I want to aliment an ESP32 CAM using a 3.7V LIPO battery AND to can charge the LIPO battery without have to change anything on the wiring
(only to plug an USB cable into the charger for to charge the battery and aliment the ESP32 CAM if the LIPO battery is empty)
I think to use something like this for to dynamically recharge the LIPO battery using an USB câble
Or have I to use the circuitry as proposed here ?
(I prefer limit the number of components/wiring because want to store the entire system into a very limited volum)
PS : It's for to work with an LED emitter + a LED recepter on the ESP32 CAM side : is a 5V solution a better solution than a 3.3V solution for to handle this ?
