So the problem im encountering is that when i touch the touch sensor to move the servos, OLED display resets, by resets i mean it blacks out and then turns back on.
Heres the code, pls help
#include <I2C_BM8563.h>
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_GFX.h>
#include <HX711.h>
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <Servo.h>
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
#define SENSOR_PIN 16
int lastState = LOW;
int currentState;
int servoPin1 = 12;
int servoPin2 = 14;
int servoPin3 = 27;
int servoPin4 = 32;
unsigned long servoMoveTime = 0;
#define BM8563_I2C_SDA 21
#define BM8563_I2C_SCL 22
#define SCREEN_WIDTH 128 // Width of OLED display
#define SCREEN_HEIGHT 64 // Height of OLED display
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
unsigned long previousMillis = 0; // stores the last time the display was updated
// Declaration for load cell pins
const int LOADCELL_DOUT_PIN = 25;
const int LOADCELL_SCK_PIN = 26;
HX711 scale;
// Calibration factor
#define CALIBRATION_FACTOR 22378.1 // Calibration factor to ensure accurate weighing
// Variables for temperature and humidity
float t;
float h;
#define DHTPIN 19 // Digital pin connected to the DHT sensor
#define DHTTYPE DHT11
I2C_BM8563 rtc(I2C_BM8563_DEFAULT_ADDRESS, Wire1);
DHT dht(DHTPIN, DHTTYPE);
bool servosMoving = false;
unsigned long servoEndTime = 0;
delay(50);
pinMode(SENSOR_PIN, INPUT);
attachInterrupt(digitalPinToInterrupt(SENSOR_PIN), sensorStateChanged, CHANGE);
currentState = digitalRead(SENSOR_PIN);
servo1.attach(servoPin1);
servo2.attach(servoPin2);
servo3.attach(servoPin3);
servo4.attach(servoPin4);
resetServos();
Wire.begin();
scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
scale.set_scale(CALIBRATION_FACTOR);
scale.tare();
Wire1.begin(BM8563_I2C_SDA, BM8563_I2C_SCL);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // Start OLED display
display.clearDisplay();
display.setTextColor(SSD1306_WHITE);
display.setTextSize(1);
display.setCursor(0, 0);
display.display();
dht.begin();
rtc.begin(); // Start RTC (SDA - 12, SCL - 14)
if (servosMoving) {
if (millis() >= servoEndTime) {
resetServos();
servosMoving = false; // Reset the servosMoving flag
// Update the display
updateDisplay();
I2C_BM8563_DateTypeDef dateStruct;
rtc.getDate(&dateStruct);
void updateDisplay() {
// Check if it's time to update the display
if (currentMillis - previousMillis >= 1000) { // Update the display every 1000 milliseconds
// Set RTC
I2C_BM8563_TimeTypeDef timeStruct;
rtc.getTime(&timeStruct);
float weight = scale.get_units(5); // Read the weight
t = dht.readTemperature(); // Read temperature
h = dht.readHumidity(); // Read humidity
display.printf("%02d/%02d/%02d %02d:%02d:%02d\n", // Format for displaying date and time (16/3/2023 9:00:30)
dateStruct.date,
dateStruct.month,
dateStruct.year,
timeStruct.hours,
timeStruct.minutes,
timeStruct.seconds);
display.setCursor(0, 10);
display.println("Temp: " + String(t) + " C");
display.setCursor(0, 20);
display.println("Hum: " + String(h) + " %");
display.setCursor(0, 30);
display.println("Weight: ");
display.setCursor(0, 40);
display.setTextSize(2);
display.println(String(weight) + " kg");
display.display();
void sensorStateChanged() {
if (lastState == LOW && currentState == HIGH && !servosMoving) {
moveServos(0, 90); // Move servos to 90 degrees
servosMoving = true; // Set the servosMoving flag
servoEndTime = millis() + 5000; // Calculate the time when the servos should stop moving
lastState = currentState;
void moveServos(int startPos, int endPos) {
int increment = (endPos > startPos) ? 1 : -1; // Determine the increment value
for (int i = startPos; i != endPos + increment; i += increment) {
servo1.write(i);
servo2.write(i);
servo3.write(i);
servo4.write(i);
delay(15);
void resetServos() {
moveServos(90, 0); // Move servos back to 0 degrees
