ESP32 Bluetooth serial problem
I have created a fire fighting bot but when i disconnect it from the com port the board remains on due to the battery supply but the bluetooth connection is lost . I don't know whether is a problem with my code or with my power supply connection.
`#include "BluetoothSerial.h"
BluetoothSerial ESP_BT; //Object for Bluetooth
int RForword = 13 ;
int LBackward = 27 ;
int LForward) = 14 ;
int RBackward) = 12 ;
int incoming;
Serial.begin(9600); //Start Serial monitor in 9600
ESP_BT.begin("Car by Giant");
Serial.println("Bluetooth Device is Ready to Pair");
pinMode(R Forword,OUTPUT);
pinMode(L Forward,OUTPUT);
pinMode(L Backward,OUTPUT);
pinMode(R Backward,OUTPUT);
digitalWrite(RF,LOW);
digitalWrite(LB,LOW);
digitalWrite(LF,LOW);
digitalWrite(RB,LOW);
if (ESP_BT.available()) //Check if we receive anything from Bluetooth
incoming = ESP_BT.read(); //Read what we recevive
Serial.print("Received:"); Serial.println(incoming);
if (incoming == 83)
    digitalWrite(R Forword,LOW);
    digitalWrite(L Backward,LOW);
    digitalWrite(L Forward,LOW);
    digitalWrite(R Backward,LOW);
      if (incoming == 66)
    digitalWrite(R Forword,HIGH);
    digitalWrite(L Forward,HIGH);
        if (incoming == 70)
    digitalWrite(L Backward,HIGH);
    digitalWrite(R Backward,HIGH);
        if (incoming == 76)
        if (incoming == 82)
                xz`
                       if (incoming == 6)
      delay(300);
                       if (incoming == 5)
       delay(300);
                       if (incoming == 4)
delay(400);
                       if (incoming == 3)
    delay(400);
delay(20);
int RForword = 13 ;
int incoming;
    if (incoming == 83)
          if (incoming == 66)
            if (incoming == 70)
            if (incoming == 76)
            if (incoming == 82)
                    xz`
                           if (incoming == 6)
          delay(300);
                           if (incoming == 5)
           delay(300);
                           if (incoming == 4)
           delay(400);
                           if (incoming == 3)
        delay(400);
  delay(20);
I think you need to press the RST button. Did you do that?
Without a wiring diagram this is only a guess, but the Bluetooth radio takes a lot of power compared to the non radio parts of the board. It may be that your battery is too weak. If it's a 9V fire detector battery that is often the problem.
Please read the pinned post re 'How to get the most from the forum'. However I think I answered your question in another post, get a better battery.
i already tried it .
Please do not cross post, it wastes people's time.
Are you using an Arduino Nano ESP32 or an other ESP32?
ESP32 Devkit
Sorry for cross posting.
i also used a proper 9v supply for it
The Nano ESP32 category is specific for the Arduino Nano ESP32 and hence your topic has been moved to a more suitable location on the forum.
bro what should i do .
A certain lack of consistency ─
And then ─
Perhaps --
ESP_BT.begin();
Instead of getting all wrapped up in this full blown R/C thing, you could take a few steps back and nail down the basics -- getting one LED to turn on/off that way.
