Ok i don't know what is now the problem... i changed a little bit in the code and now have the same issue that the code will not boot without USB connected... with USB still everything works fine.
What are the major changes:
After i recodnise the same problem i took a look into the serial output with USB and also tryed:
- wm.setDebugOutput(false); to prevent debugging log from the WifiManager
- Connect GPIO15 to GND to prevent Output log of the ESP32
So with USB i see no output but still does not boot up without USB.
After everything works and the Halloween test went successful i will put the board and code as open source for everyone
Here is the current code:
#include <Arduino.h>
#include <stdlib.h>
#define LED_BUILTIN 2 // Fix for IRRemote lib warning
#define SEND_PWM_BY_TIMER // Fix for IRRemote lib warning
// Wifi
#include <WiFiManager.h>
WiFiManager wm;
int cpTimeout = 90; // Timeout for the configuration portal
WiFiManagerParameter custom_led_delay("led_delay", "LED delay", "", 10);
// Core
#include <Infinitag_Core.h>
Infinitag_Core infinitagCore;
// WifiManager configuration portal button
#define BTN_CP_START 17
int buttonState = 0;
// IR
#define DECODE_RC5
#include <IRremote.hpp>
#define IR_RECEIVE_PIN 16
IRrecv irrecv(IR_RECEIVE_PIN);
decode_results results;
// LED
#define LED_PIN 18
#define LED_COUNT 12
#define BRIGHTNESS 255
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRBW + NEO_KHZ800);
// Switches
#define SW_1 19
#define SW_2 21
#define SW_3 22
#define SW_4 23
// Color Settings
int ledColorWifiReboot[4] = {0, 0, 0, 255};
int ledColorWifiWait[4] = {255, 255, 0, 0};
int ledColorIdle[4] = {255, 0, 255, 0};
int ledColorHit[4] = {255, 0, 0, 0};
int ledColorMissHit[4] = {0, 255, 255, 0};
// General
bool targetHit = false;
#define TEST_LED_PIN 2
// Disable Log to prevent Serial Log
// Test blink
pinMode(TEST_LED_PIN, OUTPUT);
digitalWrite(TEST_LED_PIN, HIGH);
digitalWrite(TEST_LED_PIN, LOW);
// Wifi - 1
WiFi.mode(WIFI_STA);
// Set configuration portal PIN
pinMode(BTN_CP_START, INPUT);
// Set Switch Pins
pinMode(SW_1, OUTPUT);
pinMode(SW_2, OUTPUT);
pinMode(SW_3, OUTPUT);
pinMode(SW_4, OUTPUT);
// Custom configuration
wm.addParameter(&custom_led_delay);
// Set the default value for the custom field
custom_led_delay.setValue("1000",4);
// Custom menu
// Added param for custom configuration
// Added exit to start loop after configuration
std::vector<const char *> menu = {"wifi","info","param","close","sep","update","exit"}; // Added param to the menu
wm.setMenu(menu); // custom menu, pass vector
wm.setHostname("InfinitagTarget_1");
// LED
strip.begin();
strip.show();
strip.setBrightness(BRIGHTNESS);
ledShowSetup();
// Wifi - 2
//wm.resetSettings(); // Only for Develop - Remove after
// Auto Connect
if (!wm.autoConnect("InfinitagTarget_1","12345678")) {
// IR
irrecv.enableIRIn();
// General
targetHit = false;
irDecode();
configPortalButton();
if (targetHit) {
targetHitLoop();
targetNotHitLoop();
void targetNotHitLoop() {
setAllSwitches(LOW);
ledFillFull(ledColorIdle);
void targetHitLoop() {
setAllSwitches(HIGH);
ledFillFull(ledColorHit);
targetHit = false;
IrReceiver.resume();
void setAllSwitches(int state) {
digitalWrite(SW_1, state);
digitalWrite(SW_2, state);
digitalWrite(SW_3, state);
digitalWrite(SW_4, state);
void configPortalButton() {
buttonState = digitalRead(BTN_CP_START);
if (buttonState == HIGH) {
ledShowSetup();
wm.setConfigPortalTimeout(cpTimeout);
wm.startConfigPortal("WM_ConnectAP","12345678");
void irDecode() {
// IR signal received?
if (IrReceiver.decode()) {
// Is the IR signal a Infinitag signal?
if (infinitagCore.irDecode(IrReceiver.decodedIRData.decodedRawData)) {
// Validate all required Infinitag parameters for a valid hit
if (infinitagCore.irRecvIsSystem == false && infinitagCore.irRecvGameId == 0
&& infinitagCore.irRecvTeamId == 0 && infinitagCore.irRecvPlayerId == 0
&& infinitagCore.irRecvCmd == 1 && infinitagCore.irRecvCmdValue == 255) {
targetHit = true;
ledFillFull(ledColorMissHit);
delay(150);
strip.clear();
void ledShowSetup() {
ledFillFull(ledColorWifiReboot);
delay(150);
ledFillFull(ledColorWifiWait);
void ledFillFull(int color[]) {
strip.fill(strip.Color(color[0], color[1], color[2], color[3]));
strip.show();
If anyone is interested: GitHub - Infinitag/Target: Lasertag target board for Infinitag open source system.
