Hello, I am compiling a code that I used in an ESP32 Dev, to an ESP32 C3, but it does not allow me to compile, it shows me the following error, and I think it has to do with bluetooth:
Code:
//Import i2C LCD libraries
#include "BluetoothSerial.h"
#include "ELMduino.h"
int sda_pin = 04; // GPIO16 as I2C SDA
int scl_pin = 05; // GPIO17 as I2C SCL
// set the LCD number of columns and rows
int lcdColumns = 16;
int lcdRows = 2;
// set LCD address, number of columns and rows
// if you don't know your display address, run an I2C scanner sketch
LiquidCrystal_I2C lcd(0x27, lcdColumns, lcdRows);
BluetoothSerial SerialBT;
#define ELM_PORT SerialBT
#define DEBUG_PORT Serial
ELM327 myELM327;
Wire.setPins(sda_pin, scl_pin); // Set the I2C pins before begin
Wire.begin(); // join i2c bus (address optional for master)
#if LED_BUILTIN
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, LOW);
#endif
// initialize LCD
lcd.init();
// turn on LCD backlight
lcd.backlight();
DEBUG_PORT.begin(115200);
//SerialBT.setPin("1234");
ELM_PORT.begin("ArduHUD", true);
if (!ELM_PORT.connect("OBDII"))
DEBUG_PORT.println("Couldn't connect to OBD scanner - Phase 1");
while (1);
if (!myELM327.begin(ELM_PORT, true, 2000))
Serial.println("Couldn't connect to OBD scanner - Phase 2");
while (1);
Serial.println("Connected to ELM327");
static int pidCounter = 0;
switch (pidCounter)
case 0:
float motor = myELM327.engineCoolantTemp();
if (myELM327.nb_rx_state == ELM_SUCCESS)
uint32_t tempeR = (uint32_t)motor;
lcd.setCursor(0, 0);
lcd.print("Motor: " + String(tempeR) + " C"); Serial.println(tempeR);
delay(200);
pidCounter++;
else if (myELM327.nb_rx_state != ELM_GETTING_MSG) myELM327.printError();
case 1:
float motorRPM = myELM327.rpm();
uint32_t mRPM = (uint32_t)motorRPM;
lcd.setCursor(0, 1);
lcd.print("RPM: " + String(mRPM) + ".0"); Serial.println(mRPM);
delay(200);
pidCounter = 0;
This error:
c:/users/saagc/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `.L0 ':
C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:715: undefined reference to `esp_spp_disconnect'
c:/users/saagc/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `_stop_bt':
C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:716: undefined reference to `esp_spp_deinit'
C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:189: undefined reference to `esp_spp_write'
c:/users/saagc/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:153: undefined reference to `esp_bt_gap_set_pin'
c:/users/saagc/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:650: undefined reference to `esp_bt_gap_register_callback'
c:/users/saagc/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `_init_bt':
C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:658: undefined reference to `esp_spp_register_callback'
c:/users/saagc/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:666: undefined reference to `esp_spp_init'
c:/users/saagc/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:688: undefined reference to `esp_bt_gap_set_security_param'
c:/users/saagc/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:693: undefined reference to `esp_bt_gap_set_cod'
c:/users/saagc/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `BluetoothSerial::disconnect()':
C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:657: undefined reference to `esp_spp_disconnect'
c:/users/saagc/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `BluetoothSerial::connect(String)':
C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:936: undefined reference to `esp_bt_gap_set_scan_mode'
c:/users/saagc/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:945: undefined reference to `esp_bt_gap_start_discovery'
c:/users/saagc/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `.LVL458':
C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:265: undefined reference to `esp_bt_gap_set_scan_mode'
c:/users/saagc/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `esp_spp_cb':
C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:271: undefined reference to `esp_spp_start_srv'
c:/users/saagc/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:283: undefined reference to `esp_spp_disconnect'
c:/users/saagc/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:364: undefined reference to `esp_spp_connect'
c:/users/saagc/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:391: undefined reference to `esp_spp_disconnect'
C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:126: undefined reference to `esp_bt_gap_resolve_eir_data'
c:/users/saagc/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `get_name_from_eir':
C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:130: undefined reference to `esp_bt_gap_resolve_eir_data'
C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:456: undefined reference to `esp_bt_gap_cancel_discovery'
c:/users/saagc/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: libraries\BluetoothSerial\BluetoothSerial.cpp.o: in function `esp_bt_gap_cb':
C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:455: undefined reference to `esp_spp_start_discovery'
c:/users/saagc/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:522: undefined reference to `esp_bt_gap_pin_reply'
c:/users/saagc/appdata/local/arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/../lib/gcc/riscv32-esp-elf/8.4.0/../../../../riscv32-esp-elf/bin/ld.exe: C:\Users\saagc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.4\libraries\BluetoothSerial\src/BluetoothSerial.cpp:530: undefined reference to `esp_bt_gap_ssp_confirm_reply'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board ESP32C3 Dev Module.
I can hardly find examples to use libraries in the ESP32 C3, thanks for the help
