.
  delay(100);
  digitalWrite(22, HIGH);LEDS.addLeds<WS2811, GPIO_NUM_22, GRB>(leds,NUM_LEDS);
  FastLED.show();
  delay(100);
  digitalWrite(23, HIGH);LEDS.addLeds<WS2811, GPIO_NUM_23, GRB>(leds,NUM_LEDS);
  FastLED.show();
  delay(100);
   sendCommand(CMD_PLAY_WITHVOLUME, 0X1E01);//play the first song with volume 30 class
delay(100);//the programm will send the play option each .1 seconds to the catalex chip
  // Set the state of all of the leds to black (off)
  fill_solid(leds, NUM_LEDS, CRGB::Black);
  FastLED.show();
  if(BTData == '2')
    digitalWrite(25, HIGH);LEDS.addLeds<WS2811, GPIO_NUM_25, GRB>(leds,NUM_LEDS);
  FastLED.show();
  delay(100);
  digitalWrite(26, HIGH);LEDS.addLeds<WS2811, GPIO_NUM_26, GRB>(leds,NUM_LEDS);
  FastLED.show();
  delay(100);
  digitalWrite(27, HIGH);LEDS.addLeds<WS2811, GPIO_NUM_27, GRB>(leds,NUM_LEDS);
  FastLED.show();
  delay(100);
  FastLED.show();
  if(BTData == '3')
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
  delay(100);
  FastLED.show();
if(BTData == '4')
  FastLED.show();
  delay(100);
  FastLED.show();
  FastLED.show();
  delay(100);
  FastLED.show();
  FastLED.show();
  delay(100);
  FastLED.show();
  FastLED.show();
  delay(100);
  FastLED.show();
  FastLED.show();
  delay(100);
  FastLED.show();
  FastLED.show();
  delay(100);
  FastLED.show();
  /* If received Character is 0, then turn OFF the LED */
  if(BTData == '0')
    digitalWrite(ledPIN, LOW);
cobbling code together with low knowledge sooner or later leads to malfunctions
recently I posted an analogon:
If you want to ride a mountain-bike off-road you have to know some basics:
This bike has just handbrakes no pedal-operated-brake.
This lever is the frontwheel-brake
This lever is the backwheel-brake
This lever is the gear-shifting front
This lever is the gear-shifting back
and you have to have at least some practice
Without knowing these basics and some practice you will fell off the bike if you try to run offroad downhill.
This is what you are trying to do.
Even the most professional coding-expert will develop software this way:
One thing at a time.
The code you took to control the MP3-player is taken from an arduino-uno.
There are some constants used that are a bad idea to use those constants.
As a first step you should start with a testcode that does only
one thing
at a time. Because this is the professional way to develop software.
In your case this one thing is
Sending the commands to control a MP3-player-modul with serial interface.
Be the change you want to see in the world
best regards Stefan
Thanks, yes its not ideal I know. I am trying to learn but probably going about it in the wrong way. I guess its back to the beginning.
