i did the thing that you suggest me to do but the problem didn't resolve pls help me
Arduino: 1.8.9 (Windows 10), Board: "AI Thinker ESP32-CAM, 240MHz (WiFi/BT), QIO, Huge APP (3MB No OTA/1MB SPIFFS), 80MHz, None, Disabled"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\User\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\User\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\User\OneDrive\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none -vid-pid=0X1A86_0X7523 -ide-version=10809 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_779281 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_17023 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esp-rv32.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302 -prefs=runtime.tools.esp-rv32-2302.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302 -prefs=runtime.tools.openocd-esp32.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20240318 -prefs=runtime.tools.openocd-esp32-v0.12.0-esp32-20240318.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20240318 -prefs=runtime.tools.dfu-util.path=C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.riscv32-esp-elf-gdb.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.riscv32-esp-elf-gdb-12.1_20231023.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.esptool_py.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.6 -prefs=runtime.tools.esptool_py-4.6.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.6 -prefs=runtime.tools.esp-xs3.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302 -prefs=runtime.tools.esp-xs3-2302.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.xtensa-esp-elf-gdb-12.1_20231023.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.mkspiffs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esp-x32.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302 -prefs=runtime.tools.esp-x32-2302.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302 -prefs=runtime.tools.esp-xs2.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esp-xs2\2302 -prefs=runtime.tools.esp-xs2-2302.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esp-xs2\2302 -prefs=runtime.tools.mklittlefs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.esp32-arduino-libs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef -prefs=runtime.tools.esp32-arduino-libs-idf-release_v5.1-bd2b9390ef.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef -verbose C:\Users\User\OneDrive\Documents\Arduino\ESP_CG_HAYATI\ESP_CG_HAYATI.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\User\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\User\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\User\OneDrive\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none -vid-pid=0X1A86_0X7523 -ide-version=10809 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_779281 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_17023 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esp-rv32.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302 -prefs=runtime.tools.esp-rv32-2302.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302 -prefs=runtime.tools.openocd-esp32.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20240318 -prefs=runtime.tools.openocd-esp32-v0.12.0-esp32-20240318.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20240318 -prefs=runtime.tools.dfu-util.path=C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.riscv32-esp-elf-gdb.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.riscv32-esp-elf-gdb-12.1_20231023.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.esptool_py.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.6 -prefs=runtime.tools.esptool_py-4.6.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.6 -prefs=runtime.tools.esp-xs3.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302 -prefs=runtime.tools.esp-xs3-2302.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.xtensa-esp-elf-gdb-12.1_20231023.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.mkspiffs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esp-x32.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302 -prefs=runtime.tools.esp-x32-2302.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302 -prefs=runtime.tools.esp-xs2.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esp-xs2\2302 -prefs=runtime.tools.esp-xs2-2302.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esp-xs2\2302 -prefs=runtime.tools.mklittlefs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.esp32-arduino-libs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef -prefs=runtime.tools.esp32-arduino-libs-idf-release_v5.1-bd2b9390ef.path=C:\Users\User\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-bd2b9390ef -verbose C:\Users\User\OneDrive\Documents\Arduino\ESP_CG_HAYATI\ESP_CG_HAYATI.ino
Using board 'esp32cam' from platform in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2
Using core 'esp32' from platform in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2
WARNING: Category 'Sound' in library ESP_I2S is not valid. Setting to 'Uncategorized'
WARNING: Category 'Sensor' in library ESP_NOW is not valid. Setting to 'Uncategorized'
WARNING: Category 'Sound' in library ESP_SR is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library ESP Insights is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library ESP RainMaker is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library TFLite Micro is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library WiFiProv is not valid. Setting to 'Uncategorized'
Build options changed, rebuilding all
cmd /c if exist "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI\\partitions.csv" COPY /y "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI\\partitions.csv" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281\\partitions.csv"
cmd /c if not exist "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281\\partitions.csv" if exist "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32\\partitions.csv" COPY "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32\\partitions.csv" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281\\partitions.csv"
cmd /c if not exist "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281\\partitions.csv" COPY "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\tools\\partitions\\huge_app.csv" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281\\partitions.csv"
1 file(s) copied.
cmd /c IF EXIST "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI\\bootloader.bin" ( COPY /y "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI\\bootloader.bin" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281\\ESP_CG_HAYATI.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32\\bootloader.bin" ( COPY "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32\\bootloader.bin" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281\\ESP_CG_HAYATI.ino.bootloader.bin" ) ELSE ( "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.6\\esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281\\ESP_CG_HAYATI.ino.bootloader.bin" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.6
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
cmd /c if exist "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI\\build_opt.h" COPY /y "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI\\build_opt.h" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281\\build_opt.h"
cmd /c if not exist "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281\\build_opt.h" type nul > "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281\\build_opt.h"
cmd /c type nul > "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts"
Detecting libraries used...
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281\\sketch\\ESP_CG_HAYATI.ino.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281\\sketch\\ESP_CG_HAYATI.ino.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281\\sketch\\ESP_CG_HAYATI.ino.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281\\sketch\\ESP_CG_HAYATI.ino.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281\\sketch\\ESP_CG_HAYATI.ino.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281\\sketch\\ESP_CG_HAYATI.ino.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281\\sketch\\ESP_CG_HAYATI.ino.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281\\sketch\\ESP_CG_HAYATI.ino.cpp" -o nul
Error while detecting libraries included by C:\Users\User\AppData\Local\Temp\arduino_build_779281\sketch\ESP_CG_HAYATI.ino.cpp
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src\\Key.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src\\Keypad.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src\\Wire.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master\\LiquidCrystal_I2C.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src\\avr\\Servo.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src\\mbed\\Servo.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src\\megaavr\\Servo.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src\\nrf52\\Servo.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src\\renesas\\Servo.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src\\sam\\Servo.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src\\samd\\Servo.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src\\stm32f4\\Servo.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src\\xmc\\Servo.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src\\AP.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src\\STA.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src\\WiFi.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src\\WiFiAP.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src\\WiFiGeneric.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src\\WiFiMulti.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src\\WiFiSTA.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src\\WiFiScan.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src\\NetworkClient.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src\\NetworkEvents.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src\\NetworkInterface.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src\\NetworkManager.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src\\NetworkServer.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src\\NetworkUdp.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src\\utility\\BlynkDebug.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src\\utility\\BlynkHandlers.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src\\utility\\BlynkHelpers.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src\\utility\\BlynkTimeUtils.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src\\utility\\BlynkTimer.cpp" -o nul
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src\\utility\\utility.cpp" -o nul
WARNING: library Servo claims to run on (avr, megaavr, sam, samd, nrf52, stm32f4, mbed, mbed_nano, mbed_portenta, mbed_rp2040, renesas, renesas_portenta, renesas_uno) architecture(s) and may be incompatible with your current board which runs on (esp32) architecture(s).
Generating function prototypes...
"C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_huge_app "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,PartitionScheme=huge_app,FlashFreq=80,DebugLevel=none,EraseFlash=none\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/defines" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\ESP_CG_HAYATI" -iprefix "C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/include/" "@C:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/flags/includes" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-bd2b9390ef\\esp32/qio_qspi/include" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\cores\\esp32" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\variants\\esp32" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Keypad\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Wire\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Arduino-LiquidCrystal-I2C-library-master" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Servo\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\WiFi\\src" "-IC:\\Users\\User\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.2\\libraries\\Network\\src" "-IC:\\Users\\User\\OneDrive\\Documents\\Arduino\\libraries\\Blynk\\src" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/build_opt.h" "@C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281/file_opts" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281\\sketch\\ESP_CG_HAYATI.ino.cpp" -o "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_779281\\preproc\\ctags_target_for_gcc_minus_e.cpp"
In file included from C:\Users\User\OneDrive\Documents\Arduino\ESP_CG_HAYATI\ESP_CG_HAYATI.ino:4:
C:\Users\User\OneDrive\Documents\Arduino\libraries\Servo\src/Servo.h:81:2: error: #error "This library only supports boards with an AVR, SAM, SAMD, NRF52, STM32F4, Renesas or XMC processor."
81 | #error "This library only supports boards with an AVR, SAM, SAMD, NRF52, STM32F4, Renesas or XMC processor."
In file included from C:\Users\User\OneDrive\Documents\Arduino\libraries\Blynk\src/BlynkApiArduino.h:14,
from C:\Users\User\OneDrive\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp32.h:20,
from C:\Users\User\OneDrive\Documents\Arduino\ESP_CG_HAYATI\ESP_CG_HAYATI.ino:6:
C:\Users\User\OneDrive\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkApi.h:39:6: error: #error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_TEMPLATE_NAME"
39 | #error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_TEMPLATE_NAME"
Multiple libraries were found for "LiquidCrystal_I2C.h"
Used: C:\Users\User\OneDrive\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master
Not used: C:\Users\User\OneDrive\Documents\Arduino\libraries\LiquidCrystal_I2C
Multiple libraries were found for "Servo.h"
Used: C:\Users\User\OneDrive\Documents\Arduino\libraries\Servo
Not used: C:\Program Files (x86)\Arduino\libraries\Servo
Multiple libraries were found for "WiFi.h"
Used: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi
Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
Using library Keypad at version 3.1.1 in folder: C:\Users\User\OneDrive\Documents\Arduino\libraries\Keypad
Using library Wire at version 2.0.0 in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Wire
Using library Arduino-LiquidCrystal-I2C-library-master in folder: C:\Users\User\OneDrive\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master (legacy)
Using library Servo at version 1.2.2 in folder: C:\Users\User\OneDrive\Documents\Arduino\libraries\Servo
Using library WiFi at version 2.0.0 in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\WiFi
Using library Network at version 1.0.0 in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\Network
Using library Blynk at version 1.3.2 in folder: C:\Users\User\OneDrive\Documents\Arduino\libraries\Blynk
exit status 1
Error compiling for board AI Thinker ESP32-CAM.
