Hello developers,
I'm having trouble compiling code for esp32 board. I have chose sample code from examples but that too is giving error I suspect some problem with esp32 board Library. Also want to mention that I have installed latest library and tried various old Arduino ide but same problem is coming. Any suggestions will be helpful. Thank you.
Operating system : windows 10, 64bit
Arduino ide version : 1.8.15
Esp32 library : 1.0.6
Boards manager link : https://dl.espressif.com/dl/package_esp32_index.json
-Board library downloaded from Arduino ide boards manager
Code:
This sketch demonstrates how to scan WiFi networks.
The API is almost the same as with the WiFi Shield library,
the most obvious difference being the different file you need to include:
#include "WiFi.h"
// Set WiFi to station mode and disconnect from an AP if it was previously connected
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
Serial.println("Setup done");
Serial.println("scan start");
// WiFi.scanNetworks will return the number of networks found
int n = WiFi.scanNetworks();
Serial.println("scan done");
if (n == 0) {
Serial.println("no networks found");
Serial.print(n);
Serial.println(" networks found");
for (int i = 0; i < n; ++i) {
// Print SSID and RSSI for each network found
Serial.print(i + 1);
Serial.print(": ");
Serial.print(WiFi.SSID(i));
Serial.print(" (");
Serial.print(WiFi.RSSI(i));
Serial.print(")");
Serial.println((WiFi.encryptionType(i) == WIFI_AUTH_OPEN) ? " " : "*");
delay(10);
Serial.println("");
// Wait a bit before scanning again
delay(5000);
Error message:
Arduino: 1.8.15 (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
F:\WORK\arduino-1.8.15\arduino-builder -dump-prefs -logger=machine -hardware F:\WORK\arduino-1.8.15\hardware -hardware C:\Users\Drive&Control\AppData\Local\Arduino15\packages -tools F:\WORK\arduino-1.8.15\tools-builder -tools F:\WORK\arduino-1.8.15\hardware\tools\avr -tools C:\Users\Drive&Control\AppData\Local\Arduino15\packages -built-in-libraries F:\WORK\arduino-1.8.15\libraries -libraries C:\Users\Drive&Control\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none -ide-version=10815 -build-path C:\Users\DRIVE&~1\AppData\Local\Temp\arduino_build_126161 -warnings=all -build-cache C:\Users\DRIVE&~1\AppData\Local\Temp\arduino_cache_107581 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Drive&Control\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\Drive&Control\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\Drive&Control\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\Drive&Control\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.esptool_py.path=C:\Users\Drive&Control\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\Drive&Control\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -verbose C:\Users\DRIVE&~1\AppData\Local\Temp\arduino_modified_sketch_937852\WiFiScan.ino
F:\WORK\arduino-1.8.15\arduino-builder -compile -logger=machine -hardware F:\WORK\arduino-1.8.15\hardware -hardware C:\Users\Drive&Control\AppData\Local\Arduino15\packages -tools F:\WORK\arduino-1.8.15\tools-builder -tools F:\WORK\arduino-1.8.15\hardware\tools\avr -tools C:\Users\Drive&Control\AppData\Local\Arduino15\packages -built-in-libraries F:\WORK\arduino-1.8.15\libraries -libraries C:\Users\Drive&Control\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none -ide-version=10815 -build-path C:\Users\DRIVE&~1\AppData\Local\Temp\arduino_build_126161 -warnings=all -build-cache C:\Users\DRIVE&~1\AppData\Local\Temp\arduino_cache_107581 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Drive&Control\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\Drive&Control\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\Drive&Control\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\Drive&Control\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.esptool_py.path=C:\Users\Drive&Control\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\Drive&Control\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -verbose C:\Users\DRIVE&~1\AppData\Local\Temp\arduino_modified_sketch_937852\WiFiScan.ino
Using board 'esp32' from platform in folder: C:\Users\Drive&Control\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
Using core 'esp32' from platform in folder: C:\Users\Drive&Control\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
cmd /c if exist "C:\\Users\\DRIVE&~1\\AppData\\Local\\Temp\\arduino_modified_sketch_937852\\partitions.csv" copy /y "C:\\Users\\DRIVE&~1\\AppData\\Local\\Temp\\arduino_modified_sketch_937852\\partitions.csv" "C:\\Users\\DRIVE&~1\\AppData\\Local\\Temp\\arduino_build_126161\\partitions.csv"
& was unexpected at this time.
exit status 1
Error compiling for board ESP32 Dev Module.
Any code will give same error message so I'm guessing its esp32 board library error.
