I'm trying to make a Bluetooth keypad/macropad for use in games (not a controller). The issue is that my keypresses aren't sent over Bluetooth to my Windows 10 PC.
The keypad is 2 column X 6 rows. I'm using keypad.h (matrix connected to gpio pins) as this seemed the simplest soultion to hooking everything up.
Wiring is correct as the right keypresses are sent on the COM port when viewed in the Serial Monitor.
Windows recognised the "keyboard" via bluetooth as well, so it's not that it's not connecting properly either.
I'm sure the problem is very simple and I'm missing something obvious.
Any help would be greatly appreciated.
#include <BleKeyboard.h>
#define USE_NIMBLE
#include <Keypad.h>
const byte ROWS = 6; //six rows
const byte COLS = 2; //two columns
char keys[ROWS][COLS] = {
{ '7', '1' },
{ '8', '2' },
{ '9', '3' },
{ '0', '4' },
{ '-', '5' },
{ '=', '6' },
byte rowPins[ROWS] = { 10, 6, 7, 5, 4, 8 };
byte colPins[COLS] = { 2, 3 };
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
BleKeyboard bleKeyboard("ESP32-C3_Keypad", "Me", 100);
bleKeyboard.begin();
// This will hold down all the following buttons.
void macroCommand(uint8_t key) {
bleKeyboard.press(KEY_LEFT_SHIFT);
bleKeyboard.press(key);
char key = keypad.getKey();
// Only do something with the keypress if we
// are connected to something via bluetooth
Serial.println(key);
if (bleKeyboard.isConnected() && key) {
switch (key) {
case '1':
bleKeyboard.print('!');
case '2':
bleKeyboard.press('2');
case '3':
macroCommand('3');
case '4':
bleKeyboard.write('$');
case '5':
macroCommand('5');
case '6':
macroCommand('6');
case '7':
macroCommand('7');
case '8':
macroCommand('8');
case '9':
macroCommand('9');
case '0':
macroCommand('0');
case '-':
macroCommand('-');
case '=':
macroCommand('=');
delay(100);
bleKeyboard.releaseAll();
I tried various different bits of code down near the bottom to see if anything would work. So far no luck.
Edit. I've used the BLEKeyboard example code before. This DOES output text over bluetooth. I need an output to happen when a button is pressed though.
