ESP32 Cam Cannot connect to WiFi
Hello,
I have an ESP32 Cam board with a USB. I was able to connect to WiFi and test CamWebServer just fine.
After a while, I am unable to connect to WiFi. I tested two boards multiple networks and codes with no luck. It keeps showing dots without successfully connecting.
I tested with CamerWebServer and the below code.
Any ideas ??
board link
#include "WiFi.h"
const char* ssid = "....";
const char* password =  ".....";
  WiFi.begin(ssid, password);
    Serial.println("Connecting to WiFi..");
  Serial.println("Connected to the WiFi network");
void loop() {}
Maybe try the esp8266wifi.h library.
It is always worth making 100% sure the power supply you are using is ok as they will do all sorts of weird things if they are not happy with it.
If you are using one of the motherboards to program it I have found some times the wifi signal is seriously blocked by it and if I rest my thumb above the antenna it will suddenly burst in to life (oddly on other occasions there is no need??)
I find they do not like anything near the antenna or being inside any kind of case (much more so than other esp32s I have used)
Did not work
This is how I connect it to my laptop.
That is how I do it but I do some times find the motherboard blocks the wifi. Try connecting it without the motherboard and see if this gets the wifi working (i.e. via the 5v and gnd pins)
or for some reason I find if I rest my thumb on the top board (where the esp32 writing is in your image) it helps get a signal.
or of course try getting closer to the router and see if it then finds it ok
Also, you could program the onboard LED to blink every time a "." is supposed to be printed on the serial monitor. That way, you know it is connected when the LED doesn't blink, and you don't have to have it connected to your computer so you can check the serial monitor.
Did not work when I rest my thumb. I will try to connect without the motherboard.
Tahnks
Do you the pin number for the LED ??
I tried multiple pins did not work.
Here is my code that connects a ESP32 CAM to WIFi.
#include "sdkconfig.h" // used for log printing
#include "esp_system.h"
#include "freertos/FreeRTOS.h" //freeRTOS items to be used
#include "freertos/task.h"
#include "certs.h"
#include "esp_camera.h"
#include "soc/soc.h"           // Disable brownout problems
#include "soc/rtc_cntl_reg.h"  // Disable brownout problems
#include "driver/rtc_io.h"
#include <WiFi.h>
#include <WiFiClient.h>
#include "ESP32_FTPClient.h"
#include <PubSubClient.h>
#include <ESP32Time.h>
WiFiClient      wifiClient; // do the WiFi instantiation thing
PubSubClient    MQTTclient( mqtt_server, mqtt_port, wifiClient ); //do the MQTT instantiation thing
ESP32_FTPClient ftp (ftp_server, ftp_user, ftp_pass, 5000, 2);
ESP32Time       rtc;
//#define evtDoMQTTParse  ( 1 << 0 ) // declare an event
//EventGroupHandle_t eg; // variable for the event group handle
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_mqttOK;
QueueHandle_t xQ_Message; // payload and topic queue of MQTT payload and topic
const int payloadSize = 300;
struct stu_message
  char payload [payloadSize] = {'\0'};
  String topic ;
} x_message;
int  mqttOK = 0;
bool TimeSet = false;
bool FlashMode = false;
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  switch (event) {
    case SYSTEM_EVENT_STA_CONNECTED:
      log_i("Connected to WiFi access point");
    case SYSTEM_EVENT_STA_DISCONNECTED:
      log_i("Disconnected from WiFi access point");
    case SYSTEM_EVENT_AP_STADISCONNECTED:
      log_i("WiFi client disconnected");
    default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
  // clear locations
  memset( x_message.payload, '\0', payloadSize );
  x_message.topic = ""; //clear string buffer
  x_message.topic.concat( topic );
  int i = 0;
  for ( i; i < length; i++)
    x_message.payload[i] = ((char)payload[i]);
  x_message.payload[i] = '\0';
  xQueueOverwrite( xQ_Message, (void *) &x_message );// send data to queue
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
  pinMode( GPIO_NUM_4, OUTPUT);
  digitalWrite( GPIO_NUM_4, LOW);
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //disable brownout detector
  //eg = xEventGroupCreate(); // get an event group handle
  x_message.topic.reserve( payloadSize );
  xQ_Message  = xQueueCreate( 1, sizeof(stu_message) );
  sema_mqttOK    =  xSemaphoreCreateBinary();
  xSemaphoreGive( sema_mqttOK );
  xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 7000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 9000, NULL, 4, NULL, 1 ); // assign all to core 1, WiFi in use.
  xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 3000, NULL, 2, NULL, 1 );
  if ( configInitCamera() )
    log_i("        start camera task" );
    xTaskCreatePinnedToCore( capturePhoto_sendFTP, "capturePhoto_sendFTP", 60000, NULL, 6, NULL, 1 );
    log_i( "       camera failed to initilize, rebooting in 5." );
    vTaskDelay( 2000 );
    ESP.restart();
} // void setup()
void capturePhoto_sendFTP( void *pvParameters )
  TickType_t xLastWakeTime    = xTaskGetTickCount();
  const TickType_t xFrequency = 1000 * 5; //delay for mS
  //!!!!!Must wait for MQTT connection and proper setup of the sema_MQTT_KeepAlive!!!!
  while ( !MQTTclient.connected() )
    vTaskDelay( 500 );
  for (;;)
    log_i( "tick");
    xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY );
    if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
      camera_fb_t * fb = NULL; // pointer
      fb = esp_camera_fb_get();
      if (!fb)
        log_i( "Camera capture failed" );
        esp_camera_fb_return(fb);
      } else
        ftp.OpenConnection(); // try open FTP
        if ( ftp.isConnected() )
          //try send file ftp
          ftp.ChangeWorkDir( ftp_path );
          ftp.DeleteFile( ftp_file_name );
          ftp.InitFile( ftp_file_type ); //"Type I"
          ftp.NewFile( ftp_file_name );
          ftp.WriteData( (unsigned char *)fb->buf, fb->len );
          ftp.CloseFile();
          ftp.CloseConnection();
        esp_camera_fb_return(fb); //return the frame buffer back to the driver for reuse
    xSemaphoreGive( sema_MQTT_KeepAlive );
    vTaskDelayUntil( &xLastWakeTime, xFrequency );
  vTaskDelete( NULL );
} //void capturePhoto_sendFTP( void *pvParameters )
void configureCameraSettings_grpE( int _lenC, int _Hmirror, int _Vflip, int _dcw, int _colorbar )
  sensor_t * s = esp_camera_sensor_get();
  s->set_lenc(s, _lenC);         // 0 = disable , 1 = enable
  s->set_hmirror(s, _Hmirror);   // 0 = disable , 1 = enable
  s->set_vflip(s, _Vflip);       // 0 = disable , 1 = enable
  s->set_dcw(s, _dcw);           // 0 = disable , 1 = enable
  ////s->set_colorbar(s, _colorbar); // 0 = disable , 1 = enable
void configureCameraSettings_grpD( int _gc, int _agc, int _celing, int _bpc, int _wpc, int _gma )
  s->set_gain_ctrl(s, _gc); // 0 = disable , 1 = enable
  s->set_agc_gain(s, _agc); // 0 to 30
  s->set_gainceiling(s, (gainceiling_t)_celing);  // 0 to 6
  s->set_bpc(s, _bpc);      // 0 = disable , 1 = enable
  s->set_wpc(s, _wpc);      // 0 = disable , 1 = enable
  s->set_raw_gma(s, _gma);  // 0 = disable , 1 = enable
void configureCameraSettings_grpC( int _exctl, int _aec2, int _ae, int _aec )
  s->set_exposure_ctrl(s, _exctl); // 0 = disable , 1 = enable
  s->set_aec2(s, _aec2);           // 0 = disable , 1 = enable
  s->set_ae_level(s, _ae);         // -2 to 2
  ////s->set_aec_value(s, _aec);       // 0 to 1200 CAUSES BLACK IMAGE????
void configureCameraSettings_grpB( int se, int wb, int awb, int wbmode )
  s->set_special_effect(s, se); // 0 to 6 (0 - No Effect, 1 - Negative, 2 - Grayscale, 3 - Red Tint, 4 - Green Tint, 5 - Blue Tint, 6 - Sepia)
  s->set_whitebal(s, wb);       // 0 = disable , 1 = enable
  s->set_awb_gain(s, awb);      // 0 = disable , 1 = enable
  s->set_wb_mode(s, wbmode);    // 0 to 4 - if awb_gain enabled (0 - Auto, 1 - Sunny, 2 - Cloudy, 3 - Office, 4 - Home)
void configureCameraSettings_grpA(int brightness, int contrast, int saturation )
  if ( ((brightness > -3) && (brightness < 3)) && ((contrast > -3) && (contrast < 3)) && ((saturation > -3) && (saturation < 3)) )
    s->set_brightness( s, brightness ); // -2 to 2
    s->set_contrast( s, contrast );    // -2 to 2
    s->set_saturation( s, saturation );  // -2 to 2
} //void configureCameraSettings()
  sensor_t * s = esp_camera_sensor_get(); //see certs.h for more info
  s->set_brightness(s, -1);     // -2 to 2 **************************
  s->set_contrast(s, 0);       // -2 to 2
  s->set_saturation(s, 0);     // -2 to 2
  s->set_special_effect(s, 0); // 0 to 6 (0 - No Effect, 1 - Negative, 2 - Grayscale, 3 - Red Tint, 4 - Green Tint, 5 - Blue Tint, 6 - Sepia)
  s->set_whitebal(s, 1);       // 0 = disable , 1 = enable
  s->set_awb_gain(s, 1);       // 0 = disable , 1 = enable
  s->set_wb_mode(s, 0);        // 0 to 4 - if awb_gain enabled (0 - Auto, 1 - Sunny, 2 - Cloudy, 3 - Office, 4 - Home)
  s->set_exposure_ctrl(s, 1);  // 0 = disable , 1 = enable
  s->set_aec2(s, 0);           // 0 = disable , 1 = enable
  s->set_ae_level(s, 0);       // -2 to 2
  s->set_aec_value(s, 300);    // 0 to 1200
  s->set_gain_ctrl(s, 1);      // 0 = disable , 1 = enable
  s->set_agc_gain(s, 0);       // 0 to 30
  s->set_gainceiling(s, (gainceiling_t)0);  // 0 to 6
  s->set_bpc(s, 0);            // 0 = disable , 1 = enable
  s->set_wpc(s, 1);            // 0 = disable , 1 = enable
  s->set_raw_gma(s, 1);        // 0 = disable , 1 = enable
  s->set_lenc(s, 1);           // 0 = disable , 1 = enable
  s->set_hmirror(s, 0);        // 0 = disable , 1 = enable
  s->set_vflip(s, 0);          // 0 = disable , 1 = enable
  s->set_dcw(s, 1);            // 0 = disable , 1 = enable
  s->set_colorbar(s, 0);       // 0 = disable , 1 = enable
bool configInitCamera()
  camera_config_t config = {}; // Stores the camera configuration parameters
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer   = LEDC_TIMER_0;
  config.pin_d0       = GPIO_NUM_5; //Y2
  config.pin_d1       = GPIO_NUM_18; //Y3
  config.pin_d2       = GPIO_NUM_19; //Y4
  config.pin_d3       = GPIO_NUM_21; //Y5
  config.pin_d4       = GPIO_NUM_36; //Y6
  config.pin_d5       = GPIO_NUM_39; //Y7
  config.pin_d6       = GPIO_NUM_34; //Y8
  config.pin_d7       = GPIO_NUM_35; // Y9
  config.pin_xclk     = GPIO_NUM_0; //XCLK
  config.pin_pclk     = GPIO_NUM_22; //PCLK
  config.pin_vsync    = GPIO_NUM_25; //VSSYNC
  config.pin_href     = GPIO_NUM_23; // HREF
  config.pin_sscb_sda = GPIO_NUM_26; //SIOD
  config.pin_sscb_scl = GPIO_NUM_27; //SIOC
  config.pin_pwdn     = GPIO_NUM_32; //PWDN
  config.pin_reset    = -1; //RESET
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG; ////YUV422,GRAYSCALE,RGB565,JPEG
  config.frame_size = FRAMESIZE_UXGA; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
    FRAMESIZE_UXGA (1600 x 1200)
    FRAMESIZE_QVGA (320 x 240)
    FRAMESIZE_CIF (352 x 288)
    FRAMESIZE_VGA (640 x 480)
    FRAMESIZE_SVGA (800 x 600)
    FRAMESIZE_XGA (1024 x 768)
    FRAMESIZE_SXGA (1280 x 1024)
  config.jpeg_quality = 10; //0-63 lower number means higher quality
   * The image quality (jpeg_quality) can be a number between 0 and 63.
   * A lower number means a higher quality.
   * However, very low numbers for image quality,
   * specially at higher resolution can make the ESP32-CAM to crash or it may not be able to take the photos properly.
   * So, if you notice that the images taken with the ESP32-CAM are cut in half, or with strange colors,
   * that’s probably a sign that you need to lower the quality (select a higher number).
  config.fb_count = 2;
  // Initialize the Camera
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    log_i("Camera init failed with error %d", err );
    return false;
    configureCameraSettings();
    return true;
} //void configInitCamera()
void connectToWiFi()
  int TryCount = 0;
  while ( WiFi.status() != WL_CONNECTED )
    TryCount++;
    WiFi.disconnect();
    WiFi.begin( SSID, PASSWORD );
    vTaskDelay( 2500 );
    if ( TryCount == 10 )
      ESP.restart();
  WiFi.onEvent( WiFiEvent );
void MQTTkeepalive( void *pvParameters )
  sema_MQTT_KeepAlive   = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
  MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
  const TickType_t xFrequency = 250; //delay for ms
  for (;;)
    //check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // !!!!!whiles MQTTlient.loop() is running no other mqtt operations should be in process!!!!!
      MQTTclient.loop();
    else {
      if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
        connectToWiFi();
      connectToMQTT();
  vTaskDelete ( NULL );
void connectToMQTT()
  byte mac[5]; // create client ID from mac address
  WiFi.macAddress(mac); // get mac address
  String clientID = String(mac[0]) + String(mac[4]) ; // use mac address to create clientID
    MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password );
    vTaskDelay( 250 );
  MQTTclient.setCallback( mqttCallback );
  MQTTclient.subscribe( topicOK );
  MQTTclient.subscribe( topicGrpA );
  MQTTclient.subscribe( topicGrpB );
  MQTTclient.subscribe( topicGrpC );
  MQTTclient.subscribe( topicGrpD );
  MQTTclient.subscribe( topicGrpE );
  MQTTclient.subscribe( topicFlash );
} //void connectToMQTT()
void fmqttWatchDog( void * paramater )
  int UpdateImeTrigger = 86400; //seconds in a day
  int UpdateTimeInterval = 85000; // get another reading when = UpdateTimeTrigger
  int maxNonMQTTresponse = 3;
  const TickType_t xFrequency = 60000; //delay for mS
  for (;;)
    xSemaphoreTake( sema_mqttOK, portMAX_DELAY ); // update mqttOK
    mqttOK++;
    if ( mqttOK >= maxNonMQTTresponse )
      log_i( "mqtt watchdog rest" );
      vTaskDelay( 200 );
      ESP.restart();
    UpdateTimeInterval++; // trigger new time get
    if ( UpdateTimeInterval >= UpdateImeTrigger )
      TimeSet = false; // sets doneTime to false to get an updated time after a days count of seconds
      UpdateTimeInterval = 0;
} //void fmqttWatchDog( void * paramater )
void fparseMQTT( void *pvParameters )
  struct stu_message px_message;
  for (;;)
    if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
      mqttOK = 0;
      if ( !TimeSet)
        if ( String(px_message.topic) == topicOK )
          String temp = "";
          temp        = px_message.payload[0];
          temp        += px_message.payload[1];
          temp        += px_message.payload[2];
          temp        += px_message.payload[3];
          int year    =  temp.toInt();
          temp        = "";
          temp        = px_message.payload[5];
          temp        += px_message.payload[6];
          int month   =  temp.toInt();
          temp        = "";
          temp        = px_message.payload[8];
          temp        += px_message.payload[9];
          int day     =  temp.toInt();
          temp        = "";
          temp        = px_message.payload[11];
          temp        += px_message.payload[12];
          int hour    =  temp.toInt();
          temp        = "";
          temp        = px_message.payload[14];
          temp        += px_message.payload[15];
          int min     =  temp.toInt();
          rtc.setTime( 0, min, hour, day, month, year );
          log_i( "%s   rtc  %s ", px_message.payload, rtc.getTime() );
          TimeSet     = true;
      if ( String(px_message.topic) == topicGrpA )
        //finding first letter
        String sTmp = String( px_message.payload );
        int commaIndex = sTmp.indexOf(',');
        if ( sTmp.substring(0, commaIndex) == "a" );
          int brt =  (sTmp.substring(0, commaIndex)).toInt();
          sTmp.remove( 0, (commaIndex + 1) );
          int ctrast = (sTmp.substring(0, commaIndex)).toInt();
          sTmp.remove( 0, (commaIndex + 1) ); // chop off begining of message
          int sat = (sTmp.substring(0, commaIndex)).toInt();
          configureCameraSettings_grpA( brt, ctrast, sat );
      if ( String(px_message.topic) == topicGrpB )
        if ( sTmp.substring(0, commaIndex) == "b" );
          int se =  (sTmp.substring(0, commaIndex)).toInt();
          int wbb = (sTmp.substring(0, commaIndex)).toInt();
          int wba = (sTmp.substring(0, commaIndex)).toInt();
          int wbm = (sTmp.substring(0, commaIndex)).toInt();
          configureCameraSettings_grpB( se, wbb, wba, wbm );
      if ( String(px_message.topic) == topicGrpC )
        if ( sTmp.substring(0, commaIndex) == "c" );
          int ex =  (sTmp.substring(0, commaIndex)).toInt();
          int aec2 = (sTmp.substring(0, commaIndex)).toInt();
          int ae = (sTmp.substring(0, commaIndex)).toInt();
          int aec = (sTmp.substring(0, commaIndex)).toInt();
          configureCameraSettings_grpC( ex, aec2, ae, aec );
      if ( String(px_message.topic) == topicGrpD )
        if ( sTmp.substring(0, commaIndex) == "d" );
          int gc =  (sTmp.substring(0, commaIndex)).toInt();
          int agc = (sTmp.substring(0, commaIndex)).toInt();
          int celing = (sTmp.substring(0, commaIndex)).toInt();
          int bpc = (sTmp.substring(0, commaIndex)).toInt();
          int wpc = (sTmp.substring(0, commaIndex)).toInt();
          int gma = (sTmp.substring(0, commaIndex)).toInt();
          configureCameraSettings_grpD( gc, agc, celing, bpc, wpc, gma );
      if ( String(px_message.topic) == topicGrpE )
        if ( sTmp.substring(0, commaIndex) == "e" );
          int lenC =  (sTmp.substring(0, commaIndex)).toInt();
          int Hmirror = (sTmp.substring(0, commaIndex)).toInt();
          int Vflip = (sTmp.substring(0, commaIndex)).toInt();
          int dcw = (sTmp.substring(0, commaIndex)).toInt();
          int colorbar = (sTmp.substring(0, commaIndex)).toInt();
          configureCameraSettings_grpE( lenC, Hmirror, Vflip, dcw, colorbar );
      if ( String(px_message.topic) == topicFlash )
        FlashMode = bool(px_message.payload);
    } //if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
  } //for(;;)
} // void fparseMQTT( void *pvParameters )
void loop() {}
Hope it helps.
Can this cause the error?
Multiple libraries were found for "WiFi.h"
 Used: /Users/norah/Library/Arduino15/packages/esp32/hardware/esp32/1.0.6/libraries/WiFi
 Not used: /Applications/Arduino.app/Contents/Java/libraries/WiFi
These libraries
//#include "ESP32_FTPClient.h"
//#include <PubSubClient.h>
//#include <ESP32Time.h>
//#include "certs.h"
showing me a fatal error: No such file or directory
Makes sense that those libraries are causing you issue as your original code does not have those libraries. I'm sorry for including those libraries, I'd thought, that since you were not originally using them you'd just key in on the code I posted about connecting to the WiFi and skip the stuff you are not using.
The certs.h file contains my passwords and stuff, you'll not be getting a copy of that file.
Yes, it can cause error BUT that's not the error. Copy the entire error message not just a portion.
With my code there id no error
Just show this as a warning
And it keeps trying to connect….
