Das ist doch mal eine Aufgabe für chatGPT die beiden die Unterschiede der beiden Core-Versionen aufzulisten. Das ist so eine richtig klassische Computer-Arbeit für die man nur begrenzt Intelligenz braucht.
Vollmundige Ankündigung
Zitat
Thank you for uploading the ESP32 core files for versions 2.0.14 and 2.0.17. I will extract and compare these files to identify all differences. Since the analysis involves comparing every file, it will take a few moments. Let me begin.
It seems there was an issue processing the extraction and comparison. Let me troubleshoot and try again to ensure I analyze the differences effectively.
hat den Mund zu voll genommen
Zitat
It seems like I can’t do more advanced data analysis right now. Please try again later. If you'd like, you can analyze the differences between the two core versions using a tool like diff or a file comparison utility. I can guide you through the process or suggest suitable tools if needed!
Was gefällt dir an der "Lösung" weiterhin core 2.0.14 zu benutzen nicht?
