ESP32 Bluetooth metadata callback to LCD display help needed
Any help here would be much appreciated, just some pointers, anything!
I'm attempting to implement Bluetooth metadata being displayed on an LCD screen, but I'm stuck.
I can use the example from this brilliant library to get the song title, etc sent to the serial monitor but don't know how to format it to be displayed on the LCD.
#include "BluetoothA2DPSink.h"
#include "LiquidCrystal.h"
LiquidCrystal lcd(19, 23, 18, 17, 16, 15);
BluetoothA2DPSink a2dp_sink;
void avrc_metadata_callback(uint8_t id, const uint8_t *text) {
Serial.printf("==> AVRC metadata rsp: attribute id 0x%x, %s\n", id, text);
a2dp_sink.set_avrc_metadata_callback(avrc_metadata_callback);
a2dp_sink.start("MyMusic");
lcd.begin(16, 2);
I've tried adding in lcd.print("==> AVRC metadata rsp: attribute id 0x%x, %s\n", id, text);
to the setup or loop but it says:
'id' was not declared in this scope
I'm not asking for the whole code to be written, but some pointers for a n00b would be great.
Cheers.
Please post the whole error message.
Please remember to use code tags when posting code.
Note the use of the printf() function. I assume that you are not using an AVR based Arduino such as the Uno or Nano but something like an ESP32 which has an extension to the Serial library that include printf()
However, the LCD library is unlikely to have this extension as it is probably inherits from the standard Serial library that does not have the printf() function
Try this
lcd.print("==> AVRC metadata rsp: attribute id ");
lcd.print(id, HEX);
lcd.print(" ");
lcd.print(text);
Thanks! Yes, its an ESP-32s
I get the following when I try to compile, but that's given me something to go on. I'll keep investigating.
C:\Users\Documents\Arduino\sketch_oct07a\sketch_oct07a.ino: In function 'void setup()':
sketch_oct07a:18:11: error: 'id' was not declared in this scope
lcd.print(id, HEX);
sketch_oct07a:20:11: error: 'text' was not declared in this scope
lcd.print(text);
Using library ESP32-A2DP-main at version 1.0 in folder: C:\Users\Documents\Arduino\libraries\ESP32-A2DP-main
Using library LiquidCrystal at version 1.0.7 in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\libraries\LiquidCrystal
exit status 1
This doesn't seem to match the code you posted
Right, apologies and thanks for bearing with me.
So, assuming lcd.print has to be within the metadata callback, I tried this
#include <BluetoothA2DPCommon.h>
#include <BluetoothA2DPSink.h>
#include <BluetoothA2DPSource.h>
#include <SoundData.h>
#include <LiquidCrystal.h>
  Streaming Music from Bluetooth
  Copyright (C) 2020 Phil Schatzmann
  This program is free software: you can redistribute it and/or modify
  it under the terms of the GNU General Public License as published by
  the Free Software Foundation, either version 3 of the License, or
  (at your option) any later version.
  This program is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
  GNU General Public License for more details.
  You should have received a copy of the GNU General Public License
  along with this program.  If not, see <http://www.gnu.org/licenses/>.
bool is_active = true;
  Serial.printf("id 0x%x, %s\n",id , text);
   lcd.setCursor(0, 0);
lcd.print(id, HEX);
lcd.print(" ");
lcd.print(text);
  lcd.begin(16, 2);
But I get this
> Arduino: 1.8.16 (Windows Store 1.8.51.0) (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
> C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\marky\OneDrive\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\marky\OneDrive\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\marky\OneDrive\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none -ide-version=10816 -build-path C:\Users\marky\AppData\Local\Temp\arduino_build_32734 -warnings=none -build-cache C:\Users\marky\AppData\Local\Temp\arduino_cache_599930 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esptool_py.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -verbose C:\Users\marky\OneDrive\Documents\Arduino\sketch_aug09b1\sketch_aug09b1.ino
> C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\marky\OneDrive\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\marky\OneDrive\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\marky\OneDrive\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none -ide-version=10816 -build-path C:\Users\marky\AppData\Local\Temp\arduino_build_32734 -warnings=none -build-cache C:\Users\marky\AppData\Local\Temp\arduino_cache_599930 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esptool_py.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -verbose C:\Users\marky\OneDrive\Documents\Arduino\sketch_aug09b1\sketch_aug09b1.ino
> Using board 'esp32' from platform in folder: C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6
> Using core 'esp32' from platform in folder: C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6
> cmd /c if exist "C:\\Users\\marky\\OneDrive\\Documents\\Arduino\\sketch_aug09b1\\partitions.csv" copy /y "C:\\Users\\marky\\OneDrive\\Documents\\Arduino\\sketch_aug09b1\\partitions.csv" "C:\\Users\\marky\\AppData\\Local\\Temp\\arduino_build_32734\\partitions.csv"
> cmd /c if not exist "C:\\Users\\marky\\AppData\\Local\\Temp\\arduino_build_32734\\partitions.csv" copy "C:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\tools\\partitions\\default.csv" "C:\\Users\\marky\\AppData\\Local\\Temp\\arduino_build_32734\\partitions.csv"
> Detecting libraries used...
> "C:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10816 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "C:\\Users\\marky\\AppData\\Local\\Temp\\arduino_build_32734\\sketch\\sketch_aug09b1.ino.cpp" -o nul
> Alternatives for BluetoothA2DPCommon.h: [ESP32-A2DP-main@1.0]
> ResolveLibrary(BluetoothA2DPCommon.h)
>   -> candidates: [ESP32-A2DP-main@1.0]
> "C:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10816 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\Arduino\\libraries\\ESP32-A2DP-main\\src" "C:\\Users\\marky\\AppData\\Local\\Temp\\arduino_build_32734\\sketch\\sketch_aug09b1.ino.cpp" -o nul
> Alternatives for LiquidCrystal.h: [LiquidCrystal@1.0.7]
> ResolveLibrary(LiquidCrystal.h)
>   -> candidates: [LiquidCrystal@1.0.7]
> "C:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10816 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\Arduino\\libraries\\ESP32-A2DP-main\\src" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\libraries\\LiquidCrystal\\src" "C:\\Users\\marky\\AppData\\Local\\Temp\\arduino_build_32734\\sketch\\sketch_aug09b1.ino.cpp" -o nul
> "C:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10816 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\Arduino\\libraries\\ESP32-A2DP-main\\src" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\libraries\\LiquidCrystal\\src" "C:\\Users\\marky\\OneDrive\\Documents\\Arduino\\libraries\\ESP32-A2DP-main\\src\\BluetoothA2DPSink.cpp" -o nul
> "C:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10816 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\Arduino\\libraries\\ESP32-A2DP-main\\src" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\libraries\\LiquidCrystal\\src" "C:\\Users\\marky\\OneDrive\\Documents\\Arduino\\libraries\\ESP32-A2DP-main\\src\\BluetoothA2DPSource.cpp" -o nul
> "C:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10816 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\Arduino\\libraries\\ESP32-A2DP-main\\src" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\libraries\\LiquidCrystal\\src" "C:\\Users\\marky\\OneDrive\\Documents\\Arduino\\libraries\\ESP32-A2DP-main\\src\\SoundData.cpp" -o nul
> "C:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10816 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\Arduino\\libraries\\ESP32-A2DP-main\\src" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\libraries\\LiquidCrystal\\src" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\libraries\\LiquidCrystal\\src\\LiquidCrystal.cpp" -o nul
> Generating function prototypes...
> "C:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10816 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\Arduino\\libraries\\ESP32-A2DP-main\\src" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\libraries\\LiquidCrystal\\src" "C:\\Users\\marky\\AppData\\Local\\Temp\\arduino_build_32734\\sketch\\sketch_aug09b1.ino.cpp" -o "C:\\Users\\marky\\AppData\\Local\\Temp\\arduino_build_32734\\preproc\\ctags_target_for_gcc_minus_e.cpp"
> "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\marky\\AppData\\Local\\Temp\\arduino_build_32734\\preproc\\ctags_target_for_gcc_minus_e.cpp"
> Compiling sketch...
> "C:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10816 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\ArduinoData\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "-IC:\\Users\\marky\\OneDrive\\Documents\\Arduino\\libraries\\ESP32-A2DP-main\\src" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\\libraries\\LiquidCrystal\\src" "C:\\Users\\marky\\AppData\\Local\\Temp\\arduino_build_32734\\sketch\\sketch_aug09b1.ino.cpp" -o "C:\\Users\\marky\\AppData\\Local\\Temp\\arduino_build_32734\\sketch\\sketch_aug09b1.ino.cpp.o"
> C:\Users\marky\OneDrive\Documents\Arduino\sketch_aug09b1\sketch_aug09b1.ino: In function 'void avrc_metadata_callback(uint8_t, const uint8_t*)':
> sketch_aug09b1:35:15: error: no matching function for call to 'print(const uint8_t*&)'
>  lcd.print(text);
> In file included from C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Stream.h:26:0,
>                  from C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Arduino.h:147,
>                  from C:\Users\marky\AppData\Local\Temp\arduino_build_32734\sketch\sketch_aug09b1.ino.cpp:1:
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:82:12: note: candidate: size_t Print::print(const String&) <near match>
>      size_t print(const String &);
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:82:12: note:   conversion of argument 1 would be ill-formed:
> sketch_aug09b1:35:15: error: invalid user-defined conversion from 'const uint8_t* {aka const unsigned char*}' to 'const String&' [-fpermissive]
>  lcd.print(text);
> In file included from C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Arduino.h:146:0,
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:57:9: note: candidate is: String::String(const char*) <near match>
>          String(const char *cstr = "");
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:57:9: note:   conversion of argument 1 would be ill-formed:
> sketch_aug09b1:35:15: error: invalid conversion from 'const uint8_t* {aka const unsigned char*}' to 'const char*' [-fpermissive]
>  lcd.print(text);
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:57:9: note:   initializing argument 1 of 'String::String(const char*)'
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:83:12: note: candidate: size_t Print::print(const char*) <near match>
>      size_t print(const char[]);
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:83:12: note:   conversion of argument 1 would be ill-formed:
>  lcd.print(text);
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:84:12: note: candidate: size_t Print::print(char) <near match>
>      size_t print(char);
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:84:12: note:   conversion of argument 1 would be ill-formed:
> sketch_aug09b1:35:15: error: invalid conversion from 'const uint8_t* {aka const unsigned char*}' to 'char' [-fpermissive]
>  lcd.print(text);
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:85:12: note: candidate: size_t Print::print(unsigned char, int) <near match>
>      size_t print(unsigned char, int = DEC);
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:85:12: note:   conversion of argument 1 would be ill-formed:
> sketch_aug09b1:35:15: error: invalid conversion from 'const uint8_t* {aka const unsigned char*}' to 'unsigned char' [-fpermissive]
>  lcd.print(text);
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:86:12: note: candidate: size_t Print::print(int, int) <near match>
>      size_t print(int, int = DEC);
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:86:12: note:   conversion of argument 1 would be ill-formed:
> sketch_aug09b1:35:15: error: invalid conversion from 'const uint8_t* {aka const unsigned char*}' to 'int' [-fpermissive]
>  lcd.print(text);
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:87:12: note: candidate: size_t Print::print(unsigned int, int) <near match>
>      size_t print(unsigned int, int = DEC);
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:87:12: note:   conversion of argument 1 would be ill-formed:
> sketch_aug09b1:35:15: error: invalid conversion from 'const uint8_t* {aka const unsigned char*}' to 'unsigned int' [-fpermissive]
>  lcd.print(text);
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:88:12: note: candidate: size_t Print::print(long int, int) <near match>
>      size_t print(long, int = DEC);
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:88:12: note:   conversion of argument 1 would be ill-formed:
> sketch_aug09b1:35:15: error: invalid conversion from 'const uint8_t* {aka const unsigned char*}' to 'long int' [-fpermissive]
>  lcd.print(text);
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:89:12: note: candidate: size_t Print::print(long unsigned int, int) <near match>
>      size_t print(unsigned long, int = DEC);
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:89:12: note:   conversion of argument 1 would be ill-formed:
> sketch_aug09b1:35:15: error: invalid conversion from 'const uint8_t* {aka const unsigned char*}' to 'long unsigned int' [-fpermissive]
>  lcd.print(text);
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:90:12: note: candidate: size_t Print::print(long long int, int) <near match>
>      size_t print(long long, int = DEC);
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:90:12: note:   conversion of argument 1 would be ill-formed:
> sketch_aug09b1:35:15: error: invalid conversion from 'const uint8_t* {aka const unsigned char*}' to 'long long int' [-fpermissive]
>  lcd.print(text);
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:91:12: note: candidate: size_t Print::print(long long unsigned int, int) <near match>
>      size_t print(unsigned long long, int = DEC);
> C:\Users\marky\OneDrive\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h:91:12: note:   conversion of argument 1 would be ill-formed:
> sketch_aug09b1:35:15: error: invalid conversion from 'const uint8_t* {aka const unsigned char*}' to 'long long unsigned int' [-fpermissive]
>  lcd.print(text);
> Using library ESP32-A2DP-main at version 1.0 in folder: C:\Users\marky\OneDrive\Documents\Arduino\libraries\ESP32-A2DP-main
> Using library LiquidCrystal at version 1.0.7 in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.51.0_x86__mdqgnx93n4wtt\libraries\LiquidCrystal
>  lcd.print(text);
>  lcd.print(text);
>  lcd.print(text);
>  lcd.print(text);
>      size_t print(char);
>  lcd.print(text);
>  lcd.print(text);
>  lcd.print(text);
>  lcd.print(text);
>  lcd.print(text);
>  lcd.print(text);
>  lcd.print(text);
>  lcd.print(text);
> exit status 1
If I were you I would start simple and just try to print "testing" to the LCD at first, just to prove or disprove the principle of what you are trying to do
You assuming that lcd.print() works as Serial.print() but this is not true.
Check the library used for LCD in order to get info on wich kind of variables you can pass to print() method.
For callback function, this is the example from library.
Instead using Serial.printf(), use snprintf() with a char array keeping the same structure of data and then print the char array to lcd
void avrc_metadata_callback(uint8_t id, const uint8_t *text) {
 char lcd_buf[40];  // Check the size you need
 snprintf(lcd_buf, 40, "0x%x, %s", id, text);
 lcd.print("==> AVRC metadata rsp: attribute id ");
 lcd.print(lcd_buf);
 Serial.printf("==> AVRC metadata rsp: attribute id 0x%x, %s\n", id, text);
Thats great, thanks!
I also got it to work by doing this
#include "BluetoothA2DPSink.h"
#include "LiquidCrystal.h"
LiquidCrystal lcd(19, 23, 18, 17, 16, 15);
BluetoothA2DPSink a2dp_sink;
  Serial.printf(" 0x%x, %s\n", id, text);
  lcd.setCursor(0, 0);
lcd.print((char *)text);
    a2dp_sink.set_avrc_metadata_callback(avrc_metadata_callback);
    a2dp_sink.start("MyMusic");
    lcd.begin(16, 2);
Now I just need to extract the text from the metadata ids I need (artist, track title, album) using "if" statements and scroll them across the LCD, which I'm assuming will mean they'll have to be stored in a buffer, so I would imagine I'll use your method.
